Steel Series Gauges Plugin - Help Please
Posted: Wed Dec 13, 2017 5:07 pm
by TreeBee
Hello All
I have managed to add in the Steel Series Gauges Plugin and created a link on the menu to view them, but I want the gauges to display in the header block at the top of the main page and because Im a full-time beekeeper and not a web guy Im struggling to make it work Im guessing it needs code?
I have tried adding in the #plugin(steelSeries) but that doesn't work.
Grateful for any help or advice you can give me.
Andy..
Re: Steel Series Gauges Plugin - Help Please
Posted: Wed Dec 13, 2017 5:42 pm
by weatherbee
You would have to download the block steel series gauges and then put the block in the header spot. The steel series gauges plug in and block are different.
Posted: Wed Dec 13, 2017 6:00 pm
by TreeBee
Hi Tom
Thank you and now that you have told me it seems so obvious, Im getting there slowly with the page setup :)
The gauges now display in a block template but will not work/display in the header block.
Andy..
Posted: Wed Dec 13, 2017 6:06 pm
Hi Andy, make sure you only include it in the header block. If it is also mentioned in your homepage main area it will not work. Each block must only be included once
Posted: Wed Dec 13, 2017 6:13 pm
by TreeBee
Hi Tom
I have worked it out, you only place the name space in the header as ssGauges with no other text or brackets.
Jachym had put in the instructions.
Thanks for your help.
Andy..
