Auto-updates
Luc
Software: WeeWX
Re: Auto-updates
Post by Luc » Mon Oct 02, 2017 8:48 am
PaulMy wrote: Mon Oct 02, 2017 3:37 am I tried it and worked. But I prefer to download to computer and then FTP as I like to have a copy on my computer.
Paul
The auto update leaves the downloaded zip files on your local server.
So you would have the best of both worlds!
soend
Re: Auto-updates
Post by soend » Mon Oct 02, 2017 8:50 am
Ok
WessexWeather
Re: Auto-updates
Post by WessexWeather » Mon Oct 02, 2017 10:02 am
OK, although only used it once to update a plugin so far.
Simon (WessexWeather)
Re: Auto-updates
Post by Jachym » Mon Oct 02, 2017 10:17 am
If it works once it will work. If it doesnt work, it never works.
I made a test with one user with https and even that wont help.
Robert
Station model: davis vantage vue
Software: meteohub
Re: Auto-updates
Post by Robert » Mon Oct 02, 2017 10:18 am
Ok for Plugins and Blocks
sensei
Station model: TFA Nexus
Software: Weewx
Re: Auto-updates
Post by sensei » Mon Oct 02, 2017 10:20 am
OK!
bianco57
Station model: Davis Vp2 PLUS
Software: Meteobridge Proi
Re: Auto-updates
Post by bianco57 » Mon Oct 02, 2017 10:26 am
+1 update Blocks/Plugins ok for me just a small bug for "dbInfo" ... date posted on 01.01.70 (scenn) Thnx
Davis Pro 2+ * SEREMANGE ERZANGE FR57
by MeteoTemplate
http://valdefench57sgz.franceserv.com/m ... esktop.php
by Infoclimat StatIC FR
http://www.infoclimat.fr/observations-m ... 000T5.html
Will
Station model: Davis pro 2
Software: Weather display
Re: Auto-updates
Post by Will » Mon Oct 02, 2017 10:42 am
Ok for Plugins and Blocks ;)
Torjan
Station model: Davis pro 2, WMR 300
Software: Weather Display, Meteobri
Re: Auto-updates
Post by Torjan » Mon Oct 02, 2017 10:43 am
Hi!
OK
Re: Auto-updates
Post by Jachym » Mon Oct 02, 2017 11:34 am
bianco57 wrote: Mon Oct 02, 2017 10:26 am +1 update Blocks/Plugins ok for me just a small bug for "dbInfo" ... date posted on 01.01.70 (scenn) Thnx
This is not a bug, this means you have one "null" record at the beginning of the database, you need to delete it.
jorgbj
Software: Netatmo
Re: Auto-updates
Post by jorgbj » Mon Oct 02, 2017 11:43 am
No, it doesn't work.
Use HTTPS and webspace at "one,com"
Re: Auto-updates
Post by Jachym » Mon Oct 02, 2017 11:53 am
jorgbj wrote: Mon Oct 02, 2017 11:43 am No, it doesn't work.
In your case it is most likely because of the https, https servers in general dont load ZIP files from http servers, probably not an issue with provider in this case.
stuee
Station model: OCwmr300
Software: WeatherDisplay
Re: Auto-updates
Post by stuee » Mon Oct 02, 2017 11:59 am
Ok, Block and plugin. thanks
jay_hoehn
Software: WeeWx
Re: Auto-updates
Post by jay_hoehn » Mon Oct 02, 2017 1:15 pm
Jachym,
I just updated to version 16 and the update went flawlessly. There was one plugin and one block to update and the automatic update worked perfectly. I'm sorry others are having issues with the auto updates, it is great. I hope it can be saved.
Thanks again for a great update.
Jay
SteveWx
Station model: Davis Vue
Re: Auto-updates
Post by SteveWx » Mon Oct 02, 2017 1:18 pm
Tested OK.
Fraggboy
Software: Bloomsky
Re: Auto-updates
Post by Fraggboy » Mon Oct 02, 2017 2:38 pm
Jachym wrote: Mon Oct 02, 2017 11:53 am
In my environment, I had to enabled certain PHP extensions. ZIP (and CURL) is not normally enabled by default. YMMV in how you enabled the extensions.
Re: Auto-updates
Post by Jachym » Mon Oct 02, 2017 2:47 pm
Thats one possibility, although in case of https, they usually never allow this to load from http simply due to security reasons.
bianco57
Re: Auto-updates
Post by bianco57 » Mon Oct 02, 2017 3:33 pm
Jachym wrote: Mon Oct 02, 2017 11:34 am This is not a bug, this means you have one "null" record at the beginning of the database, you need to delete it.
Thnx for the information
actually i have the mention "1970" ?!
to avoid making a stupid, how do I have to do for delete ?
by MeteoTemplate
Re: Auto-updates
Post by Jachym » Mon Oct 02, 2017 3:41 pm
Go to the Edit Data page and click some random date in the calendar. Then in the URL you will see the date you chose in the calendar. Replace it with the 1 Jan 1970 and then delete the nonsense row
bianco57
Re: Auto-updates
Post by bianco57 » Mon Oct 02, 2017 3:49 pm
;) ok Jachym thnx solved
by MeteoTemplate
Reinhard
Software: WeatherCat
Re: Auto-updates
Post by Reinhard » Mon Oct 02, 2017 4:28 pm
I am an HTTPS user, too. And it works. ;)
yamiacaveman
Software: Weather Display,Meteotemp
Re: Auto-updates
Post by yamiacaveman » Mon Oct 02, 2017 5:23 pm
Auto update to 16 fine, cannot update auto plugins, clicking on the symbol for the plugin a new blank screen comes up and no other action.
http://www.ace-host.net/
yamiacaveman
Re: Auto-updates
Post by yamiacaveman » Mon Oct 02, 2017 5:30 pm
Ok, so I went into my c-panel and went under PHP selector and checked the PHP extention box that said zip and all works find now --- Updated the plugins.
Fraggboy
Software: Bloomsky
Re: Auto-updates
Post by Fraggboy » Mon Oct 02, 2017 5:41 pm
yamiacaveman wrote: Mon Oct 02, 2017 5:30 pm Ok, so I went into my c-panel and went under PHP selector and checked the PHP extention box that said zip and all works find now --- Updated the plugins.
Yay!! I'm glad enabling the zip extension worked for you. :)
BTW- I have noticed that these extensions aren't enabled (By default) if you use http, or https.
iquebecs58
Re: Auto-updates
Post by iquebecs58 » Mon Oct 02, 2017 7:29 pm
ok
Météorologue amateur/ amateur meteorologist: Steven Villeneuve
St-Alphonse-de-Caplan, Gaspésie
Station WU: IQUEBECS58
CoCoRaHS : CAN-QC-5
CWOP : E1397
Facebook/Twitter : Météo St-Alphonse
Site: www.meteostalphonse.com
Site foudre/Lightning site :www.meteostalphonse.com/nexstorm/StormS ... tation.htm
Courriel/Email: info@meteostalphonse.com
