meteotemplate php 8.0/8.1
- Station model: PCE-FWS-20
- Software: cumulus
Re: meteotemplate php 8.0/8.1
Good night guys;
my service provider is going to drop support for php7.4 and
I spend hours and hours reading your suggestions and changes.
I have updated with the latest davidefa files but I can't get the station status and station block to work, stopping to update the database but it does update the current block.
my pay is panxabuida.es
What can I do or what can I look at?
thank you
thank you
- Station model: WS-5000/GW1100
- Software: ECOWITT Plugin
Well all the updated need to be put together in a pre release
It does work im using php 8.1
Keep in mind you may have to sacrifice some of the third party blocks and plugins but that time was coming some of those developers have moved on
David has been a real asset to keeping Meteotemplate still running
If you have done Dave's
updates and still have issues some debugging may have to be done if you dont know how just ask there are a lot of good people on here that can tell you how
Good luck
Good luck
Good luck
Good luck
- lemimi
To update some of my programs written in php and rather than correct errors line by line, I recently discovered Rector.
It does help! Even if that does not accomplish everything.
It is a program that automatically upgrades and refactors your application's PHP code.
See here: https://github.com/rectorphp/rector
and even online directly: https://www.phptools.online/php-checker
More info by searching for Rector PHP 8 with your favorite search engine.
Do not forget to put or switch your local or remote server to php 8: a program that runs in php 8 may not work at all in 7 and even less in 5!
If that can help...
Good day... Michel
If that can help...
Good day... Michel
- Software: cumulus
thanks for the comment.spd2612 wrote: ↑Thu Feb 16, 2023 11:58 pm Well all the updated need to be put together in a pre release
Good luck
Good luck
I started again from scratch, left everything as it was with the backup copy and installed the files modified by davidefa one by one from the first php v1 to v 1.1 and now it's working.
some blocks don't work as expected but none important.
I'll be in php 8.0 for a few days and I'll go to php8.1 and even php 8.2 if possible.
Thanks again for the help, especially for Davidafe.
- Station model: Davis pro 2
Any help here would be much appreciated as I'm pulling my hair out!
The display of my webpage is completely messed up. I have updated all the files as mentioned earlier in this thread I've even tried a brand new fresh install, but the page layout using Safari on a Mac or chrome looks a mess even on a PC. Were is the problem? is it in the database or in the files as like I said with a clean install, I get the same output.
http://www.nitram-media.com/weather
PHP 8.1
PHP 8.1
Please describe as exact as possible, what you did.
Looks, like some formatting is missing.
- lemimi
Good morning,
Your address with HTTP points to HTTPS.
If I force from my browser to open without security, your site is displayed normally.
Good day... Michel
Good day... Michel
Indeed...
But seems, that some blocks are still not updated (endless spinner) for PHP 8.x.
Thank you all that replied, yes is was a http-https setting.
I have now updated plugins and all should be working, Thank again.
- meteoesine
- Station model: Davis Pro2+
- Software: Meteobridge nano
checking for any ?errors this warning appears to me. How can i fix it?
many tnx in advance
Warning: Undefined variable $moreclouds in /.../template/scripts/headerMetar.php on line 832
if ($moreclouds == "yes") {
$returner = "$returner$cumulus";
} else {
$returner = false;
return $returner;
and also if running headerMetar.php
Warning: Undefined variable $baseURL in /home/cldvlwax/public_html/template/scripts/headerMetar.php on line 36
Warning: Undefined variable $baseURL in /home/cldvlwax/public_html/template/scripts/headerMetar.php on line 42
P.S. @FSC830 scripts are already installed
/header.php
/scripts/functions.php
/homepage/css/themeSetter.php
/homepage/blocks/current/currentBlock.php
many tnx in advance
} else {
$returner = false;
return $returner;
/header.php
- Screenshot - 19_03_2023 , 08_07_03.jpg (26.6 KiB) Viewed 880 times
Hm, may that I did find this after uploading the last archive, but my file is slightly different.
Here its not line 832, but line 835:
The $baseURL issue was not seen at my site yet!?
Need to investigate this.
But when calling your site
no errors are thrown!?
if ((isset($moreclouds)) && ($moreclouds == "yes")) {
https://meteoesine.it/template/indexDesktop.php?errors
- meteoesine
true, I noticed it too after cleaning the pc with ccleaner ...
- atari
- Station model: ws2315
- Software: weewx,cumulus
updated currentBlock.php not woking on my config,Im using v18, good work
tested & runing on php8.2
"not working" is not a good description, what exactly is wrong?
Looking at your site https://neutrino-digital.com/template/i ... on=21.4173 currentBlock seems working as designed!?
- atari
On v18 its working showing meteo data, but whan i try to update it show only time, all senzor are gone.
Btw Im using cumulus to send data to web.
