need some help with made a newblock
Posted: Sun Dec 31, 2023 11:03 am
by Weerstationwoerden
Hi to you all
I want to made a new block for the gauges op the top from my home page
I know the block gauges works ok but I want the put my one gauges
Like tis example https://www.weerstation-woerden.nl/mete ... basic.php
I have try to put that script into the blankBlock.php file but it will not work
The code is like this https://www.weerstation-woerden.nl/gaug ... c.php.txt
What do I wrong ?
Greetings Gert
Re: need some help with made a newblock
Posted: Sun Dec 31, 2023 3:55 pm
The 'steel series gauges' are already available as blocks and plugins for meteotemplate ( search for ssGauges ).
If you want to modify/customize the ssGauges block, I think is not a super easy task.
Last year, I compared the code on github from mcrossley and the code in meteotemplate: a huge number of differences ( I wanted to verify if I could update easily the block with the latest version on github, abandoned quickly the idea ).
Posted: Mon Jan 01, 2024 9:31 pm
Thanks for your help
it's works ok now
greetings Gert
