Re: Meteotemplate - process of updating
Posted: Wed Aug 23, 2023 3:37 pm
Thank you!
no idea why this gone missing suddenly, maybe just me....
Official Forum for Meteotemplate weather website template.
http://www.meteotemplate.com/forum/
<?php
# Meteotemplate
# http://www.meteotemplate.com
# Free website template for weather enthusiasts
# Author: Jachym
# Brno, Czech Republic
# First release: 2015
# v2.0 2017-04-20 Now also handle data of update programs
# v2.1 2017-04-24 Handling of fallen rain between 23:55 and 00:00:00
# v2.2 2017-07-02 Added Extra sensors; fixed bug rain at begin of day
# v3.0 2017-08-11 Added multipliers
# v3.1 2017-12-20 Discard outdated parameters; added mysql error logging
//error_reporting(E_ALL);
$apiLog = array();
$rawInput = array();
$utc = time();
$timeId = "Time";
if(isset($apiUpdate)){
// api included by CUMULUS, WU, CUSTOM, NETATMO, WLIP
$rawUpdate['SW'] = $apiUpdate;
$apiLog['info'][] = "Handling data from ".$apiUpdate;
// load data
foreach ($rawUpdate as $key => $value) {
$rawInput[$key] = $value;
if($key == 'U'){
$apiLog['info'][] = "update 'U' = ".$rawInput['U']." (".date("Y-m-d H:i:s",$rawInput['U']).")";
else{
$apiLog['info'][] = "update '".$key."' = ".$rawInput[$key];
else{
// api section called by http
$base = "";
// load main info
require($base."config.php");
// load dependencies
require($base."scripts/functions.php");
// check acces authorization
if(isset($_GET['PASS'])){
$password = $_GET['PASS'];
else if(isset($_GET['PASSWORD'])){
$password = $_GET['PASSWORD'];
else{
die("No password provided");
// check if password is correct
if($password!=$updatePassword){
if($password==$adminPassword){ // if admin password provided accept, but notify
echo "Authorized via admin password";
else{
die("Unauthorized");
$apiLog['info'][] = "Authorized access.";
$apiLog['info'][] = "Current date/time: ".date("Y-m-d H:i:s");
$apiLog['info'][] = "api called by http";
// read raw input
if(isset($_GET)){
foreach($_GET as $urlParameter=>$value){
if($urlParameter!="PASSWORD" && $urlParameter!="PASS"){
$rawInput[$urlParameter] = $value;
$apiLog['info'][] = "update ".$urlParameter.": ".$value;
else{
// no data in api
$apiLog['error'][] = "api: no data";
generateAPILog();
die("api: no data");
// end of api section
// common part for both:
// apiUpdate section called by /update/update.php
$apiLog['info'][] = "Begin of common part of api script";
# HANDLING LIVE DATA
$apiLog['info'][] = "Start handling live data";
// Preset time of live update
foreach ($rawInput as $key => $value) {
$rawInput[$key.$timeId] = $utc;
// multipliers
if($multiplierT != 0 && isset($rawInput['T'])){
$rawInput["T"] = $rawInput["T"] + $multiplierT;
if($multiplierP != 0 && isset($rawInput['P'])){
$rawInput["P"] = $rawInput["P"] + $multiplierP;
if($multiplierW != 1 && isset($rawInput['W'])){
$rawInput["W"] = $rawInput["W"] * $multiplierW;
if($multiplierR != 1 && isset($rawInput['R'])){
$rawInput["R"] = $rawInput["R"] * $multiplierR;
if($multiplierW != 1 && isset($rawInput['G'])){
$rawInput["G"] = $rawInput["G"] * $multiplierW;
if($multiplierR != 1 && isset($rawInput['RR'])){
$rawInput["RR"] = $rawInput["RR"] * $multiplierR;
// Check if extra sensors should be loaded
$apiLog['info'][] = "Checking if extra sensors should be logged";
$extraSensors = array();
if(file_exists($base."update/apiSettings.txt")){
$extraAPIRaw = json_decode(file_get_contents($base."update/apiSettings.txt"),true);
foreach($extraAPIRaw as $extraParam=>$extraValue){
if($extraValue==1){
$extraSensors[] = $extraParam;
else{
$apiLog['info'][] = "Extra sensor settings file not found.";
$apiLog['info'][] = "Extra sensors data to save in db: " . implode(", ",$extraSensors);
// read previous live data
if(file_exists($base."meteotemplateLive.txt")){
// get latest date from cache file
$mtLive = file_get_contents($base."meteotemplateLive.txt");
$liveInput = json_decode($mtLive,true);
if(array_key_exists("R".$timeId,$liveInput)){ // check if rain is from yesterday, if so, delete it
$dayRain = date("Ymd",$liveInput['R'.$timeId]);
$dayNow = date("Ymd");
if($dayRain!=$dayNow){
unset($liveInput['R']);
unset($liveInput['RTime']);
foreach ($liveInput as $key => $value) {
$pos = strpos($key,$timeId);
if ($pos > 0) {
// time parameter
if($utc-$value > 600) {
// value more than 10 minutes ago; skip writing back
$apiLog['info'][] = "Variable too old, remove from meteotemplateLive.txt: ".$key.": ".date("Y-m-d H:i:s",$value);
$keyValue = substr($key,0,$pos);
// remove value and timestamp from array
unset($liveInput[$keyValue]); // remove value
unset($liveInput[$key]); // remove timestamp
else {
// value parameter
$liveInput[$key] = $value;
// convert UGP to P when needed
if(isset($rawInput['UGP']) && !isset($rawInput['P'])){
$apiLog['info'][] = "convert UGP: ".$rawInput['UGP'];
// get station elevation from config
// $stationElevation
// $stationElevationUnits - m/ft
// define constants for SLP calculations
// convert elevation to m if in ft
if($stationElevationUnits=="ft"){
$elevationM = $stationElevation * 0.3048;
else{
$elevationM = $stationElevation;
$apiLog['info'][] = "elevationM: ".$elevationM;
$apiLog['info'][] = "liveInput['T']: ".$liveInput['T'];
