just a suggestion: as there is already the InterativeGraph block, very complete and customizable also for short and long period graphs, graphCombinate block seems to be a light duplicate of that one.
On my opinion, graphCombinate block should simply show graphs of 24/48h, like the enclosed image for example, with 2 trend lines: one for last 24 hours and the second one from 48h to 24h.
most probably will be not feasible, but what do you think?
thanks also to Users for any comments
graphCombinate - alternative version
- meteoesine
- Station model: Davis Pro2+
- Software: Meteobridge nano
Re: graphCombinate - alternative version
you can specify the interval of the graph, including 24h already. I could add the possibility of 48 interval as well I guess, but if you look at the code you only need to replace 24 with 48 at one place and it will work so it should be easy to change even for you
- meteoesine
I’m not skilled to change the codes, thanks anyway
OK, I will add the 48h option myself, it is not complicated and if you think it will be useful we can do it
- meteoesine
Thanks Jachym, very kind of you
