meteobridge and meteotemplate
Is there a manual to setup the meteobridge? I no longer get this set in the meteobridge for meteotemplate.
- iatros
- Language Admin
Re: meteobridge and meteotemplate
Hi meteomw
login to: admin.meteobridge.com/xxxxxxxxx
Tab: Weather Network
at the bottom: add more weather networks, select meteotemplate
fill in interval, API URL (http://www.[your meteotemplate root folder]/api.php) and password
Done
Cheers, Martin
Done
Cheers, Martin
Thx Martin,
That is what I did but it do not work. I got the following message:
Error: Meteotemplate: https://www.meteomw.nl/template/api.php ... 9&PASS=<my password>: HTTPS support not compiled in.
I got also the error messages:
1) Error: Meteotemplate: OpenSSL: error:14077410:lib(20):func(119):reason(1040)
2)error:14077410:lib(20):func(119):reason(1040) Unable to establish SSL connection. (5 more tries, next in 5 secs)
On advice of Smarbedded (supplier meteobridge) changed http to https.
- iatros
- Language Admin
so you DID try http:// (instead of https://) ?
Hopefully Jachym happens to see this thread, he should be able to help you!
Thx for Your answer but both do not work
- Johnny
- Developer
Hi Meteomw, for what it's worth the image below is how mine is set up, sounds like and http or https issue, maybe someone else on the forum can point you in the right direction.
Thx Johnny, I have the same set-up only with my credentials and I also tried http and https. Nöt ing helps. Could it be a server problem?
I have added two screenshots, perhaps that gives more clarity about the problem. I have also been in contact with Smartbedded and they indicate that it is probably a problem at / home / openssl / wget-ssl, but the webhoster indicates that this directory does not exist. Does anyone know what's going on?
- mb 2.jpg (11.12 KiB) Viewed 7350 times
- mb.jpg (60.26 KiB) Viewed 7350 times
- meteoesine
- Station model: Davis Pro2+
- Software: Meteobridge nano
since last night I have the site offline for the same reason.
Please someone give us an answer to solve the problem, having accurate that it is not a hosting problem
thanks in advance
thanks in advance
- Asobig
- Software: Meteobridge (Red)
Boris has released an update with the following description:
"updates openssl and wget support on MR3020 and Meteobridge PRO platform to handle HTTPS targets that do no longer support SSL (but only TLS) due to security concerns. Previous error message "OpenSSL: Error ... reason(1040)" should be resolved by this."
Perhaps a reboot of your Meteobridge will help.
thanks for the tip! I had to reboot and the problem is solved! It was strange yesterday that I had contact with Smartbedded and they indicated that it was not their fault but the web host. Anyway the problem has been solved. thx.