if(isset($liveInput['T'])){ // temperature is available, use more accurate formula
$temperatureK = $liveInput['T'] + 273.15; // temperature in K
$constant['g'] = 9.80665; // Earth-surface gravitational constant [m/s2]
$constant['M'] = 0.0289644; // molar mass of dry air [kg/mol]
$constant['R'] = 8.31447; // universal gas constant
$partA = ($constant['g'] * $constant['M'] * $elevationM) / ($constant['R'] * $temperatureK);
$convertedP = $rawInput['UGP'] / exp(- $partA);
$apiLog['info'][] = "more accurate convertedP: ".$convertedP;
else{ // temperature is N/A use less accurate formula
$convertedP = $rawInput['UGP'] - ($elevationM/9.2);
$apiLog['info'][] = "less accurate convertedP: ".$convertedP;
$rawInput['P'] = (string)(round($convertedP,3));
$rawInput['P'.$timeId] = $utc;
$apiLog['info'][] = "calculated P: ".$rawInput['P'];
// multiplier for converted UGP to P
// add saved live data fields for not updated fields
if(!isset($rawInput[$key])){
// if live data key not present use saved live data
// time fields ($rawInput[$key.$timeId]) will be copied too
$apiLog['info'][] = "add live data: ".$key.": ".$value;
// calculate dewpoint
$rawInput['D'] = (string)dewpoint($rawInput['T'], $rawInput['H']);
$rawInput['D'.$timeId] = $utc;
$apiLog['info'][] = "calculated D: ".$rawInput['D'];
// calculate apparent temp
$rawInput['A'] = (string)apparent($rawInput['T'], $rawInput['H'], $rawInput['W'] / 3.6);
$rawInput['A'.$timeId] = $utc;
$apiLog['info'][] = "calculated A: ".$rawInput['A'];
// save raw input
$rawOutput = json_encode($rawInput,JSON_NUMERIC_CHECK);
$apiLog['info'][] = "Save meteotemplateLive.txt: ".$rawOutput;
file_put_contents($base."meteotemplateLive.txt",$rawOutput);
// check we have write permissions for the cache folder and meteotemplateLive.txt
if(!file_exists($base."meteotemplateLive.txt")){
$apiLog['error'][] = "meteotemplateLive.txt was not created! Probably incorrect permissions for the template root folder.";
echo "Live conditions file not created. Check permissions!";
# PARSING
$apiLog['info'][] = "Start data parsing";
$convertUgp = false;
// save live data fields to raw data
$rawData[$key] = $value;
// ESSENTIAL
// Date and time
$apiLog['info'][] = "Parsing date; Server time: ".date("Y-m-d H:i:s");
$valid['date'] = true;
if(!isset($rawData['U'])){
$valid['date'] = false;
$apiLog['error'][] = "No value for date specified.";
else{
// date must be passed as UNIX timestamp
// checking: date must be numeric, must be after 1990 and must not be in the future
$apiLog['info'][] = "Validating date: ".$rawData['U']." (".date("Y-m-d H:i:s",$rawData['U']).")";
if(is_numeric($rawData['U'])){
if($rawData['U']>631152000 && $rawData['U']<(time()+10*60)){ // 10 minutes tolerance
$data['timestamp'] = ($rawData['U']); // also save the timestamp
$data['date'] = date("Y-m-d H:i:s",$rawData['U']); // convert to MySQL accepted format
$apiLog['info'][] = "Date is valid; difference with server time is ".($rawData['U'] - $utc)." s" ;
else{
$apiLog['error'][] = "Date is invalid; difference with server time is ".($rawData['U'] - $utc)." s";
else{
$apiLog['error'][] = "Date is invalid (not numeric)";
// Parameters
// Outside Temperature
$apiLog['info'][] = "Parsing temperature";
$valid['T'] = true;
if(!isset($rawData['T'])){
$valid['T'] = false;
$apiLog['error'][] = "No temperature data provided.";
else{
$rawT = trim($rawData['T']);
$apiLog['info'][] = "Temperature: ".$rawT." C";
if($rawT===""){
$apiLog['error'][] = "Temperature field blank.";
elseif(!is_numeric($rawT)){
$apiLog['error'][] = "Temperature is not a number.";
// apply conversion - API uses Celsius
if($valid['T']){
$apiLog['info'][] = "Database units: ".$dataTempUnits;
if($dataTempUnits!="C"){
$rawT = convertor($rawT, "C", $dataTempUnits);
$apiLog['info'][] = "Temperature converted to: ".$rawT." ".$dataTempUnits;
// check limits
$apiLog['info'][] = "Checking temperature is between limits specified in template Main settings.";
$apiLog['info'][] = "Minimum temperature limit: ".$limitTempMin." ".$dataTempUnits;
$apiLog['info'][] = "Maximum temperature limit: ".$limitTempMax." ".$dataTempUnits;
if($rawT>=$limitTempMin && $rawT<=$limitTempMax){
$apiLog['info'][] = "Temperature is OK and within the allowed limits";
$data['T'] = $rawT;
else{
$apiLog['error'][] = "Temperature is outside the allowed limits.";
// Outside Max Temperature
$apiLog['info'][] = "Parsing maximum temperature";
$valid['Tmax'] = true;
if(!isset($rawData['TMX'])){
$valid['Tmax'] = false;
$apiLog['error'][] = "No max temperature data provided.";
else{
$rawTmax = trim($rawData['TMX']);
$apiLog['info'][] = "Max Temperature: ".$rawTmax." C";
if($rawTmax===""){
$apiLog['error'][] = "Max Temperature field blank.";
elseif(!is_numeric($rawTmax)){
$apiLog['error'][] = "Max Temperature is not a number.";
if($valid['Tmax']){
$rawTmax = convertor($rawTmax, "C", $dataTempUnits);
$apiLog['info'][] = "Temperature converted to: ".$rawTmax." ".$dataTempUnits;
// check limits
$apiLog['info'][] = "Checking max temperature is between limits specified in template Main settings.";
if($rawTmax>=$limitTempMin && $rawTmax<=$limitTempMax){
$apiLog['info'][] = "Max Temperature is OK and within the allowed limits";
