SILAM allergy risk forecast map as a block
Julius
Software: meteobridge
Post by Julius » Mon Oct 04, 2021 12:14 pm
Turns out this map;
https://silam.fmi.fi/pollen.html?parame ... ion=europe
is particularly correct for me and my girlfriend's allergies. Would be great to be able to put this animated png inside a block, or perhaps even just a bunch of the forecast png's rotating? I'm guessing these are always for the coming hours;
https://silam.fmi.fi/AQ/operational/eur ... 00_040.png
https://silam.fmi.fi/AQ/operational/eur ... 00_041.png
https://silam.fmi.fi/AQ/operational/eur ... 00_042.png
https://silam.fmi.fi/AQ/operational/eur ... 00_043.png
(not sure at what interval these are updated, but so far it seems to work as a general pollen forecast).
Must be someone who has scripted rotating 3 or 4 images inside a block before. Anyone?
Daali
Station model: Ecowitt GW1002
Re: SILAM allergy risk forecast map as a block
Post by Daali » Mon Oct 04, 2021 1:59 pm
You could use dynamicImage for a singe image, updatable block
or you could use the images block with a back end cronjob to curl those sites to update the images folder.
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
WH41 PM2.5 Air Quality
WH45 PM2.5/10/Co2 Air Quality
WN34S Soil temperature
WH31SM Soil Moisture
