meteotemplate php 8.0/8.1
Testing meteotemplate on php 8.0 and it seems to work with minor updates.
A few blocks/plugins should be updated too.
Not sure everything else is working.
v1.0
- make a backup of your meteotemplate installation
- expand the archive php8_1.0.zip in the root folder of your installation
- install the updated blocks/plugins as needed
NOTE
This mod includes also a few fixes:
- cookies/samesite warnings
- control panel -> database extraSensors backup
- control panel -> 'edit data' and 'edit data extra sensors' fixes
NOTE 1
The included indoorData plugin is an update of the plugin described here: viewtopic.php?f=60&t=1998&p=9653&hilit=indoordata#p9653
v1.0
NOTE
NOTE 1
- php8_plugins_1.0.zip
- (161.12 KiB) Downloaded 182 times
- php8_blocks_1.0.zip
- (138.6 KiB) Downloaded 175 times
- php8_1.0.zip
- (46.32 KiB) Downloaded 144 times
Re: meteotemplate php 8.0
good work, youve been busy!
I will keep this in mind if my server gets updated.
v1.1
- added scripts directory ( not included in previous version )
- few fixes
NOTE
One of the problem for the conversion is that a few warnings that where generated before in some occasions ( which generally passed unobserved ) are now generating errors. So the scripts may stop unexpectedly anytime.
One of these functions generating errors is the 'count' function ( added an equivalent and more safe count8 function ).
Another source of errors are mathematical operations between values which include non proper numbers
Testing now on my server ( waiting for next error to fix )
@mchd17
I'd say a little bit 'incasinato' ( but I don't know how to translate it ; - )
- few fixes
NOTE
@mchd17
- php8_1.1.zip
- (97.04 KiB) Downloaded 164 times
- Dehatter
- Station model: Ecowitt WH80/GW1000B
Not sure if anyone else is having this issue.
ssGuages will display as designed, but the display but will not update.
Syntax Error: Unexpected End of JSON input.
- Dehatter
Also a signature issue perhaps.
Fatal error: Array and string offset access syntax with curly braces is no longer supported in /homepages/5/d717902257/htdocs/template/plugins/stickers/stickerInteractiveAnim.php on line 1057
- Dehatter
Went back to v7.4, then reinstalled the backup for ssGauge block I made and all is working. So just these 2 minor issues I noticed. I did nothing for the signature - it just started working again on its own using v7.4.
Just so you know.
Excellent work though. It seemed like everything else was working fine on v8.0.
Just so you know.
Thanks for testing and for the feedback. Should post a few updates shortly.
- Dehatter
So...
If you give up on ssGauges and go to the other gauges block ('gauges' ver 7.1), then use your blocks modified for PHP 8.0, I am working not only with PHP 8.0 but with PHP 8.1. Obviously the signature block is still messed up, but I am ok with that inconvenience.
One thing about the gauges block is that you can not change the color of the 'updated' highlight. Just for page consistency, I changed the highlight color on my current block to match the gauge block (#85D7E3).
Also, lesson learned, if you modify the gauge range for the temperatures, use a value that ends with a zero (like 110) or the block will round up to the nearest 10 for the background, yet the arrow will display based the value you entered. Example - I set the maximum value for 105 but this is what it looked like:
You can see the temp is 86, but the gauge shows well over 90.
Now my page is good until 12/2024 with no further intervention from me.
I will TOTALLY miss the extra information from the ssGuage mouseover and the wind rose, but the ssGuages GIT hub site has not been touched for 7 years so I do not feel like anyone is going to update it any time soon.
Database seems to be updating and all site functionality seems to be working.
FYI, I have an Ecowitt WS80 using a GW1000B to log my data to a meteobridge device.
Blocks used on my page:
Radar40, airQualityUS, astroEvents, cloudHeight, cloudTemp, co2, count, countDown, current, dayNight, dayPie, dbInfo, earthquakes, forecast, forecastGraphical, gauges, gfs, graphCombined, highLowUS, history, indoor, interactiveGraph, lightning, location, metarCustom, meteogram, moonPhase, nwsForecastCustom, radarUS, rain, riset, ssGauges, stationAverages, stationData, stationRecords, stationStatus, text, trends, usExtremeProbability, usSPC, uv, videos, warningsUSRegions, weatherNetworks, webcam, webcamTimelapse, wind, windy, worldTime
www.meckweather.com
www.meckweather.com
Thanks for trying ( and for the feedback ).