$data['Tmax'] = $rawTmax;
else{
$apiLog['error'][] = "Max Temperature is outside the allowed limits.";
// Outside Min Temperature
$apiLog['info'][] = "Parsing minimum temperature";
$valid['Tmin'] = true;
if(!isset($rawData['TMN'])){
$valid['Tmin'] = false;
$apiLog['error'][] = "No min temperature data provided.";
else{
$rawTmin = trim($rawData['TMN']);
$apiLog['info'][] = "Min Temperature: ".$rawTmin." C";
if($rawTmin===""){
$apiLog['error'][] = "Min Temperature field blank.";
elseif(!is_numeric($rawTmin)){
$apiLog['error'][] = "Min Temperature is not a number.";
if($valid['Tmin']){
$rawTmin = convertor($rawTmin, "C", $dataTempUnits);
$apiLog['info'][] = "Temperature converted to: ".$rawTmin." ".$dataTempUnits;
// check limits
$apiLog['info'][] = "Checking min temperature is between limits specified in template Main settings.";
if($rawTmin>=$limitTempMin && $rawTmin<=$limitTempMax){
$apiLog['info'][] = "Min Temperature is OK and within the allowed limits";
$data['Tmin'] = $rawTmin;
else{
$apiLog['error'][] = "Min Temperature is outside the allowed limits.";
// Humidity
$apiLog['info'][] = "Parsing humidity";
$valid['H'] = true;
if(!isset($rawData['H'])){
$valid['H'] = false;
$apiLog['error'][] = "No humidity data provided.";
else{
$rawH = trim($rawData['H']);
$apiLog['info'][] = "Humidity: ".$rawH." percent";
if($rawH===""){
$apiLog['error'][] = "Humidity field blank.";
elseif(!is_numeric($rawH)){
$apiLog['error'][] = "Humidity is not a number.";
if($valid['H']){
// discard nonsense
if($rawH<0 && $rawH>100){
$apiLog['error'][] = "Humidity is outside sensible range (0-100%).";
else{
// check limits from main settings
$apiLog['info'][] = "Checking humidity is between limits specified in template Main settings.";
$apiLog['info'][] = "Minimum humidity limit: ".$limitHumidityMin." %";
$apiLog['info'][] = "Maximum humidity limit: ".$limitHumidityMax." %";
if($rawH>=$limitHumidityMin && $rawH<=$limitHumidityMax){
$apiLog['info'][] = "Humidity is OK and within the allowed limits";
$data['H'] = $rawH;
else{
$apiLog['error'][] = "Humidity is outside the allowed limits.";
// Wind Speed
$apiLog['info'][] = "Parsing wind speed";
$valid['W'] = true;
if(!isset($rawData['W'])){
$valid['W'] = false;
$apiLog['error'][] = "No wind speed data provided.";
else{
$rawW = trim($rawData['W']);
$apiLog['info'][] = "Wind speed: ".$rawW." kmh";
if($rawW===""){
$apiLog['error'][] = "Wind speed field blank.";
elseif(!is_numeric($rawW)){
$apiLog['info'][] = "Wind speed is not a number.";
// apply conversion - API uses km/h
if($valid['W']){
$apiLog['info'][] = "Database wind speed units: ".$dataWindUnits;
if($dataWindUnits!="kmh"){
$rawW = convertor($rawW, "kmh", $dataWindUnits);
$apiLog['info'][] = "Wind speed converted to: ".$rawW." ".$dataWindUnits;
// discard nonsense
if($rawW<0){
$apiLog['error'][] = "Wind speed cannot be negative.";
else{
// check limits
$apiLog['info'][] = "Checking wind speed is between limits specified in template Main settings.";
$apiLog['info'][] = "Minimum wind speed limit: ".$limitWindMin." ".$dataWindUnits;
$apiLog['info'][] = "Maximum wind speed limit: ".$limitWindMax." ".$dataWindUnits;
if($rawW>=$limitWindMin && $rawW<=$limitWindMax){
$apiLog['info'][] = "Wind speed is OK and within the allowed limits";
$data['W'] = $rawW;
else{
$apiLog['error'][] = "Wind speed is outside the allowed limits.";
// Wind Gust
$apiLog['info'][] = "Parsing wind gust";
$valid['G'] = true;
if(!isset($rawData['G'])){
$valid['G'] = false;
$apiLog['error'][] = "No wind gust data provided.";
else{
$rawG = trim($rawData['G']);
$apiLog['info'][] = "Wind gust: ".$rawG." kmh";
if($rawG===""){
$apiLog['error'][] = "Wind gust field blank.";
elseif(!is_numeric($rawG)){
$apiLog['error'][] = "Wind gust is not a number.";
if($valid['G']){
$apiLog['info'][] = "Database wind units: ".$dataWindUnits;
$rawG = convertor($rawG, "kmh", $dataWindUnits);
$apiLog['info'][] = "Wind gust converted to: ".$rawG." ".$dataWindUnits;
// discard nonsense
if($rawG<0){
$apiLog['error'][] = "Wind gust cannot be negative.";
else{
// check limits
$apiLog['info'][] = "Checking wind gust is between limits specified in template Main settings.";
$apiLog['info'][] = "Minimum wind gust limit: ".$limitWindMin." ".$dataWindUnits;
$apiLog['info'][] = "Maximum wind gust limit: ".$limitWindMax." ".$dataWindUnits;
if($rawG>=$limitWindMin && $rawG<=$limitWindMax){
$apiLog['info'][] = "Wind gust is OK and within the allowed limits";
$data['G'] = $rawG;
else{
$apiLog['error'][] = "Wind gust is outside the allowed limits.";
// Wind direction (bearing)
$apiLog['info'][] = "Parsing wind direction";
$valid['B'] = true;
if(!isset($rawData['B'])){
$valid['B'] = false;
$apiLog['error'][] = "No wind direction data provided.";
else{
$rawB = trim($rawData['B']);
$apiLog['info'][] = "Wind direction: ".$rawB." degrees";
if($rawB===""){
$apiLog['error'][] = "Wind direction field blank.";
elseif(!is_numeric($rawB)){
$apiLog['error'][] = "Wind direction is not a number.";
if($valid['B']){
// discard nonsense
if($rawB<0 && $rawB>360){
$apiLog['error'][] = "Wind direction is outside sensible range (0-360 degrees).";
else{
$apiLog['info'][] = "Wind direction is OK and within the allowed limits";
