Extra Temp Sensor and Soil Block issues
Posted: Wed Jan 30, 2019 9:39 pm
by livefeed
I am having the hardest time getting the Extra Temp Sensor and Soil Blocks to read my data, nothing is displaying in the block but my api and meteotemplateLive.txt both see data, I must be doing something wrong, here are my settings.
- Screen Shot 2019-01-30 at 4.30.50 PM.png (291.59 KiB) Viewed 14894 times
- Screen Shot 2019-01-30 at 4.38.06 PM.png (282.96 KiB) Viewed 14894 times
Re: Extra Temp Sensor and Soil Block issues
Posted: Thu Aug 22, 2019 10:02 pm
by Michael
have you as Source in the Setting of the Soil Block the Entry "API" ?
Michael
Posted: Wed Jun 08, 2022 4:17 pm
by Oli
Quick side question because it fits the topic here:
Don't the values (dry soil, etc.) have to be exactly the opposite? So 0-10 very dry soil and 101-200 saturated soil?
Posted: Wed Jun 08, 2022 4:23 pm
by Gerrit
No, 0 is extremely wet, 200 is extremely dry.
Posted: Wed Jun 08, 2022 5:44 pm
by Oli
Okay, thanks, then it's just confusing with the ecowitt soil moisture sensor, which apparently transmits a percentage. I would then have to convert that accordingly.
Posted: Wed Jun 08, 2022 6:26 pm
If you use the ecowitt plugin to feed the meteotemplate database you can use the 'math' function to convert the 0-100 ecowitt range to the 200-0 'conventional' range
Posted: Thu Jun 09, 2022 8:06 am
by Oli
Yes, thank you. I have zero idea about php but this gives a view i am happy with:
<?php
$converted = 200 - ${"soilM".$i} * 2;
if(isset(${"soilM".$i})){
echo "<p>${"soilM".$i} Prozent</p>";
echo "<p> $converted Centibar </p>";
- feuchte.jpg (21 KiB) Viewed 12542 times
Posted: Sun Jun 12, 2022 5:41 am
by meteoesine
davidefa wrote: ↑Wed Jun 08, 2022 6:26 pm
interesting, pls kindly explain better how I should do it
thank you
Posted: Mon Jun 13, 2022 8:55 pm
For example you could define:
SM1=200-#SM1#*2 ( if you want to convert the soil moisture in 0-200 range, sorta cbar )
T5=#T1#-#T4# ( if you want to measure the difference to a reference sensor )
( to substitute a sensor value use the sensor name enclosed between two '#' chars )
In the 'math with sensor' input field you can use any function 'known by php' ( you can use even complex formulas, if needed )
Here I rescaled my two sensors:
- ecowitt_math.png (154.17 KiB) Viewed 12481 times
Posted: Mon Jun 13, 2022 11:35 pm
by meteoesine
Tnx a lot
Posted: Mon Apr 10, 2023 7:36 pm
by Julius
davidefa wrote: ↑Mon Jun 13, 2022 8:55 pm
Davide, you mention the math option. I would very much like to do
P+P1+P2+P3=P4/4=P5 and then show P5 as my all over average hPa value for our location. I have 4 sensors that all push to the api now. Is there some block that does this already, that you know of?