Regarding the steelSeries plugin I updated it ( to fix an error in case selected time format is am/pm ): viewtopic.php?f=60&t=2096#p11453
Need to dig further about ssGauges and windRose blocks and php 8.1 compatibility.
- Dehatter
You are my latest and greatest hero. I missed that thread!
Thank you so very much,
Plugin works great, but I am having trouble with the block working.
www.MeckWeather,com
www.MeckWeather,com
Plugin stickers ver 7.3:
- fixed compatibility with php 8.0/8.1 ( www.davidefabbri.net/files/stickers_7.3.zip )
- meteoesine
- Station model: Davis Pro2 + BloomSky cam
- Software: Meteobridge nano
Ciao,
I've definitively set my host for the php 8.1 version (8.1.8 to be precise)
davidefa's mods workd pretty fine but as far as I'm concerned there are still a couple of things that still don't work
* https://meteoesine.it/template/pages/st ... tDaily.php
* https://meteoesine.it/template/pages/st ... ndices.php
many thanks in advance to try to fix them asap
- ScreenShot01096.jpg (28.78 KiB) Viewed 4049 times
- ScreenShot01097.jpg (37.68 KiB) Viewed 4049 times
Yes, all scripts in pages directory need to be updated ( added in my todo list )
Re: meteotemplate php 8.0/8.1
Updated the pages and mobile directories ( mobile pages only minimally tested )
- updated the forecast to use openweathermap.org api, ( in place of darksky.net that should retire next march ), insert the api key, in the main setup, in place of the darksky one
- pdf generation should be ok
- Station model: WS-2902A/GW1000
- Software: ECOWITT Plugin
I have to update my server to PHP 8.0
I Know in its current state 18.0 it wont work my biggest concern is ecowitt plugin which I require for my WS 2902A to work
What should I download ? This has a lot of different posts here making it confusing.
Do I just need the 3 zips in the top post?
Thanks in advance
I just looked at what I have done over the years
Blocks installed
Blank block
current Current Conditions Block
logo
naSatellite North American Satellite
nws NWS Alerts - Saratoga Script 1.1
radarUS
ssGauges Steel Series Gauges 3.1
Station Status 5.0
Summary 5.4
Videos 1.0
warningsUSRegions
Weather Networks block
webcam
Wind
Plugins Installed
airTraffic 1.1
apiViewer 1.0
bloomSky 3.0
contact 3.0
diary 4.0
ecowitt 2.8
pageBuilder
steelSeries 4.0
stickers
Thanks in advance
Blocks installed
Blank block
logo
radarUS
Station Status 5.0
Summary 5.4
Videos 1.0
warningsUSRegions
webcam
Wind
Plugins Installed
airTraffic 1.1
apiViewer 1.0
bloomSky 3.0
contact 3.0
diary 4.0
ecowitt 2.8
pageBuilder
steelSeries 4.0
stickers
- Station model: VP2+
- Software: Meteobridge Pro
I have just found this post following a notification from One.Com that they have moved to PHP 8.0. With 8.0 the template doesn't respond which reading the above was expected. I was able to force a move back to 7.4 but this will cease on 28th November. My immediate thought was to abandon the weather site altogether which would be a great shame as I have other non-weather pages attached to it such as Gallery. I have read a few of the posts but I don't think my brain is making much sense of it.
Is there a step by step guide to correct this or is it an ongoing exercise.
This is an update of the first post.
v1.1
- expand the archive php8_1.1.zip in the root folder of your installation
http://www.davidefabbri.net/files/php8_1.1.zip
NOTE
This is not the same archive as the first post ( even if the name is the same, sorry for the confusion ), use this archive
Currently converting blocks and plugins, if you have a non functioning block/plugin please drop a note
P.P.S.
If you don't 'feel brave enough' to test this mod on your main site ( or if you simply want to create a meteotemplate 'test site' ) you can create a 'parasite meteotemplate' ( a site that share the same database as the main one ):
- copy your main site from 'template' to 'template1' directory
- edit your template1/config.php in line 19 from:
to
- expand the archive php8_1.1.zip in the template1 directory
- last step, create a symlink so that template1/meteotemplateLive.txt points to template/meteotemplateLive.txt ( or you can use a cron job that copies template/meteotemplateLive.txt to template1/meteotemplateLive.txt every minute or so )
Point your browser to the 'template1' directory and you should be able to see your 'parasite meteotemplate site'
@spd2612
ecowitt plugin v2.11 or 3.0 should be ok ( I currently use v2.11 with php 8.0 )
Most of the blocks/plugin you mention should be php 8.0 compatible, just install last version
@G4MHJ
Just follow the above steps and you should be ok, as you say, this is a work in progress any feedback is welcome
v1.1
NOTE
P.P.S.
