Usradar Problem
Edderton_Weather
Station model: Davis Vantage PRO2
Usradar Problem
Post by Edderton_Weather » Sat Dec 02, 2017 5:29 pm
Hi
I have a problem with the US radar plugin
It just shows all of the usa map and menu for setlecting weather satellites ?
Not the same as the demo site. All of the other plugins work fine.
I have deleted folder, download 2nd copy of zip from site. checked all files.
still not working to design
Url is
http://www.ardmore-lodge.com/template/p ... /index.php
Setup info
USradar version v2.0
Plugin Setup
#plugin(usRadar)
Plugin folder
/public/template/plugins/usRadar
template version
Meteotemplate 16.0 Physalis
I have checked upper and lower etc. just used the default. As far as I can see the are no setting up from the Menu setup tan.
Where am I going wrong. :?:
Phillip
Re: Usradar Problem
Post by Jachym » Sun Dec 03, 2017 10:31 am
I dont see any problems, yours looks exactly like the DEMO page (at least for me when I checked)
http://www.meteotemplate.com/template/p ... /index.php
Edderton_Weather
Re: Usradar Problem
Post by Edderton_Weather » Sun Dec 03, 2017 8:06 pm
Hi Jachym
When I go to your demo site it looks like
http://www.meteotemplate.com/template/p ... /radar.php
When I go to mine from any PC including friends PC's
It look like this
Phillip
Re: Usradar Problem
Post by Jachym » Sun Dec 03, 2017 8:54 pm
Hi
if you delete the radar.php from the URL you will see the demo is the same. THe link you posted is for an older version which I forgot to remove from the DEMO server, but yours is ok
Edderton_Weather
Re: Usradar Problem
Post by Edderton_Weather » Mon Dec 04, 2017 9:21 pm
Ok Many thanks
Think I liked the old version best, easier for users to use.
Give them to much choice and they get confused. :D
Phillip
Re: Usradar Problem
Post by Jachym » Mon Dec 04, 2017 10:25 pm
yes, the original version, however, was removed due to copyright so I do not recommend using it
