Plugin WLIP
PNCATTE
Software: WLIP
Plugin WLIP
Post by PNCATTE » Sat Jan 04, 2020 8:42 am
Two concerns with the WLIP plugins.
To retrieve the data from WL, add a line to the file: setting.php
$ tokenID = '3557167274C874BF09454634831031D5A';
and modify file wlIPupdate.php,
line 67 : $url = "https://api.weatherlink.com/v1/NoaaExt. ... ".$tokenID;
Another concern the gusts are not correct.
on weatherlink there are no bursts and meteotemplateLive.txt
what he records
{ "T" 5.9, "H": 93, "P": 1032.6, "B": 221, "W": 1609, "G": 4827, "R": 0.20066, "RR" 0, " S "0," U ": 1577901058," TIN ": 22.2," HIN ": 38," SW ":" Wlip "," TTIME ": 1577901105," HTime ": 1577901105," ptime ": 1577901105," btime ": 1577901105," WTIME ": 1577901105," gtime ": 1577901105," RTime ": 1577901105," RRTime ": 1577901105," sTime ": 1577901105," utime ": 1577901105," TINTime ": 1577901105," HINTime " : 1577901105, "SWTime": 1577901105, "D": 4.8 "dTime": 1577901105, "A" 4.4 "atime": 1577901105}
modify the file:
In your file ..plugins \ WIIP \ wlIPupdate.php,
you have the link between the database fields and the xml tags of the weatherlink API:
For Gust you should have:
$ rawUpdate ['G'] = floatval ($ xml-> wind_mph) * 1.609; // km / h
which you can replace with:
Line 80 ; $ rawUpdate ['G'] = floatval ($ xml-> davis_current_observation-> wind_ten_min_gust_mph) * 1.609; // km / h
You have to put the cron on 1 minute, so that the maximum burst is recorded since they recorded in alldata every five minutes.
I attach the modified files thanks to the forum which allowed me to make this plugin work properly
Best wishes
wlIP.zip
(4.11 KiB) Downloaded 661 times
fredericowessel
Re: Plugin WLIP
Post by fredericowessel » Fri Sep 11, 2020 7:47 pm
I did the modifications and updated archives in two of my templates. One is updating perfectly. Whe I access the cronjob link, the result is "Authorized via admin passwordSuccess".
My other template, is not updating. Admin password, update password and WL password are correct and when I access the cron job link, the result is a blank page. If I try a wrong password, the result is "Unauthorized".
I can't figure out whats wrong.
Re: Plugin WLIP
Post by Jachym » Sun Sep 13, 2020 9:58 am
I prepared a second version of this plugin that uses the API v2. The problem however is that rain does not work and when I did some research I found this is a bug in the WL API. The reported rain is always null.... it has been discussed by other developers on other forums, not much we can do... it is in this form unusable.
fredericowessel
Re: Plugin WLIP
Post by fredericowessel » Mon Sep 14, 2020 12:11 pm
But with the changes suggested here, the plugin works perfectly, in my case, in the template that is updating, including rain.
The template that is not updating. Could have relation, that are two diffent accounts? The template that is updating is a Pro account and the other one, that's not working, isn't a pro.
Re: Plugin WLIP
Post by Jachym » Tue Sep 15, 2020 12:22 pm
Hi Frederico,
I cannot tell because I do not use WL...
psper
Station model: Davis Vue
Software: Weather
Re: Plugin WLIP
Post by psper » Wed Oct 21, 2020 11:14 am
With this WPPI plugin changes I can query Weatherlink now.
This is a new format, with apiToken parameter and user is not username but device ID DID.
Thanks for your help!!!!!
But now I receive this from WeartherLink :
https://api.weatherlink.com/v1/NoaaExt. ... XXXXXXXXXX
Only information about Wind, but all data with zeros?
My station is working because I can see updates on my page.
I need more than BASIC Subscription?
Thanks in advance!!!
<current_observation xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.0" xsi:noNamespaceSchemaLocation="http://www.weather.gov/view/current_observation.xsd">
<credit>Davis Instruments Corp.</credit>
<credit_URL>http://www.davisnet.com</credit_URL>
<disclaimer_url>http://www.davisnet.com/about/terms.asp</disclaimer_url>
<copyright_url>http://www.davisnet.com/about/terms.asp</copyright_url>
<privacy_policy_url>http://www.davisnet.com/about/privacy.a ... policy_url>
<image>
<url>http://www.weatherlink.com/images/Logo_ ... u.jpg</url>
<title>Davis WeatherLink</title>
<link>http://www.weatherlink.com</link>
</image>
<suggested_pickup>15 minutes after the hour</suggested_pickup>
<suggested_pickup_period>60</suggested_pickup_period>
<location>São Gião, Coimbra, Portugal</location>
<latitude>40.34014</latitude>
<longitude>-7.80519</longitude>
<observation_time>Last Updated on Oct 21 2020, 11:09 am WEST</observation_time>
<observation_time_rfc822>Wed, 21 Oct 2020 11:09:07 +0100</observation_time_rfc822>
<station_id>psper</station_id>
<davis_current_observation>
<DID>001D0A712194</DID>
<station_name>São Gião</station_name>
<observation_age>0</observation_age>
<rain_day_in>0.0000</rain_day_in>
<rain_month_in>0.0000</rain_month_in>
<rain_rate_day_high_in_per_hr>0.0000</rain_rate_day_high_in_per_hr>
<rain_rate_hour_high_in_per_hr>0.0000</rain_rate_hour_high_in_per_hr>
<rain_rate_month_high_in_per_hr>0.0000</rain_rate_month_high_in_per_hr>
<rain_rate_year_high_in_per_hr>0.0000</rain_rate_year_high_in_per_hr>
<rain_storm_in>0.0000</rain_storm_in>
<rain_year_in>0.0000</rain_year_in>
</davis_current_observation>
<time_to_generate>0.364511 seconds</time_to_generate>
</current_observation>