$data['B'] = $rawB;
// Precipitation
$apiLog['info'][] = "Parsing daily cumulative precipitation";
$valid['R'] = true;
if(!isset($rawData['R'])){
$valid['R'] = false;
$apiLog['error'][] = "No precipitation data provided.";
else{
$rawR = trim($rawData['R']);
$apiLog['info'][] = "Precipitation: ".$rawR." mm";
if($rawR===""){
$apiLog['error'][] = "Precipitation field blank.";
elseif(!is_numeric($rawR)){
$apiLog['error'][] = "Precipitation is not a number.";
// apply conversion - API uses mm
if($valid['R']){
$apiLog['info'][] = "Database precipitation units: ".$dataRainUnits;
if($dataRainUnits!="mm"){
$rawR = convertor($rawR, "mm", $dataRainUnits);
$apiLog['info'][] = "Precipitation converted to: ".$rawR." ".$dataRainUnits;
// discard nonsense
if($rawR<0){
$apiLog['error'][] = "Precipitation cannot be negative.";
else{
// check limits
$apiLog['info'][] = "Checking precipitation is between limits specified in template Main settings.";
$apiLog['info'][] = "Minimum precipitation limit: ".$limitRainMin." ".$dataRainUnits;
$apiLog['info'][] = "Maximum precipitation limit: ".$limitRainMax." ".$dataRainUnits;
if($rawR>=$limitRainMin && $rawR<=$limitRainMax){
$apiLog['info'][] = "Precipitation is OK and within the allowed limits";
$data['R'] = $rawR;
else{
$apiLog['error'][] = "Precipitation is outside the allowed limits.";
// Rain rate
$apiLog['info'][] = "Parsing rain rate";
$valid['RR'] = true;
if(!isset($rawData['RR'])){
$valid['RR'] = false;
$apiLog['error'][] = "No rain rate data provided.";
else{
$rawRR = trim($rawData['RR']);
$apiLog['info'][] = "Rain rate: ".$rawRR." mm/h";
if($rawRR===""){
$apiLog['error'][] = "Rain rate field blank.";
$apiLog['error'][] = "Rain rate is not a number.";
// apply conversion - API uses mm/h
if($valid['RR']){
$apiLog['info'][] = "Database rain units: ".$dataRainUnits."/h";
$rawRR = convertor($rawRR, "mm", $dataRainUnits);
$apiLog['info'][] = "Rain rate converted to: ".$rawRR." ".$dataRainUnits."/h";
// discard nonsense
if($rawRR<0){
$apiLog['error'][] = "Rain rate cannot be negative.";
else{
// check limits
$apiLog['info'][] = "Checking rain rate is between limits specified in template Main settings.";
$apiLog['info'][] = "Minimum rain rate limit: ".$limitRainRateMin." ".$dataRainUnits."/h";
$apiLog['info'][] = "Maximum rain rate limit: ".$limitRainRateMax." ".$dataRainUnits."/h";
if($rawRR>=$limitRainRateMin && $rawRR<=$limitRainRateMax){
$apiLog['info'][] = "Rain rate is OK and within the allowed limits";
$data['RR'] = $rawRR;
else{
$apiLog['error'][] = "Rain rate is outside the allowed limits.";
// Solar radiation
$valid['S'] = true;
if($solarSensor){
$apiLog['info'][] = "Parsing solar radiation";
if(!isset($rawData['S'])){
$valid['S'] = false;
$apiLog['error'][] = "No solar radiation data provided.";
else{
$rawS = trim($rawData['S']);
$apiLog['info'][] = "Solar radiation: ".$rawS." w/m2";
if($rawS===""){
$apiLog['error'][] = "Solar radiation field blank.";
elseif(!is_numeric($rawS)){
$apiLog['error'][] = "Solar radiation is not a number.";
if($valid['S']){
// discard nonsense
if($rawS<0){
$apiLog['error'][] = "Solar radiation cannot be negative.";
else{
$apiLog['info'][] = "Checking solar radiation is between limits specified in template Main settings.";
$apiLog['info'][] = "Minimum solar radiation limit: ".$limitSolarMin." W/m2";
$apiLog['info'][] = "Maximum solar radiation limit: ".$limitSolarMax." W/m2";
if($rawS>=$limitSolarMin && $rawS<=$limitSolarMax){
$apiLog['info'][] = "Solar radiation is OK and within the allowed limits";
$data['S'] = $rawS;
else{
$apiLog['error'][] = "Solar radiation is outside the allowed limits.";
else{
$apiLog['info'][] = "Solar radiation sensor disabled in Main settings - skipping.";
// EXTRA SENSORS
// Now parse extra sensors
if(count($extraSensors)>0){
$extraQueryParams = array();
$extraQueryValues = array();
$apiLog['info'][] = "Now parsing extra sensors.";
foreach($extraSensors as $extraSensor){
if($extraSensor == "TIN"){
$thisSensorName = "indoor temperature";
$thisSensorLimits = array(1,50);
$thisSensorUnits = "deg C";
$thisSensorDecimals = 1;
if($extraSensor == "HIN"){
$thisSensorName = "indoor humidity";
$thisSensorLimits = array(0.01,100);
$thisSensorUnits = "%";
if($extraSensor == "SN"){
$thisSensorName = "daily snowfall";
$thisSensorLimits = array(0,5000);
$thisSensorUnits = "mm";
$thisSensorDecimals = 0;
if($extraSensor == "SD"){
$thisSensorName = "snow depth";
$thisSensorLimits = array(0,10000);
if($extraSensor == "NL"){
$thisSensorName = "noise level";
$thisSensorLimits = array(0,200);
$thisSensorUnits = "dB";
if($extraSensor == "L"){
$thisSensorName = "lightning";
$thisSensorLimits = array(0,1000);
$thisSensorUnits = "";
if($extraSensor == "SS"){
$thisSensorName = "sunshine";
$thisSensorLimits = array(0,24);
$thisSensorUnits = "h";
if($extraSensor == "UV"){
$thisSensorName = "UV";
$thisSensorLimits = array(0,20);
//$for($g=1;$g<=4;$g++){
if($extraSensor == "T".$g){
$thisSensorName = "extra temperature sensor ".$g;
$thisSensorLimits = array(-60,60);
if($extraSensor == "H".$g){
$thisSensorName = "extra humidity sensor ".$g;
if($extraSensor == "TS".$g){
$thisSensorName = "soil temperature sensor ".$g;
