Font size - Block “current"
Posted: Thu Jul 25, 2024 3:41 pm
by El_Viejo
Version used 24.6
I have found that some templates use a larger font size for the sensor values than the default.
In the block settings I have not been able to find a way to achieve this.
What do I have to do to increase the font size of the sensor values?
Thanks in advance.
Re: Font size - Block “current"
Posted: Wed Aug 07, 2024 11:51 am
by didoujm
Bonjour
Il faut aller à la ligne 365:
<span class="mticon-temp conditionsIcon tooltip" alt='' title="<?php echo lang('temperature','c')?>"></span><br><?php if($showLabels){?><span class='currentLabel'><?php echo lang('temperature','c')?></span><br><?php } ?><span id="currentTValue" style='font-size: 1.3em'></span><br>°<?php echo $displayTempUnits?>.
je vous joins un exemple ci-dessus.
Il faut ajouter style='font-size:1.3em' pour agrandir la valeur température.
Amicalement didier
Posted: Thu Aug 08, 2024 3:56 pm
by El_Viejo
Thank you very much for your help.
In my version of the block it is line 345. In order not to rush and ruin my template, I will slowly review the changes to be made.
Merci beaucoup.
Posted: Fri Aug 09, 2024 3:17 pm
by El_Viejo
I just tried it and it doesn't work correctly. It adds another amount below the current temperature instead of increasing the font size.
What am I doing wrong?
Merci.
Posted: Fri Aug 09, 2024 4:28 pm
by MonyMony
I have modified the font size of the label on this block (see
www.cecilweather.com). In my case, I changed the value in line 317 for font-size:
.currentLabel{
font-size:0.6em;
font-variant: small-caps;
Other font sizes are in the style area of the code should you wish to make changes beyond what I did. To help, I am attaching my copy of the current block.php for you to do a comparison with. I hope it helps!
Posted: Sat Aug 10, 2024 2:59 pm
by El_Viejo
Thank you very much.
I will try it.
Posted: Mon Aug 12, 2024 4:12 pm
by El_Viejo
I have tried that file modification with different "font-size" and it does not work.
Tried in Chrome, Edge and Mozilla, with no result in increasing the size.
I'm stumped.
But, thanks for your interest.
Posted: Mon Aug 12, 2024 4:30 pm
by milesb
El_Viejo wrote: ↑Mon Aug 12, 2024 4:12 pm
I'm stumped.
I've had the same lack of success.
Posted: Mon Aug 12, 2024 11:08 pm
by lemimi
Here is what I get on my web page:
https://lemimi.fr/template/indexDesktop.php
If you are interested, the file can be downloaded here:
http://lemimi.fr/chargements/template/currentBlock.zip
Good luck... Michel
Posted: Tue Aug 13, 2024 7:49 am
by El_Viejo
Downloaded, I will try it.
Posted: Tue Aug 13, 2024 9:10 am
by El_Viejo
Tested and works.
Thank you all for your help.
