Hello Forum,
A new MeteoTemplate-User is born: In northern Germany, Schleswig-Holstein:
The private weather station Büdelsdorf is located in central Schleswig-Holstein, about 30 kilometres west of Kiel and about 100 kilometres north-northwest of Hamburg.
The landscape is shaped by the last Ice Age, whose glaciers formed the so-called Geest here: an area that is too hilly to the east with slightly permeable sandy soils. In the west, a striking ancient dune (the Geestrücken) separates this landscape structure from the wide and flat, heavy marshy soils of the west coast.
In Schleswig-Holstein, which is located on the Jutland peninsula, seasonal extremes of temperature are rare due to the proximity of the North Sea and Baltic Sea. Also winter snow and heavy thunderstorms are the exception. But there is usually a fresh breeze and windless days are almost seen as a speciality.
Used Station is a VantagePro2 Plus in combination with Meteobridge NANO SD
Have data since 2002-01-01, imported in MeteoTemplate.
Have a look if interested!
https://buedelsdorfwetter.de/template
New User Büdelsdorf Weather, North Germany
- Jolumarali
- Station model: Vantage Vue
- Software: WlIP
Re: New User Büdelsdorf Weather, North Germany
Hallo aus Frankreich.
Willkommen bei meteotemplate
xray77
Hello José Luis,
Thanks for your warmly welcome here!
I have visited your Homepage, very nice look and feel!
Have a Question: How have you worked it out to see the block "graphCombined" with different colors for temperature, humidity e.g.? I haven't found some settings in the block-settings for it, but it looks so much better as the default black or white line-color for all parameters... Can you give me a hint, what I must to do to see the different colors as like on your page?
Thank you and best regards
Mike
Mike
