- configure the plugin inserting 'access token' and 'station id' ( available via tempestwx.com )
- copy the script weatherflowUpdate.php to load/crons and setup a CRON job ( if not already created ) to execute load/cron.php?password=xxx ( I think 1 minute is ok for the cron job )
only the following fields are converted in the corresponding meteotemplate filed:
["timestamp"] ["U"]
["air_temperature"] ["T"]
["sea_level_pressure"] ["P"]
["relative_humidity"] ["H"]
["precip_accum_local_day"] ["R"]
["precip_accum_last_1hr"] ["RR"]
["wind_avg"] ["W"]
["wind_direction"] ["B"]
["wind_gust"] ["G"]
["solar_radiation"] ["S"]
["uv"] ["UV"]
["lightning_strike_last_epoch"] ["LT"]
["lightning_strike_last_distance"] ["LD"]
["lightning_strike_count"] ["L"]