$thisSensorLimits = array(-60,80);
if($extraSensor == "SM".$g){
$thisSensorName = "soil moisture sensor ".$g;
$thisSensorLimits = array(0.01,200);
if($extraSensor == "LT".$g){
$thisSensorName = "leaf temperature sensor ".$g;
if($extraSensor == "LW".$g){
$thisSensorName = "leaf wetness sensor ".$g;
$thisSensorLimits = array(0,15);
if($extraSensor == "CO2_".$g){
$thisSensorName = "CO2 sensor ".$g;
$thisSensorLimits = array(300,600);
$thisSensorUnits = "ppm";
if($extraSensor == "CO_".$g){
$thisSensorName = "CO sensor ".$g;
$thisSensorLimits = array(0.1,50);
if($extraSensor == "NO2_".$g){
$thisSensorName = "NO2 sensor ".$g;
$thisSensorLimits = array(0,10);
if($extraSensor == "SO2_".$g){
$thisSensorName = "SO2 sensor ".$g;
$thisSensorUnits = "ppb";
if($extraSensor == "O3_".$g){
$thisSensorName = "O3 sensor ".$g;
$thisSensorLimits = array(0,100);
if($extraSensor == "PP".$g){
$thisSensorName = "particulate pollution ".$g;
$thisSensorUnits = "ug/m3";
if(isset($rawData[$extraSensor])){
$thisSensorVal = $rawData[$extraSensor];
$apiLog['info'][] = "Sensor ".$thisSensorName." raw value: " . $thisSensorVal . " " . $thisSensorUnits;
$apiLog['info'][] = "Limits for this sensor: " . $thisSensorLimits[0] ." to " . $thisSensorLimits[1];
if($thisSensorVal >= $thisSensorLimits[0] && $thisSensorValue <= $thisSensorLimits[1] && is_numeric($thisSensorVal)){
$apiLog['info'][] = "Sensor data within acceptable limits.";
$extraQueryParams[] = $extraSensor;
$extraQueryValues[] = number_format($thisSensorVal, $thisSensorDecimals, ".", "");
else{
$apiLog['info'][] = "Sensor data outside acceptable limits or value invalid.";
else{
$apiLog['info'][] = "Sensor: ".$thisSensorName." not found in API file, skipping...";
else{
$apiLog['info'][] = "No extra sensors set to log to extra alldata table.";
// Create/load cache file
// first check how old the cache is, if it is older than 30 minutes delete it to prevent averaging current values with very old values when station offline
if(file_exists($base."cache/apiCache.txt")){
$cacheRaw = file_get_contents($base."cache/apiCache.txt");
$cache = json_decode($cacheRaw,true);
$latestCacheDate = $cache['timestamp'][count($cache['timestamp'])-1];
if (time()-$latestCacheDate > 60 * 30) {
unlink($base."cache/apiCache.txt");
$apiLog['info'][] = "Cache file is over 30 minutes old, deleting it.";
// cache file exists - i.e. it is valid, load it
$apiLog['info'][] = "Cached data loaded from cache/apiCache.txt.";
// cache file does not exist, create empty file
else{
$cache = array();
$apiLog['info'][] = "No cache file found, create empty file.";
// Check for partial data
// Check for partial data in cache when data is not present
$validCachedT = false;
// use cached data instead when present
if(count($cache['T']) > 0) {
$T = $cache['T'][count($cache['T'])-1];
$validCachedT = true;
$apiLog['info'][] = "Use cached Temperature for calculations: ".$T;
else {
if($valid['T']) {
$T = $data['T'];
$validCachedH = false;
if(count($cache['H']) > 0) {
$H = $cache['H'][count($cache['H'])-1];
$validCachedH = true;
$apiLog['info'][] = "Use cached Humidity for calculations: ".$H;
else {
if($valid['H']) {
$H = $data['H'];
$validCachedW = false;
if(count($cache['W']) > 0) {
$W = $cache['W'][count($cache['W'])-1];
$validCachedW = true;
$apiLog['info'][] = "Use cached Wind for calculations: ".$W;
else {
if($valid['W']) {
$W = $data['W'];
// Unadjusted gauge pressure
if(isset($rawData['UGP']) && !isset($rawData['P'])){
$convertUgp = true;
$apiLog['info'][] = "convert UGP: ".$rawData['UGP'];
else{
if($valid['T'] || $validCachedT){ // temperature is available, use more accurate formula
$apiLog['info'][] = "T: ".$T;
$temperatureK = $T + 273.15; // temperature in K
$convertedP = $rawData['UGP'] / exp(- $partA);
$rawData['P'] = (string)(round($convertedP,3));
else{ // temperature is N/A skip calculation
$apiLog['info'][] = "No valid temp, skip less accurate calculation ";
// Barometric pressure
$apiLog['info'][] = "Parsing pressure";
$valid['P'] = true;
if(!isset($rawData['P'])){
$valid['P'] = false;
$apiLog['error'][] = "No pressure data provided.";
else{
$rawP = trim($rawData['P']);
$apiLog['info'][] = "Pressure: ".$rawP." hpa";
if($rawP===""){
$apiLog['error'][] = "Pressure field blank.";
elseif(!is_numeric($rawP)){
$apiLog['error'][] = "Pressure is not a number.";
// apply conversion - API uses hectopascals
if($valid['P']){
$apiLog['info'][] = "Database pressure units: ".$dataPressUnits;
if($dataPressUnits!="hpa"){
$rawP = convertor($rawP, "hpa", $dataPressUnits);
$apiLog['info'][] = "Pressure converted to: ".$rawP." ".$dataPressUnits;
// check limits
$apiLog['info'][] = "Checking pressure is between limits specified in template Main settings.";
$apiLog['info'][] = "Minimum pressure limit: ".$limitPressureMin." ".$dataPressUnits;
$apiLog['info'][] = "Maximum pressure limit: ".$limitPressureMax." ".$dataPressUnits;
if($rawP>=$limitPressureMin && $rawP<=$limitPressureMax){
$apiLog['info'][] = "Pressure is OK and within the allowed limits";
$data['P'] = $rawP;
$apiLog['info'][] = "Pressure is valid.";
else{
$apiLog['error'][] = "Pressure is outside the allowed limits.";
// Calculations
// Dew point
// essential: valid temperature and valid humidity
