Auto-updates
- Météo Daoulas
- Station model: WS-2800-IT
Re: Auto-updates
Hi Jachym,
The Auto Update works perfectly but I no longer use it because it systematically overwrites the changes made.
jmcafee
- Software: Meteohub
Re: Auto-updates
Hey Jachym,
Your summary of why the updates aren't working does not include the PHP ZIP option issue that several of us have posted. Could this be more central to the issue than users report (not knowing about it or how to fix)?
Re: Auto-updates
Can anyone confirm, that blocks with "icons" folder dont install with this folder? It looks like they dont, in which case it is not working for anyone
- dmgould
Re: Auto-updates
Jachym:
I just tried an auto install of the block Social Networks as a trial for you on the icons folder. I can confirm that for this block the icons folder did not download / install. Here is a snip from my ftp program after the auto install.
- socialnetworkssnip.JPG (18.69 KiB) Viewed 31650 times
Re: Auto-updates
OK, well that makes the decision easier I guess
BlueBear
- Station model: Davis VP2
- Software: WeeWx
Re: Auto-updates
I just tried to auto-install the Australia current conditions block and it too was missing the icon directory!
Bill
Bill
hcorrin
Re: Auto-updates
According to the info.php in my template folder the zip is enabled on the version of PHP I have on my hosts shared server this also means I am do not have access to alter anything, so I will have to manage with manual block and plugin updates
N0BGS
- Software: Cumulus MX
Re: Auto-updates
Jachym:
In the past I received update notifications but since my site is running SSL and yours isn't I could not automatically download them. That problem seems to have now been resolved.
Thanks,
--Kurt
Thanks,
--Kurt
Re: Auto-updates
OK, I think I made up my mind... a compromise:
block/plugin update - will remain and unfortunately not work for some. It works for the majority and saves a lot of work, so I will keep it.
block auto-installation - will be removed because it is not working correctly for anyone
Weerstation Afferden
- jay_hoehn
- Language Admin
- Software: WeeWx
Re: Auto-updates
Jachym,
A great compromise. I have really liked the auto-update of the blocks and plugins. Makes it very easy. I hope you can get it worked out for all.
Jay
Jay
Re: Auto-updates
Hi Jay,
Im afraid this isnt technically possible, some providers block my provider and vice versa, or they have ZIP file handling disabled, and the user has no way to enable it. So I cannot help those who have this problem no matter what I do.
- dmgould
Re: Auto-updates
I agree that it's a good compromise. Either way I stand behind whatever Jachym decides.
Re: Auto-updates
If anyone wants to give a try to a modified test script for block installation (which should install icons folder too), drop me an email
- wxthomson
Re: Auto-updates
I was getting a blank screen until I went to my cPanel and did what crayleb did.crayleb wrote: ↑Mon Oct 02, 2017 4:16 am No - now Yes. Godaddy hosting. Mine wasn't working - it was giving me a 500 Internal Server Error. My site is running PHP version 7.1. It was downloading the ZIP file fine but wasn't extracting it. I've since found that in cPanel I can turn on the ZIP file functionality in PHP. But now working perfectly.
Now, both blocks and plugins are working perfectly
Re: Auto-updates
Bug fix package released.
Fixes the issue with block installation and the updates will remain in the template, although not working for all. If it did not work for you before, it probably will not even after this fix.
hcorrin
Re: Auto-updates
just put the bug fix on
then I checked for block and plugin updates and saw interactivegraph block had one so I thought worth a try expecting it to fail as before, but to my surprise it updated ok checked the folder on the server and it had 3 updated files in as it should (files now have todays date)
Harold
Harold
Re: Auto-updates
hi,
good, it might help some, unfortunately I know for some this will not solve the problem
Brandon Barometer
- iatros
- Language Admin
Re: Auto-updates
No block update so far for me, but diary update to 4.0 worked fine from within Plugin setup page (Despite of https !!)
- Reinhard
- Station model: Davis VP2 Pro wireless
- Software: WeatherCat
Re: Auto-updates
Done the bugfix-update but no newer blocks and plugins available. But while V16 worked from the beginning for me I have no doubt that it will still work after the bugfix-package.
cw3beck
Re: Auto-updates
Installed the bug fixes and now the Block and Plugin auto update both appear to be working.
- Fraggboy
- Software: Bloomsky
Re: Auto-updates
After installing the bug fix, it's working as expected. At first it didn't work. Upon further investigation, it was downloading the zip file, but not going further.
For my issue, the permissions weren't correct on the folders. After modifying the permissions, the plugin update worked nicely (There isn't a block update for me to test yet).
Re: Auto-updates
Looking good
