GFS
- captainjackfan10
- Station model: Acurite Atlas
- Software: WU
GFS
I am not having any luck with the GFS Block the Meteo works great! Just not so much with the GFS. Think it may need a tune-up.
Douglas E. Cobb
Come Join My Facebook Weather Group!
https://www.facebook.com/groups/6008536 ... =bookmarks
- Pavel
- Station model: TFA 35.1075 NEXUS
Re: GFS
Hi, GFS has some problems, does not show the map, the meteogram is probably rain as a sum of rainfall, others works GFS block normally, or is it just a mistake?
- captainjackfan10
- Software: WU
Re: GFS
Working Great Now! Thanks! The Problem Was Corrected!
Douglas E. Cobb
- Pavel
Re: GFS
hello, your progress does not help when I look at your site, I see the same problem, the map is not displayed and the meteogram is not seeing individual precipitation, but the summary
- Station model: WS1001
- Software: WU
- Meteopomezia
- Station model: Davis Pro 2
- Software: Wview
Re: GFS
- al60
- Station model: Vantage Pro 2
Re: GFS
Hello,Meteopomezia wrote: ↑Fri May 08, 2020 3:58 pm Hello everyone
I have been noticing for a few days that the GFS block no longer works on what it can depend on
I have the same problem, the GFS block no longer displays anything.
Do you have an idea to solve this problem?
cordially
(Google translate)
- didoujm
- Software: WEATHER DISPLAY
Re: GFS
le programme fonctionne avec le site http://wxcharts.eu/php/get_gfs.php?days=10&lat ça fonctionne plus l'adresse wxcharts.eu Ce site est inaccessible Impossible de trouver l'adresse IP du serveur de wxcharts.eu.
Essayez d'exécuter les diagnostics réseau de Windows.
DNS_PROBE_FINISHED_NXDOMAIN.
Par contre le site https://www.wxcharts.com/ fonctionne correctement
- al60
Re: GFS
the site http://www.wxcharts.eu/ no longer works it has been removed. The https://wxcharts.com site works well.
http://www.wxcharts.eu must be replaced by https://wxcharts.com in the gfsBlock.php files and in gfsBlockTable.php using note ++ using the replace function.
Jachym, if you read us, can you update the gfs block. Thank you
Have a good day
(google translate)
Have a good day
(google translate)
- Jolumarali
- Station model: Vantage Vue
- Software: WlIP
Re: GFS
Perfect everything works
thank you
Merci
thank you
Merci
OS : Windows 10 Famille
- Meteopomezia
- Software: Wview
Re: GFS
Hello to all friends solved the gfs block now displays the map and the link removed eu and put .com
now the maps are visible almost all, in some countries some cards may not work, for italy they all work.
it will be very difficult to correct because the GFS number changes,
I hope to solve this too.
For the moment, enjoy these changes.
I'm italian sorry school english.
greetings: D: D: D
The only problem is that the WXcharts site creates images only on request
for example if you click on wind speed then you will also see it on the gif block.
I hope to solve ...
greetings: D: D: D
I hope to solve ...
- gfs.zip
- Vers. 2.0
- (10.61 KiB) Downloaded 74 times
- Station model: Davis VP2
Re: GFS
J'ai remplacé l'adresse de wxcharts mais ça ne marche pas. Ni graphs ni carte. Je vois que chez toi il te manque la carte aussi.al60 wrote: ↑Wed May 13, 2020 8:47 am the site http://www.wxcharts.eu/ no longer works it has been removed. The https://wxcharts.com site works well.
Have a good day
(google translate)
- al60
Re: GFS
[/quote]
[/quote]
J'ai signalé le problème à Jachym, je pense qu'une mise à jour va pas tarder à arriver. Pour ce qui est des cartes, Meteopomezia essai de résoudre le problème.
[/quote]
- Jolumarali
- Software: WlIP
Re: GFS
Bonjour
Version Meteopomezia, fonctionne parfaitement chez moi. (map idem)
Traduction Infos en français
Voir sur mon sous-menu graphique interactif
Ci joint mon block
Portez-vous bien
Ci joint mon block
Portez-vous bien
- gfs.7z
- (13.44 KiB) Downloaded 60 times
- Pavel
Re: GFS
Thanks for fixing GFS, but I'm not satisfied yet, it still shows a summary of the rain, but not individual precipitation, as it was in the past, see the picture. Could it still be fixed? Thank you very much.
- al60
Re: GFS
Merci beaucoup, celà fonctionne trés bien graphiques et carte.Jolumarali wrote: ↑Mon May 18, 2020 5:50 am Bonjour
Ci joint mon block
Portez-vous bien
Re: GFS
Oui, tout fonctionne, merci !al60 wrote: ↑Mon May 18, 2020 3:35 pmMerci beaucoup, celà fonctionne trés bien graphiques et carte.Jolumarali wrote: ↑Mon May 18, 2020 5:50 am Bonjour
Ci joint mon block
Portez-vous bien
