Sea Temperature Block Trouble
LOBWX
Station model: Ambient WS 1401-IP
Software: MeteoBridge
Post by LOBWX » Tue Nov 13, 2018 2:30 am
Having a bit of an issue with the seaTemperature block on https://lobwx.com its in the block named "Marine Specs" on the right, under the hamburger.
Im am trying to grab this data north-america/united-states/morro-bay.htm from https://www.seatemperature.org
Here is the output I am getting:
Notice: Undefined offset: 1 in /home/foe33895/public_html/lobwx/template/homepage/blocks/seaTemperature/seaTemperatureBlock.php on line 82
Notice: Undefined offset: 2 in /home/foe33895/public_html/lobwx/template/homepage/blocks/seaTemperature/seaTemperatureBlock.php on line 83
Notice: Undefined offset: 3 in /home/foe33895/public_html/lobwx/template/homepage/blocks/seaTemperature/seaTemperatureBlock.php on line 84
Notice: A non well formed numeric value encountered in /home/foe33895/public_html/lobwx/template/scripts/functions.php on line 165
Warning: A non-numeric value encountered in /home/foe33895/public_html/lobwx/template/scripts/functions.php on line 165
LOBWX
Re: Sea Temperature Block Trouble
Post by LOBWX » Fri Nov 16, 2018 12:28 am
Weird started working again ???
Julius
Software: meteobridge
Post by Julius » Sun Dec 25, 2022 2:40 pm
This block is broken now. I only see 0C values everywhere people use it..
tobydude
Software: Weatherdiaplay
Post by tobydude » Sun Feb 19, 2023 11:03 am
Can it be fixed?
Post by alexvanuxem » Sun Feb 19, 2023 4:59 pm
it's fixed
follow this thread viewtopic.php?f=56&t=2347&p=12117&hilit ... ure#p12117
hope it helps?
grtz
Alex
tobydude
Post by tobydude » Sun Feb 19, 2023 5:15 pm
alexvanuxem yes !
I think it works on my weaterpage now.
Thanks.
Juan Maria Vilaró
Software: Weather Dislplay
Post by Juan Maria Vilaró » Fri Mar 10, 2023 9:24 am
Good morning, I ask for help to repair the block "seaTemperature version 2.2" has been working correctly for a long time, but for a while it only indicates 0.0 and I don't know how to fix it, could someone help me or give me some solution?
thank you so much
URL: https://badameteo.com/template/indexDesktop.php
Post by alexvanuxem » Fri Mar 10, 2023 1:55 pm
when I visit your site, it seems to be working: I see 12.7°C in Badalona?
Grtz
FSC830
Post by FSC830 » Fri Mar 10, 2023 4:24 pm
@alexvanuxem: my guess, you are looking at the wrong page. ;)
When language is set to English: Weather -> Seatemperature
@Juan
Check, if the quick and dirty solution runs for you.
Backup the original files in advance.
From archive copy functions.php to </template_root/>scripts and the seaTemperature.php to the referring block directory.
Please give a feedback ;)
Saludos
!!! Note: file for seaTemp block!
seaTemp.zip
(11.1 KiB) Downloaded 73 times
Edit: Anyhow, just noticed, that your block looks different than mine!?
Where did you download this block? Is yours really a "block" or a "plugin"?
Edit II: just found, you are using a PLUGIN, not a BLOCK. Please do not mix up these two.
Now looking in the plugin... done :D
Ok, please download the index.zip, put the extracted index.php in seaTemp plugin directory and test.
!!! Note: file for seaTemp plugin!
index.zip
(2.63 KiB) Downloaded 70 times
Post by alexvanuxem » Sun Mar 12, 2023 5:59 pm
i got confused , when its's a block its visible at the homepage,
when its a plugin it's visible at weather etc???
so it's not block but a plugin?
8-)
FSC830
Post by FSC830 » Sun Mar 12, 2023 6:25 pm
No, there are two different modules.
One is a block, showing 5 targets maximum, the other is a plugin with only one target and statistics.
Me too was confused, as the "seatemp block" was mentioned.
Looking at Juans website shows a difference to my installed block.
Then I noticed, that there is a plugin too for sea temperature.
And yes, the blocks can be added to desktop, whereas plugins are visible from the menu bar.
Confusing, if different modules for same/similiar data are available.
Cavaliere
Station model: Peet Bros Ultimeter 2100
Post by Cavaliere » Sun Nov 19, 2023 8:32 pm
I just tested the file of the block in question, indicated above and now the block loads it, but the current data brings me 0.0 °C. And also if I change city, it doesn't change in the block.
Do you have a solution?
FSC830
Post by FSC830 » Tue Nov 21, 2023 12:14 pm
What is your site (link)?
Block or plugin?
Cavaliere
Post by Cavaliere » Tue Nov 21, 2023 5:07 pm
FSC830 wrote: Tue Nov 21, 2023 12:14 pm What is your site (link)?
Block or plugin?
Block Seatemperature.
My site: www.ombarcellonapg.com
Regione seatemperature this: https://www.seatemperature.org/europe/italy/milazzo.htm
