Block Current
- amonphi
- Station model: Ecowitt GW1003
- Software: WU
Re: Block Current
I wanted to ask you, Currentblock Icons where do I put them on?
In the "Blocks/Current/Icons" directory there are 2 "dark" and "light" folders ... simply paste the "Currentblock Icons" folder inside "Icons"?
- meteoesine
- Station model: Davis Pro2+
- Software: Meteobridge nano
Re: Block Current
Yes, just it
if you are using only dark theme put them into 'dark' folder, or if you prefer on both folders
- Dehatter
- Station model: Ecowitt WH80
- Software: Ecowitt GW1000
Re: Block Current
I am having issues with current block 24.3 (maybe).
PHP 8.0 and 8.1 will not update when the template is in 'Administration' mode (password entered). PHP 7.4 works fine.
If I refresh the page, it will display the current API setting, but will not update based on the time entered in settings.
ssGauges continues to update and works fine (your version).
After you click logout, it seems to auto update. If this intended, then so be it, but the block updates on PHP 7.4 no matter the mode.
Also, and maybe it is just mine, but Meteobridge does not seem to deliver a consistent API update. I have it set for 30 secs, but sometimes it will not update for several minutes. I am running the Ecowitt setup with a service sending data directly to api.php with the Meteobridge info.
Re: Block Current
It should/could be a 'side effect' of the lightningew block ( as both blocks have a function with same name ). Try updating with this.
- lightningew_2.4.zip
- (86.83 KiB) Downloaded 53 times
- Dehatter
Re: Block Current
Yes, the block is updating now. It even seems way more consistent.
Thank you again.
Thank you again.
Re: Block Current
I've seen in your cache/apiCache.txt that the api.php calls are not at constant intervals ( as you say it stalls for a couple of minutes and then suddenly 3-4 calls are received in a few seconds ).
Not sure the cause, but you may try restarting the meteobridge ( or restarting the server if you have such an option )
- Dehatter
Re: Block Current
Do you see anything in my string that could be causing a problem?
/template/api.php?U=[epoch.1:]&T=[th0temp-lastval.1:]&TMX=[th0temp-max5:]&TMN=[th0temp-min5:]&H=[th0hum-lastval.1:]&P=[thb0seapress-lastval:1]&W=[wind0avgwind-lastval=kmh:1]&G=[wind0wind-lastval=kmh:1]&B=[wind0dir-lastval:1]&R=[rain0total-daysum:--]&RR=[rain0rate-lastval:1]&S=[sol0rad-lastval:2]&UV=[uv0index-lastval:1]&TIN=[thb0temp-lastval.1:]&HIN=[thb0hum-lastval.1:]&SM1=[th20hum-lastval.0:]&L=[lgt0total-dmax.0:]&LD=[lgt0dist-lastval.1:]<=[lgt0total-nonzerotime=epoch:]&PASS='password"
I just copied from Wx thread and pasted it, after removing the sensors I do not have.
Re: Block Current
Can anyone help me...why is the heat index and wind chill not showing any values...is it something i can fix ?
Leon.
Leon.
Re: Block Current
Wind chill is calculated only for T<=10°C and W>4.8km/h ( using this formula: https://en.wikipedia.org/wiki/Wind_chill )
Heat index is calculated only for T>=26.7°C ( using this formula: https://en.wikipedia.org/wiki/Heat_index )
- Station model: Ecowitt WS90
Re: Block Current
I just nothiced the same thing in my apiviewer plugin. Mine does the same, catches up and in a few minutes the time jumps back 3-4 min. Rebooting doesn't help. Not sure where to look for the cause.davidefa wrote: ↑Wed Aug 10, 2022 11:21 pm I've seen in your cache/apiCache.txt that the api.php calls are not at constant intervals ( as you say it stalls for a couple of minutes and then suddenly 3-4 calls are received in a few seconds ).
Re: Block Current
Ok I've pinned down one of my problems. It lies somewhere in the API.oho, Ecowitt plugin or the ecowitt block. Not sure which or where to look for the error. The apiview keeps changing from meteobridge and back to the ecowitt.net plugins it seems. It also changes time back a few min and stars over.If someone can look and see where this is it would be most helpful.
Which api.php ver, ecowitt block ver and ecowitt plug ver should I bee on to revieve date in meterbrdge only. I know I need one or other to revive lightningew to update correctly but going back and forth I seemed to trash the the thing.
Two or 3 of the blocks and plugins are bumping heads and I cant trace with is causing the errors. Sending to APRS don't function correctly.
- meteoesine
Re: Block Current
I think I solved the problem using only meteobridge events
removing Meteotemplate from the meteobridge weather nets and removing ecowitt (block and plugin) from MT.
my apiViewer: https://meteoesine.it/template/plugins/ ... /index.php
http event every minute
https://meteoesine.it/template/api.php?U=[epoch.1:]&T=[th0temp-lastval.1:]&TMX=[th0temp-max5:]&TMN=[th0temp-min5:]&H=[th0hum-lastval.1:]&P=[thb0seapress-lastval:1]&W=[wind0avgwind-lastval=kmh:1]&G=[wind0wind-lastval=kmh:1]&B=[wind0dir-lastval:1]&R=[rain0total-daysum:--]&RR=[rain0rate-lastval:1]&S=[sol0rad-lastval:2]&UV=[uv0index-lastval:1]&TIN=[thb0temp-lastval.1:] &PP0=[air0pm-lastval:2]&PP1=[air1pm-lastval:2]&PP2=[air2pm-lastval:2]&HIN=[thb0hum-lastval.1:]&SM1=[soil1hum-lastval.1:]&L=[lgt0total-dmax.0:]&LD=[lgt0distance-lastval.1:]<=[lgt0total-nonzerotime=epoch:]&PASS=xxx
- ScreenShot01144.jpg (34.8 KiB) Viewed 1974 times
- ScreenShot01143.jpg (69.05 KiB) Viewed 1977 times
- amonphi
- Software: WU
Re: Block Current
today I noticed that the icon of the "Current" block (at the top right of the same), has always remained the same (partly-cloudy-day) despite having been cloudy all night, it rained almost all morning (even if Very little but, continuously) and the sky has been covered until 11:30 am (as can be seen from the Time Lapse).
I would like to understand if that icon is part of the trends and if maybe I have to change something in the settings that, currently the trends is set out of 3.
Someone can explain to me how it works.
- meteoesine
Re: Block Current
I'm trying to add the missing trend arrows to solar and uv parameters, but without success
I trust in some willing and capable volunteers
Thank you in advance
- Screenshot - 19_02_2023 , 10_42_07.png (12.05 KiB) Viewed 907 times
