Page 5 of 7
Re: Android App Brainstorming
Posted: Mon Jan 22, 2018 6:56 pm
by nitrx
polbrieuc wrote: ↑Mon Jan 22, 2018 5:05 pm
nitrx wrote: ↑Mon Jan 22, 2018 4:39 pm
I've no bug crashes except when I push the bugs button
then the app stops Galaxy S5 android 6
Yep, found a bug in the leftmenu preparation.
Just to confirm : it crashes when you click on the left menu option "Report a Bug", right ? You never get to see the actual dialog displayed ?
The dialog is displayed but when I want to send it stops I'll try the new app later.
good luck
Posted: Mon Jan 22, 2018 8:12 pm
by nitrx
The latest app crashes too on my Phone and tablet when i try to send a bugreport
Posted: Mon Jan 22, 2018 8:29 pm
by polbrieuc
nitrx wrote: ↑Mon Jan 22, 2018 8:12 pm
Ok, thanks for taking the time to test. I'll continue to search the root cause and try to get a fix.
Posted: Tue Jan 23, 2018 5:24 pm
by polbrieuc
Hello all,
I keep searching for the issue in the bug report.
I would need your help : please download the app through
this link , install it, run the app and try to send a bug report (all while connected to internet)
I do expect it to crash but it should also send me the line in the code where the exception ocurred.
Thanks again for your time.
Cheers,
Pol-Brieuc
Posted: Tue Jan 23, 2018 6:06 pm
by ON1GL
send you 3 reports, first (tablet crashed) second and third (P9) did NOT crash
Posted: Tue Jan 23, 2018 6:26 pm
by nitrx
Crash dont know if you ve the report
Posted: Wed Jan 24, 2018 2:12 pm
by polbrieuc
Thanks to all of you who are testing and help to fix issues.
I published
version 0.4.3 that should fix the issue when reporting a bug on some platforms and also display a dialog when internet connection is not available( you can turn on/off the airplane mode on your device to test it).
Next steps, along with bug fixing, will be to work on notifications.
Posted: Wed Jan 24, 2018 7:33 pm
by nitrx
Bug in bugreport fixed i think Just sent 2 testreports from my devices
Posted: Wed Jan 24, 2018 7:41 pm
by nitrx
Btw no internetconnection works fine oneens issue my Phone popups and says te app uses
A lot of power it recommends tot put te app in battery saving mode som i did no idea what thè influence is.
Posted: Thu Jan 25, 2018 1:46 pm
by polbrieuc
nitrx wrote: ↑Wed Jan 24, 2018 7:41 pm
The message about the app being put to sleep mode can be ignored for now. The current release is a debug release with lot of additional tasks/resources that won't be needed in a stable release. And in the end, the app does not consume that much power, it is just android thinking it does.
And regarding your bug report about the Dutch language, you were right, the "fl" code was applied instead of the "nl" code. (fl being probably
West Frisian). It will be corrected in the next release.
Posted: Thu Jan 25, 2018 1:56 pm
by nitrx
Great thanks for the feedback !
Posted: Sat Feb 17, 2018 12:03 pm
by nitrx
Is this project cancelled ?
Posted: Sat Feb 17, 2018 1:30 pm
by polbrieuc
nitrx wrote: ↑Sat Feb 17, 2018 12:03 pm
No, it is not cancelled at all.
It just happens that I have been busy and did not progress much in the last weeks.
Next update will include alerts (notifications) and the possibility to add as many blocks as you want in the left menu. And bug fixes, obviously.
Stay tuned...
Posted: Sat Feb 17, 2018 1:32 pm
by nitrx
Thanks for the feedback !
Posted: Thu Mar 01, 2018 11:14 pm
by ea7gt
I would be very pleased if you add my site
www.meteofrigiliana.com/eltiempo
Thanks in advance
Posted: Tue Mar 06, 2018 10:29 am
by polbrieuc
Hello Alejandro,
Your site has been added to the list of available sites in the app.
Do not hesitate to send me your feedback/comments/issues.
