I have spent days and days finding the answer for my problem, reading the WIKI several times, searching with Google, but I don't know what to do. The problem is I started with the setup.php, everything went fine, the config.php was made but when I was finished and tried to start my setup.php again I was not able to open it anymore. My Chrome browser shows me "Unauthorized access. Please log in as an administrator first" but I can't login because I can't open the setup.php
How oer where can I login as administrator, logging in to my website does not help. I can login with filezilla, see all the files so that is no problem.
Maybe the solution is simple and I hope someone can help me thank you very much!
Hans
(the Netherlands)
setup.php
- iatros
- Language Admin
Re: setup.php
Hi Hans
I assume you can access your ...//template/indexDesktop.php and open your Meteotemplate-Homepage?
Then scroll down to the footer, look for the lock - icon at the very right and click on it, then enter your admin-password. This will open the settings.
hth - cheers, Martin from Switzerland
- Station model: Davis pro 2
Re: setup.php
Hey Martin
Many thanks for your reply but that was just my problem I could not reach //template/indexDesktop.php after setting up. But you encouraged me to think a different way and in 20 minutes I found a workaround.
Now finally I can go on after 2 weeks!!!! Thank you so much
Greetings
Hans from the Netherlands
Greetings
