Page 4 of 7
Re: Auto-updates
Posted: Mon Oct 02, 2017 8:48 am
by Luc
PaulMy wrote: ↑Mon Oct 02, 2017 3:37 am
I tried it and worked. But I prefer to download to computer and then FTP as I like to have a copy on my computer.
Paul
The auto update leaves the downloaded zip files on your local server.
So you would have the best of both worlds!
Re: Auto-updates
Posted: Mon Oct 02, 2017 8:50 am
by soend
Ok
Re: Auto-updates
Posted: Mon Oct 02, 2017 10:02 am
by WessexWeather
OK, although only used it once to update a plugin so far.
Re: Auto-updates
Posted: Mon Oct 02, 2017 10:17 am
If it works once it will work. If it doesnt work, it never works.
I made a test with one user with https and even that wont help.
Re: Auto-updates
Posted: Mon Oct 02, 2017 10:18 am
by Robert
Ok for Plugins and Blocks
Re: Auto-updates
Posted: Mon Oct 02, 2017 10:20 am
by sensei
OK!
Re: Auto-updates
Posted: Mon Oct 02, 2017 10:26 am
by bianco57
+1 update Blocks/Plugins ok for me just a small bug for "dbInfo" ... date posted on 01.01.70 (scenn) Thnx
Re: Auto-updates
Posted: Mon Oct 02, 2017 10:42 am
by Will
Re: Auto-updates
Posted: Mon Oct 02, 2017 10:43 am
by Torjan
Hi!
OK
Re: Auto-updates
Posted: Mon Oct 02, 2017 11:34 am
bianco57 wrote: ↑Mon Oct 02, 2017 10:26 am
This is not a bug, this means you have one "null" record at the beginning of the database, you need to delete it.
Re: Auto-updates
Posted: Mon Oct 02, 2017 11:43 am
by jorgbj
No, it doesn't work.
Use HTTPS and webspace at "one,com"
Re: Auto-updates
Posted: Mon Oct 02, 2017 11:53 am
jorgbj wrote: ↑Mon Oct 02, 2017 11:43 am
In your case it is most likely because of the https, https servers in general dont load ZIP files from http servers, probably not an issue with provider in this case.
Re: Auto-updates
Posted: Mon Oct 02, 2017 11:59 am
by stuee
Ok, Block and plugin. thanks
Re: Auto-updates
Posted: Mon Oct 02, 2017 1:15 pm
by jay_hoehn
Jachym,
I just updated to version 16 and the update went flawlessly. There was one plugin and one block to update and the automatic update worked perfectly. I'm sorry others are having issues with the auto updates, it is great. I hope it can be saved.
Thanks again for a great update.
Jay
Re: Auto-updates
Posted: Mon Oct 02, 2017 1:18 pm
by SteveWx
Tested OK.
Re: Auto-updates
Posted: Mon Oct 02, 2017 2:38 pm
by Fraggboy
Jachym wrote: ↑Mon Oct 02, 2017 11:53 am
In my environment, I had to enabled certain PHP extensions. ZIP (and CURL) is not normally enabled by default. YMMV in how you enabled the extensions.
- Extension.jpg (89.31 KiB) Viewed 31626 times
Re: Auto-updates
Posted: Mon Oct 02, 2017 2:47 pm
Thats one possibility, although in case of https, they usually never allow this to load from http simply due to security reasons.
Re: Auto-updates
Posted: Mon Oct 02, 2017 3:33 pm
by bianco57
- dbInfo.PNG (4.66 KiB) Viewed 31613 times
Jachym wrote: ↑Mon Oct 02, 2017 11:34 am
Thnx for the information
actually i have the mention "1970" ?!
to avoid making a stupid, how do I have to do for delete ?
Re: Auto-updates
Posted: Mon Oct 02, 2017 3:41 pm
Go to the Edit Data page and click some random date in the calendar. Then in the URL you will see the date you chose in the calendar. Replace it with the 1 Jan 1970 and then delete the nonsense row
Re: Auto-updates
Posted: Mon Oct 02, 2017 3:49 pm
by bianco57
ok Jachym thnx solved
Re: Auto-updates
Posted: Mon Oct 02, 2017 4:28 pm
by Reinhard
I am an HTTPS user, too. And it works.
Re: Auto-updates
Posted: Mon Oct 02, 2017 5:23 pm
by yamiacaveman
Auto update to 16 fine, cannot update auto plugins, clicking on the symbol for the plugin a new blank screen comes up and no other action.
http://www.ace-host.net/
Re: Auto-updates
Posted: Mon Oct 02, 2017 5:30 pm
by yamiacaveman
Ok, so I went into my c-panel and went under PHP selector and checked the PHP extention box that said zip and all works find now --- Updated the plugins.
Re: Auto-updates
Posted: Mon Oct 02, 2017 5:41 pm
by Fraggboy
yamiacaveman wrote: ↑Mon Oct 02, 2017 5:30 pm
Yay!! I'm glad enabling the zip extension worked for you.
BTW- I have noticed that these extensions aren't enabled (By default) if you use http, or https.
Re: Auto-updates
Posted: Mon Oct 02, 2017 7:29 pm
by iquebecs58
ok