Cheers,
Pol-Brieuc
Posted: Tue Mar 06, 2018 5:10 pm
by meteoesine
I would be very pleased if you add my site too
www.meteoesine.it
many thanks in advance
Norbert
Posted: Wed Mar 07, 2018 11:33 pm
by ea7gt
Hola de nuevo.
Aprovecho para hablar en español ya que no me fijé que tú también lo eras.
Gracias por añadirme a la lista.
Independientemente de la app, que como has dicho está un poco parada por cuestiones de tiempo libre, ¿sería muy complicado hacer un widget que mostrara los datos actuales? Quizás actualizado cada 15 minutos... (o dejar la opción al usuario de poner el intervalo). Creo que sería una buena opción, muy interesante para muchos. Pinchando el widget podríamos ir directamente a la app para conocer más detalles e información.
Ahí queda la propuesta.
Saludos
Posted: Thu Mar 08, 2018 10:02 am
by polbrieuc
ea7gt wrote: ↑Wed Mar 07, 2018 11:33 pm
Hola de nuevo.
Saludos
Hi Alejandro,
Switching back to English so other members can participate to the conversation.
Your proposal of having a widget with the current data is great and I will definitely add it to the roadmap (most probaly using the current condition available in the left menu as a starting base).
This will come after notifications are implemented.
As I am pretty busy at my work (and want to save time for my family as well), development on the app is not as active as I wished it would but I will continue to make some time to progress.
In the meanwhile, please do continue to test the current functionnalities and report any issue you may face.
Cheers,
Pol-Brieuc
Posted: Sat Mar 10, 2018 10:19 am
by ea7gt
polbrieuc wrote: ↑Thu Mar 08, 2018 10:02 am
Hi Alejandro,
Cheers,
Pol-Brieuc
I will speak English in future posts
I also have no time in last weeks so I didn´t test the app yet. I will install again in my new phone and start testing. Don´t worry about the app progress, it´s a voluntary work so we can´t demand you anything.
I don´t know if you knows the meteoclimatic widget. It´s no longer available in the store, but I imagine (I don´t Know you) something similar (o perhaps better) and I am sure a lot of meteoclimatic users that also uses meteotemplate and miss old meteoclimatic app would download your app.
Thanks for your job
Posted: Fri Aug 24, 2018 5:03 pm
by ugo.call
I can participate too
www.meteofermo.it
Thanks in advance
Posted: Wed Aug 29, 2018 7:13 pm
by magical46
Hi, I haven't been on the forum for a while and must have missed this thread, liking it very much. Please could you add my site to the list
www.philsweather.co.uk
Phil
Posted: Sat Sep 01, 2018 6:10 pm
by Michael
What is the current status of the project?
Michael
Posted: Mon Sep 17, 2018 10:51 am
by polbrieuc
Hi ugo.call,
Your site has been added to the app.
magical46 wrote: ↑Wed Aug 29, 2018 7:13 pm
Phil
Hi Phil,
Your site has been added to the app but the mobile version (which is displayed in the app) is currently returning an error.
Michael wrote: ↑Sat Sep 01, 2018 6:10 pm
Michael
Hi Michael,
There has been no progress in the last months but I plan to restart developments beginning of October.
Next feature will be configurable notifications (rain alarm, temp thresold, etc...)
Cheers,
Pol-Brieuc
Posted: Sat Oct 13, 2018 6:08 pm
by polbrieuc
I just published version 0.5 of the App with notifications included.
You can find it
my dev page
Remember to also download the plugin if your site is part of the beta testers.
I'll put more details in a future post (I have to build some documentation around the App and the Plugin) but the new feature is Notifications, allowing to send notifications triggerred by events on your station (or on your site in general).
[Edit] For notifications to work, you will need to install the additional plugin Triggers (download it
here, see instructions
here)
Have fun testing and finding bugs and do not forget to report any issue.
Cheers,
Pol-Brieuc
PS : For those who have their site available in the App, when you modify something in the App Plugin, do not forget to clean the cache in the App (Settings/Data&Sync) to see your modifications in the app. If you are adding Notifications, also go to Settings/Notifications to check the notifications manually.
