createConfig.php
MS30
createConfig.php
Post by MS30 » Tue Feb 01, 2022 8:02 pm
Hallo zusammen
Ich habe folgendes Problem:
Wenn ich in der setup.php auf Save gehe, erschein im nächsten Fenster folgende Meldung:
Config created/updated.
und obehalb eine Menge fehler
http://www.ms30.at/Fehler.png
Vielleich kann mir bitte einer helfen was ich falsch mache
Danke
Re: createConfig.php
Post by davidefa » Tue Feb 01, 2022 10:44 pm
Which version of php are you using?
Currently meteotemplate is not compatible with php 8.0 or higher ( but I'm working on it ).
MS30
Post by MS30 » Wed Feb 02, 2022 10:03 am
Thank you for your answer. I am currently using php 8.0.
Post by davidefa » Wed Feb 02, 2022 10:59 am
You should be able to change php version trough the control panel of your hosting provider
FSC830
Post by FSC830 » Wed Feb 09, 2022 9:05 am
any idea when PHP 8 will be supported?
Seems that my provider is going to drop any PHP 7 in near future (7.4 is still available).
Post by davidefa » Wed Feb 09, 2022 10:24 am
Sorry I don't have a date ( a calendar date ; - ), I'm working on porting meteotemplate to php 8.0.
I'd say soon... but don't hold your breath ( I mean my site, in my signature, is already working on php 8.0 but if you navigate between menu entries you'll find 'a few' problems... )
FSC830
Post by FSC830 » Wed Feb 09, 2022 10:56 am
Ok, thanks.
Just another question: transferring meteotemplate to PHP 8.x also means modifying database access from mysql to mysqli?
Post by davidefa » Wed Feb 09, 2022 11:33 am
No, already meteotemplate uses mysqli.
The main changes are due to warning -> error conversion ( previous warning, almost unnoticed, that now throw an error )
