Hi all!
I moved my database to another dedicated server. Original server was running version 8.xx over windows, current one runs 5.7 over ubuntu.
Migration went ok.
MT updates the database, all fields are correctly stored, but no historical data i shown in steel gauges nor in station diary nor station climate, no where.
You can query the database outside of MT perfectly. I've rebuilt indexes (even changed from innodb to myisam), but no luck.
What am I missing?
The weather station is a self made, based on raspberry pi running my code an meteotemplate.
Thanks!
Database issue
Re: Database issue
Update:
Just noted that Station diary shows summary data, but not monthly details....
Re: Database issue
SOLVED:
It was a configuration issued as described in this extract of a post:
You can try to disable the only_full_group_by setting by executing the following:
mysql> set global sql_mode='STRICT_TRANS_TABLES,NO_ZERO_IN_DATE,NO_ZERO_DATE,ERROR_FOR_DIVISION_BY_ZERO,NO_AUTO_CREATE_USER,NO_ENGINE_SUBSTITUTION';
mysql> set session sql_mode='STRICT_TRANS_TABLES,NO_ZERO_IN_DATE,NO_ZERO_DATE,ERROR_FOR_DIVISION_BY_ZERO,NO_AUTO_CREATE_USER,NO_ENGINE_SUBSTITUTION'
Re: Database issue
I had the same issue and this solved it. Thanks for posting!mholguin wrote: ↑Wed Jan 02, 2019 11:34 pm SOLVED:
It was a configuration issued as described in this extract of a post:Code: Select all
You can try to disable the only_full_group_by setting by executing the following: mysql> set global sql_mode='STRICT_TRANS_TABLES,NO_ZERO_IN_DATE,NO_ZERO_DATE,ERROR_FOR_DIVISION_BY_ZERO,NO_AUTO_CREATE_USER,NO_ENGINE_SUBSTITUTION'; mysql> set session sql_mode='STRICT_TRANS_TABLES,NO_ZERO_IN_DATE,NO_ZERO_DATE,ERROR_FOR_DIVISION_BY_ZERO,NO_AUTO_CREATE_USER,NO_ENGINE_SUBSTITUTION'
Re: Database issue
Glad it worked!
If you find a way to make this change permanent, as I have to run this whenever I have to restart the server...