$valid['D'] = true;
if(($valid['T'] || $validCachedT) && ($valid['H'] || $validCachedH)){
// convert temperature to Celsius if necessary
if($dataTempUnits=="F"){
$temperatureC = convertor($T,"F","C");
else{
$temperatureC = $T;
$rawDCelsius = dewpoint($temperatureC, $H);
// convert back to Farenheit if necessary
$rawD = convertor($rawDCelsius,"C","F");
else{
$rawD = $rawDCelsius;
$apiLog['info'][] = "Calculated dew point: ".$rawD." ".$dataTempUnits;
// just do some basic checking, but should be ok since T and H both valid
if(is_numeric($rawD) && $rawD!=="" && $rawD!=null && $rawD>-100 && $rawD<200){
$data['D'] = $rawD;
$apiLog['info'][] = "Dew point ok.";
else{
$apiLog['error'][] = "There is some problem with the calculated dew point value. Ignored.";
$valid['D'] = false;
else{
$apiLog['info'][] = "Temperature, humidity or both are not valid and dew point calculation is therefore skipped.";
// Apparent Temperature
// essential: valid temperature, valid humidity and valid wind speed
$valid['A'] = true;
if(($valid['T'] || $validCachedT) && ($valid['H'] || $validCachedH) && ($valid['W'] || $validCachedW)){
else{
$temperatureC = $T;
if($dataWindUnits!="ms"){
$windMS = convertor($W,$dataWindUnits,"ms");
else{
$windMS = $W;
$rawACelsius = apparent($temperatureC, $H, $windMS);
$rawA = convertor($rawACelsius,"C","F");
else{
$rawA = $rawACelsius;
$apiLog['info'][] = "Calculated apparent temperature: ".$rawA." ".$dataTempUnits;
// just do some basic checking, but should be ok since T, H and W both valid
if(is_numeric($rawA) && $rawA!=="" && $rawA!=null && $rawA>-100 && $rawA<200){
$data['A'] = $rawA;
$apiLog['info'][] = "Apparent temperature ok.";
else{
$apiLog['error'][] = "There is some problem with the calculated apparent temperature value. Ignored.";
$valid['A'] = false;
else{
$apiLog['info'][] = "Temperature, humidity, wind speed or their combination are not valid and apparent temperature calculation is therefore skipped.";
// Check db update / update db
$dbInterval = 300;
// check if cache file contain a record
if(isset($cache['timestamp']) && is_array($cache['timestamp'])){
if(count($cache["timestamp"]) > 0) {
// timeForUpdate calculated from timestamp of first cached data
$checkTimestamp = $cache["timestamp"][0];
$apiLog['info'][] = "End time for database update based on timestamp of first cache data: ".date("Y-m-d H:i:s",$checkTimestamp);
else {
// timeForUpdate calculated from timestamp of current data
$checkTimestamp = $data['timestamp'];
$apiLog['info'][] = "End time for database update based on timestamp of current data: ".date("Y-m-d H:i:s",$checkTimestamp);
else {
if($checkTimestamp % $dbInterval == 0) {
$timeForUpdate = $checkTimestamp; // $checkTimestamp is equal to end time of current archive period
else {
$timeForUpdate = floor($checkTimestamp / $dbInterval) * $dbInterval + $dbInterval; // end time of current archive period
$apiLog['info'][] = "Rounded end time for database update: ".date("Y-m-d H:i:s",$timeForUpdate);
$updateTime = false;
if($data['timestamp'] >= $timeForUpdate){
$updateTime = true;
if($data['timestamp'] == $timeForUpdate){
// addDataToCache - current record belongs to the current archive set
// Add current data set to cache
// only do something if we have a valid date
if($valid['date']){
// add current data set to either empty cache file or add to existing cache
$cache['timestamp'][] = $data['timestamp'];
$cache['date'][] = $data['date'];
if($valid['T']){
$cache['T'][] = $data['T'];
if($valid['Tmax']){
$cache['Tmax'][] = $data['Tmax'];
if($valid['Tmin']){
$cache['Tmin'][] = $data['Tmin'];
if($valid['H']){
$cache['H'][] = $data['H'];
if($valid['P']){
$cache['P'][] = $data['P'];
if($valid['W']){
$cache['W'][] = $data['W'];
if($valid['G']){
$cache['G'][] = $data['G'];
if($valid['B']){
$cache['B'][] = $data['B'];
if($valid['R']){
// rain is cumulative, yet we cache for newDay checks
$cache['R'][] = $data['R'];
if($valid['RR']){
$cache['RR'][] = $data['RR'];
if($valid['S']){
$cache['S'][] = $data['S'];
if($valid['D']){
$cache['D'][] = $data['D'];
if($valid['A']){
$cache['A'][] = $data['A'];
// extra parameters
if(count($extraQueryParams)>0){
for($j = 0; $j < count($extraQueryParams); $j++){
$cache[$extraQueryParams[$j]][] = $extraQueryValues[$j];
// if time for update, do the update
if($updateTime){
$apiLog['info'][] = "Time to update the database, preparing query.";
// create the column name array for db and values array and insert date
$db['parameters'][] = "DateTime";
$firstCacheDate = $cache['timestamp'][0];
$lastCacheDate = $cache['timestamp'][count($cache['timestamp'])-1];
$apiLog['info'][] = "Timestamp first cached record: ".date("Y-m-d H:i:s",$firstCacheDate);
$apiLog['info'][] = "Timestamp last cached record: ".date("Y-m-d H:i:s",$lastCacheDate);
$apiLog['info'][] = "Timestamp last received record: ".date("Y-m-d H:i:s",$data['timestamp']);
$apiLog['info'][] = "Timestamp new database record: ".date("Y-m-d H:i:s",$timeForUpdate);
// check if this update is at 00:00:00
$dayUpdateMin1 = date("Ymd",$timeForUpdate-1);
$dayUpdate = date("Ymd",$timeForUpdate);
if($dayUpdateMin1!=$dayUpdate){
// start of a new day at 00:00:00
$newDay = true;
else {
