Auto-updates
Auto-updates
Hi guys,
clearly, what I need to know is:
- what percentage of people has problems with this
- what exactly happens
Then I will see the approximate percentage of users with problems and also can try to see if there is any pattern, if these users have something in common - same provider, same server configuration etc.
I would therefore like to ask everyone to check if the auto-updates/installations work and then let me know in this thread.
If the updates are working fine, just post "OK" - do not ignore this I need to also see for how many users it works, not just those who have probles.
If it does not work, just say "No" and if you can specify any more details it would be great.
- nitrx
Re: Auto-updates
OK
http://apeldoornmeteo.nl meteotemplate multilangual by Jachym
http://www.apeldoorn.tk/weer/index.php Saratogatemplate by mulilangual
http://apeldoorn.tk/weer Cumulus template Dutch only by Steve/Sandaysoft
http://apeldoornmeteo.nl/pws/ Home Weather Station by Brian multilangual
- Station model: WH 1080 + RPI 3
- Software: WeeWX 3.9.1
Re: Auto-updates
Also OK for me, both Plugins and Blocks
"Deus mare, Friso litora fecit" (God created the sea, Frisians the coast).
Best Regards
Georg
Best Regards
Georg
Re: Auto-updates
OK here
- Johnny
- Developer
Re: Auto-updates
Okay for me as well, I use cPanel 11 with Namecheap
- Station model: Davis Vantage Pro II
Re: Auto-updates
It does not work.
I am on ovh.com and it does not work for me nor has it ever worked for me to automatically detect the latest version of each block or plugin
- i_fiorentino
- Language Admin
Re: Auto-updates
I don't know beacuse there wasn't any block or plugin to update.
Re: Auto-updates
OK, so far it is looking better than I expected, but I will need many more users to provide some feedback. Also it seems like there might be some common things amongst those for whom it does not work.
- nikokara - BANNED
- Station model: ng265 (Fine Offset)
- Jeffm5690
Re: Auto-updates
No. Used to at least show updates. Now all blocks and plugin are 0.0. Using inmotion host - they checked and can telnet your site and it is not blocked.
Re: Auto-updates
Yes, this one is particularly weird. Neither file_get_contents, nor cURL is able to load even a simple text file...
- meteoesine
- Station model: Davis Pro2+
- Software: Meteobridge nano
- Software: WeatherCat
Re: Auto-updates
OK for me.
- Thomas
Re: Auto-updates
not work for me (verification update blocks and plugins and update language, blocks impossible)
My web hosting told me to use a "user agent"; because meteotemplate.com rejects the commands "file_get_contents" without "user agent"...
Station Météo Alès: www.meteoales.fr
- didoujm
- Software: WEATHER DISPLAY
Re: Auto-updates
pas de problème pour moi aussi
Didier
Didier
Re: Auto-updates
Ok block only, not plugin