$path = '/template/';
$path = '/template1/';
@spd2612
@G4MHJ
I am using PHP 8.0 although I dont see any issues with the template My PHP log is filled with this error any idea where its comming from?
I do have a couple more errors but this one is constant
[06-Oct-2022 21:18:12 America/New_York] PHP Warning: Undefined variable $base in E:\hurricanepub\api.php on line 69
- Station model: Vantage pro 2 plus
Good Day,
I have switched my site to PHP 8.0 and come across a little problem, which works with 7.4.
I can see the page
https://www.waskolkweer.nl/meteotemplat ... ndices.php.
I can't open the page, I can't find anything about it, but maybe I'm not looking properly.
Gerrit
I can see the page
Gerrit
@Gerrit
I think you still have the original climateIndices.php file try substituting with the attached one ( uncompress it in the pages/station directory )
@spd2612
You can use the last api.php script ( the attached one is ok, extract it in the root directory of your meteotemplate installation )
@spd2612
- api_3.4.zip
- (12.59 KiB) Downloaded 79 times
- climateIndices.zip
- (6.04 KiB) Downloaded 56 times
@davidefa
That did seem to fix those PHP ERRORS Thank you very much .
should I be using v1.1
- few fixes
Not sure if I am using that or not I went ahead and put the v1.1 update on just to be sure
Here is the other error Im getting
And the Forcast page has a fatal error
https://hurricanepub.com/pages/forecast ... php?errors
- few fixes
[14-Oct-2022 12:54:32 America/New_York] PHP Warning: Undefined array key "" in E:\hurricanepub\include\include.php on line 468
Warning: Undefined array key "madis-stations" in E:\hurricanepub\pages\forecast\index.php on line 483 Fatal error: Uncaught TypeError: implode(): Argument #1 ($pieces) must be of type array, string given in E:\hurricanepub\pages\forecast\index.php:483 Stack trace: #0 E:\hurricanepub\pages\forecast\index.php(483): implode() #1 {main} thrown in E:\hurricanepub\pages\forecast\index.php on line 483
- Station model: Ecowitt WS90
I did the same. Just copied over existing files with david's newest php 8.0-8.1
Does not work for me. This time the page loads but does not update the api or datadase with new dataon ionos.com host server. I get the following errors but only showing the forcast/index.php errors for now.
Notice: Undefined variable: returner in /homepages/37/d726071500/htdocs/wx/scripts/headerMetar.php on line 686
Warning: file_get_contents(https://api.openweathermap.org/data/2.5 ... 4cdc4010f8): failed to open stream: HTTP request failed! HTTP/1.1 401 Unauthorized in /homepages/37/d726071500/htdocs/wx/pages/forecast/index.php on line 77
Warning: array_key_exists() expects parameter 2 to be array, null given in /homepages/37/d726071500/htdocs/wx/pages/forecast/index.php on line 109
Warning: array_key_exists() expects parameter 2 to be array, null given in /homepages/37/d726071500/htdocs/wx/pages/forecast/index.php on line 220
Warning: array_key_exists() expects parameter 2 to be array, null given in /homepages/37/d726071500/htdocs/wx/pages/forecast/index.php on line 340
Warning: array_key_exists() expects parameter 2 to be array, null given in /homepages/37/d726071500/htdocs/wx/pages/forecast/index.php on line 485
Warning: array_key_exists() expects parameter 2 to be array, null given in /homepages/37/d726071500/htdocs/wx/pages/forecast/index.php on line 501
@spd2612
I think you still have the original pages/forecast/index.php script try substituting with the attached one ( uncompress it in the pages/forecast directory )
The other error refers to include\include.php script, which is not part of meteotemplate, so can't help about that ( or you could zip and post the content of the script so I can take a look )
@andyk1
Regarding the error in the forecast page you need to register on the openweathermap get an api key and insert it in the meteotemplate main setup ( in place of the darksky api key )
Regarding the database not updating i think that i could debug the issue having access to your meteotemplate site ( either having access to your hosting provider control panel or simply having an ftp access to your site )
@andyk1
- PagesForecastIndex.zip
- (15.67 KiB) Downloaded 66 times
The file did not fix this
https://hurricanepub.com/pages/forecast/index.php
see attachedI think you still have the original pages/forecast/index.php script try substituting with the attached one ( uncompress it in the pages/forecast directory )