$newDay = false;
$db['fields'][] = "'".date("Y-m-d H:i:s",$timeForUpdate)."'";
// average temperature
if(isset($cache['T'])){
$db['parameters'][] = "T";
// take temperature average and convert to db units
$rawValue = array_sum($cache['T'])/count($cache['T']);
$db['fields'][] = number_format($rawValue,1,".","");
// maximum temperature
if(isset($cache['Tmax'])){
$db['parameters'][] = "Tmax";
// take maximum temperature and convert to db units
$rawValue = max($cache['Tmax']);
else{ // if Tmax is not available see if T is and if so, use that
// take maximum and convert to db units
$rawValue = max($cache['T']);
// minimum temperature
if(isset($cache['Tmin'])){
$db['parameters'][] = "Tmin";
// take minimum temperature and convert to db units
$rawValue = min($cache['Tmin']);
else{ // if Tmin is not available see if T is and if so, use that
// take minimum and convert to db units
$rawValue = min($cache['T']);
// relative humidity
if(isset($cache['H'])){
$db['parameters'][] = "H";
// take humidity average
$rawValue = array_sum($cache['H'])/count($cache['H']);
// barometric pressure
// determine necessary number of decimal places for pressure
if($dataPressUnits=="inhg"){
$decimalsP = 2;
else{
$decimalsP = 1;
if(isset($cache['P'])){
$db['parameters'][] = "P";
// take pressure average
$rawValue = array_sum($cache['P'])/count($cache['P']);
$db['fields'][] = number_format($rawValue,$decimalsP,".","");
// wind speed
if(isset($cache['W'])){
$db['parameters'][] = "W";
// take wind average
$rawValue = array_sum($cache['W'])/count($cache['W']);
// wind gust
if(isset($cache['G'])){
$db['parameters'][] = "G";
// take wind gust maximum
$rawValue = max($cache['G']);
else{
// no gust data cached, take max wind speed instead
// take wind total
$rawValue = max($cache['W']);
// wind bearing
if(isset($cache['B'])){
$db['parameters'][] = "B";
// take wind bearing average
$rawValue = avgWindUpdate($cache['B']);
$db['fields'][] = number_format($rawValue,0,".","");
// precipitation
// determine necessary number of decimal places for precipitation
if($dataRainUnits=="in"){
$decimalsR = 2;
else{
$decimalsR = 1;
if(isset($cache['R'])){
$db['parameters'][] = "R";
// take cumulative daily rain and round it to the desired number of decimals
// use max value for check and update of last days registration
$maxRain = number_format(max($cache['R']),$decimalsR,".","");
// use last value for other periods
$currentRain = number_format($cache['R'][count($cache['R'])-1],$decimalsR,".","");
// check if newDay
if($newDay){
$apiLog['info'][] = "First database record in new day; check rain values";
$previousRain = "";
// read previous rain from database
$queryRain = "SELECT DateTime, R FROM alldata ORDER BY DateTime DESC LIMIT 1";
$thisQuery = mysqli_query($con,$queryRain);
if(!$thisQuery){
$apiLog['error'][] = "Meteotemplate MySQL Error: ".mysqli_error($con)." with query: ".$queryRain;
else{
while($row = mysqli_fetch_array($thisQuery)){
// the previous daily rain is already rounded to the desired number of decimals
$previousRain = $row['R'];
$apiLog['info'][] = "previous rain=".number_format($previousRain,$decimalsR,".","")." maxRain=".number_format($maxRain,$decimalsR,".","");
if($previousRain != "" && $maxRain > $previousRain){
// save rain during last (5-minute) period of the day
$lastRain = $maxRain - $previousRain;
$apiLog['info'][] = "Last rain of this day=".number_format($lastRain,$decimalsR,".","");
$previousDate = $row['DateTime'];
$newQuery = "UPDATE alldata SET R=".$maxRain." WHERE DateTime='".$previousDate."'";
$otherQuery = mysqli_query($con,$newQuery);
if(!$otherQuery){
$apiLog['error'][] = "Meteotemplate MySQL Error: ".mysqli_error($con)." with query: ".$newQuery;
else{
$apiLog['info'][] = "The database is updated with the following query: ".$newQuery;
// reset total rain at start of new day
$currentRain = 0.0;
$apiLog['info'][] = "Reset rain at start of new day=".number_format($currentRain,$decimalsR,".","");
else{
$apiLog['info'][] = "No new day, currentRain=".number_format($currentRain,$decimalsR,".","");
$db['fields'][] = number_format($currentRain,$decimalsR,".","");
// rain rate
if(isset($cache['RR'])){
$db['parameters'][] = "RR";
// take rain rate average or maximum based on template settings
if($apiRRCalculation == "max"){
$rawValue = max($cache['RR']);
else{
$rawValue = array_sum($cache['RR'])/count($cache['RR']);
$db['fields'][] = number_format($rawValue,$decimalsR,".","");
// solar radiation
if($solarSensor){
if(isset($cache['S'])){
$db['parameters'][] = "S";
// take solar radiation average
$rawValue = array_sum($cache['S'])/count($cache['S']);
// dew point
if(isset($cache['D'])){
$db['parameters'][] = "D";
// take dew point average
$rawValue = array_sum($cache['D'])/count($cache['D']);
// apparent temperature
if(isset($cache['A'])){
$db['parameters'][] = "A";
// take apparent temperature average
$rawValue = array_sum($cache['A'])/count($cache['A']);
// calculations
$finalExtraParams = array();
$finalExtraValues = array();
if(isset($cache[$extraSensor])){
$finalExtraParams[] = $extraSensor;
$thisExtraVal = array_sum($cache[$extraSensor])/count($cache[$extraSensor]);
$finalExtraValues[] = $thisExtraVal;
// UPDATE!
