Good morning,
The "Outlook" plugin in the "Forecast" menu in "Weather" no longer displays anything!
What is the problem ? Thank you for your help.
Sincerely
Hervé
http://pecouba.fr/IMAGE/Capture%20d'%C3 ... 100753.png
PROBLEM with Outlook" plugin in the "Forecast"
- Station model: Davis pro 2
- Software: Weatherlink
Re: PROBLEM with Outlook" plugin in the "Forecast"
Good evening, I looked on other sites and a priori the problem is general. I'm in the same situation as you. Davide, as is often the case, may have the solution.
But if a member of the community has the answer, don't hesitate.
Looking forward to
Looking forward to
- lemimi
hello,
En tout cas, cela fonctionne nickel chez moi :
https://lemimi.fr/template/pages/forecast/index.php
Bonne soirée... Michel
Good evening,
Indeed it seems to work with the old OpenWeather APIs.
The news has problems...
- Station model: HP2550
- Software: WU
Good morning,
How to recover the working plugin?
Sincerely.
Hervé
https://meteo88.pecouba.fr/
Bonjour,
Comment récuperer le plugin qui fonctionne ?
Cordialement.
Hervé
Sincerely.
Hervé
Bonjour,
Cordialement.
Hervé
