Physalis - Known bugs
Post by Jachym » Mon Sep 25, 2017 8:20 pm
I will list known bugs here, which I will fix in bulk after a few more days in case other problems are discovered.
- database update setup link in control panel does not redirect to the setup page
meteocaldas
Station model: OS WMR-88A
Re: Physalis - Known bugs
Post by meteocaldas » Tue Sep 26, 2017 7:37 pm
I made a clean install of MT16 and a clean install of all the previous modules using the auto install tool.
The majority of the clean installed modules, was missing the icons folder.
Tides, location, forecast, trends, moonphase, riset, just to name a few.
Some were also missing the cache folder, and this folder was not created after using the module.
Is this a bug or just a problem of mine?
http://www.meteocaldas.com/mtp16/indexDesktop.php
Post by Jachym » Tue Sep 26, 2017 7:38 pm
Im slowly getting rid of the icons folders as I update the blocks and instead of PNG icons use the SVG CSS objects, which are in all respects better.
meteocaldas
Post by meteocaldas » Tue Sep 26, 2017 7:53 pm
Jachym wrote: Tue Sep 26, 2017 7:38 pm Im slowly getting rid of the icons folders as I update the blocks and instead of PNG icons use the SVG CSS objects, which are in all respects better.
Understood. Are there any blocks/plugins already using the SVG icons or will you use a single icons folder for all the new blocks? Thanks.
Post by Jachym » Tue Sep 26, 2017 9:04 pm
Over half of the blocks are now using SVG and the entire main template (no longer uses PNG icons).
nikokara - BANNED
Station model: ng265 (Fine Offset)
asteroids
Post by nikokara - BANNED » Thu Sep 28, 2017 10:10 am
Jachim
In defaultItems.txt (......\admin\menu\) @line 24 remove
\r\n#default(asteroids),
in root/menu.php
@line 167 remove or comment
$temporaryContent[] = "#default(asteroids)";
@line 223 remove or comment
$defaultSpecs['asteroids'] = array("pages/astronomy/asteroids.php","asteroids","mticon-meteor");
niko
nikokara - BANNED
Post by nikokara - BANNED » Sat Sep 30, 2017 11:54 pm
asteroids in mobile version stil available
[*]....mobile\pages\astronomy\asteroids.php
[*]....mobile\menu.php @line 486
niko
dmgould
Post by dmgould » Sun Oct 01, 2017 5:30 am
I just went in to add the apiViewer plugin to my menu. After I finished I clicked 'Check My Menu' button in the menu setup. It tells me:
Default Pages
Your menu is missing the following default pages:
asteroids
I deleted that from my menu prior to updating to v16. I just checked via ftp and the plugin directory is gone. Unless I'm missing something - is this a bug? It does this on both of my sites.
nikokara - BANNED
Post by nikokara - BANNED » Sun Oct 01, 2017 5:49 am
Hi dmgould
Have a look here
viewtopic.php?p=1432#p1432
Make backups first etc blablabla
or wait for jachim's fix-patch :D
niko
dmgould
Post by dmgould » Sun Oct 01, 2017 7:14 am
Of course nikokara a backup is not the solution here. The problem is in the code which I see you have searched out. Good catch. For the record I always download a complete site backup to a local computer prior to a version update.
nikokara - BANNED
Post by nikokara - BANNED » Sun Oct 01, 2017 7:26 am
I mean before you try to make the fixes in the code yourself.
I down know if you are familiar with that
niko
Post by Jachym » Sun Oct 01, 2017 8:56 am
It should be deleted from the menu check. It should however not affect your site in any way.