// Check database connection
if (!$con) {
$apiLog['error'][] = "Unable to connect to MySQL";
$query = "
INSERT INTO alldata
(".implode(',',$db['parameters']).")
values (".implode(',',$db['fields'])."
$thisQuery = mysqli_query($con,$query);
if(!$thisQuery){
$apiLog['error'][] = "Meteotemplate MySQL Error: ".mysqli_error($con)." with query: ".$query;
else{
$apiLog['info'][] = "The database is updated with the following query: ".$query;
if(date("H")==0 && date("i") <= 10){
$thisQuery = mysqli_query($con,"ALTER TABLE alldata ORDER BY DateTime");
if(!$thisQuery){
$apiLog['error'][] = "Meteotemplate MySQL Error: ".mysqli_error($con)." with query: ALTER TABLE alldata ORDER BY DateTime";
// perform query to alldataExtra if some params are available
if(count($finalExtraParams)>0){
$finalExtraParams[] = "DateTime";
$finalExtraValues[] = "'".date("Y-m-d H:i:s",$timeForUpdate)."'";
$apiLog['info'][] = "Preparing extra sensor query...";
$queryExtra = "
INSERT INTO alldataExtra
(".implode(',',$finalExtraParams).")
values (".implode(',',$finalExtraValues).")
$thisQuery = mysqli_query($con,$queryExtra);
if(!$thisQuery){
else{
$apiLog['info'][] = "The extra database table is updated with the following query: ".$queryExtra;
// only do this at 0:00-0:10
$thisQuery = mysqli_query($con,"ALTER TABLE alldataExtra ORDER BY DateTime");
if(!$thisQuery){
$apiLog['error'][] = "Meteotemplate MySQL Error: ".mysqli_error($con)." with query: ALTER TABLE alldataExtra ORDER BY DateTime";
// save latest results of cache and log
file_put_contents($base."cache/latestApiCache.txt",json_encode($cache));
if(!file_exists($base."cache/latestApiCache.txt")){
$apiLog['error'][] = "cache/latestApiCache.txt was not created! Probably incorrect permissions on the cache folder.";
// delete cache
$apiLog['info'][] = "Cache file deleted.";
if($data['timestamp'] > $timeForUpdate){
// addDataToCache - current record belongs to the next archive set
$cache = array();
if($valid['date']){
if($valid['T']){
if($valid['Tmax']){
if($valid['Tmin']){
if($valid['H']){
if($valid['P']){
if($valid['W']){
if($valid['G']){
if($valid['B']){
if($valid['R']){
if($valid['RR']){
if($valid['S']){
if($valid['D']){
if($valid['A']){
// extra sensors
$apiLog['info'][] = "Saving first new data to cache/apiCache.txt, timestamp=".date("Y-m-d H:i:s",$data['timestamp']);
file_put_contents($base."cache/apiCache.txt",json_encode($cache));
// create API update log file
$updateLog = "";
foreach($apiLog['info'] as $info){
$updateLog .= $info."\n\r";
$updateLog .= "\n\rERRORS:\n\r";
if(isset($apiLog['error'])){
foreach($apiLog['error'] as $error){
$updateLog .= $error."\n\r";
file_put_contents($base."cache/latestApiLog.txt",$updateLog);
// not yet time for update - just save updated cache file
else{
if($valid['date']){
if($valid['T']){
if($valid['Tmax']){
if($valid['Tmin']){
if($valid['H']){
if($valid['P']){
if($valid['W']){
if($valid['G']){
if($valid['B']){
if($valid['R']){
if($valid['RR']){
if($valid['S']){
if($valid['D']){
if($valid['A']){
// extra sensors
if(isset($extraQueryParams) && is_array($extraQueryParams)){
$apiLog['info'][] = "Not yet time to update the db, saving new data to cache/apiCache.txt";
$apiLog['info'][] = "Generating log file cache/apiLog.txt";
$updateLog = "";
file_put_contents($base."cache/apiLog.txt",$updateLog);
if($convertUgp){
file_put_contents($base."cache/apiLogConvertUgp.txt",$updateLog);
// return success status to caller
echo "Success";
// Functions
// Dew point calculation
// accepts temperature [C] and humidity [%]
// returns dew point [C]
function dewpoint($dewT,$dewH){
$calcD = round(((pow(($dewH/100), 0.125))*(112+0.9*$dewT)+(0.1*$dewT)-112),1);
return $calcD;
// Apparent temperature calculation
// accepts temperature [C], humidity [%], wind speed [m/s]
// returns apparent temperature [C]
function apparent($apparentT,$apparentH,$apparentW){
$e = ($apparentH/100)*6.105*pow(2.71828, ((17.27*$apparentT)/(237.7+$apparentT)));
$calcA = round(($apparentT + 0.33*$e-0.7*$apparentW-4),1);
return $calcA;
// Average wind bearing
// accepts wind directions as an array and data as number between 0 and 360
function avgWindUpdate($directions) { // based on http://en.wikipedia.org/wiki/Yamartino_method
$sinSum = 0;
$cosSum = 0;
foreach ($directions as $value) {
$sinSum += sin(deg2rad($value));
$cosSum += cos(deg2rad($value));
return ((rad2deg(atan2($sinSum, $cosSum)) + 360) % 360);
function generateAPILog(){
global $apiLog;
global $base;
// create log and exit update script
$updateLog = "";
}I received the file directly from Jachym, but it is the same as the one he posted in this thread. (I compared the two files with Notepad++)alexvanuxem wrote: ↑Fri Aug 25, 2023 8:37 am to be clear, the api.php that Jachym shared only in code here a few posts above?
justinhow wrote: ↑Fri Sep 01, 2023 5:51 pm Hi all,
I have just done the upgrade from 18 to 19 and PHP 7.x to PHP 8.23.
As far as I can see after a quick look most of the site is still working OK, EXCEPT the Steelseries Gauges plugin (4.0) is no longer working (all showing 0/min). This still works on my site if I run under PHP 7 but not if I run under PHP 8.2.
Any ideas?
Justin
PS Thanks Jachym - great work!
The database not updating has returned for me. The new api file initially fixed the problem, but the database stopped updating on 9/1/23 at 3AM. The Current block is still updating as normal.
