If you need to run several different cron job scripts, don't assume (like I did) that the command line syntax is identical.
The cron.php script in /load parses the command line password from "password=<update password>"
The update.php script in /plugins/metoehub parses the command line password from "pass=<update password>"
In the ideal world the syntax would be identical; however the correct syntax is documented by Jachym in both instances.
Pay attention: Cron job command line parameter syntax
- Fraggboy
- Software: Bloomsky
Re: Pay attention: Cron job command line parameter syntax
Great post. I aways check in the php file to see what syntax is needed.
