Extra Sensors in Block StationData
Michael
- Station model: TE923
- Software: WEEWX
i think it would be nice if the values from Extra Sensors who stored in Table "alldataExtra" be appropriate in block StationData.
Michael
Michael
Re: Extra Sensors in Block StationData
I mentioned this in the past. Because I only had access to the standard set of sensors, I cannot test anything related to extra sensors. Making a realtime displayed value is relatively easy and you can simulate it, but for history data and statistics this is not possible.
Because of some not very good experience with programming something I cannot test (WxSim) I decided not to do it again.
Michael
- Software: WEEWX
Hi Jachym, if you want, I can provide you with my data.
akiro
- Station model: Davis Vantage 2 Pro
- Software: WeatherLink
I join Michael. It would be very interesting to display the additional sensors in the block station data or as a separate plugin for statistics purposes.
mchd17
davidefa, want to try and create this?
I would love to see extra sensors data in this block, such as Extra Temp/humidity sensors, etc
I think it can be done.
But how to graphically identify these new sensors? I mean each sensor is identified on the left side of the block by an icon, how to distinguish T1, T2...?
One simple ( not very appealing ) solution could be adding a number after the 'thermometer icon'.
Another solution could be draw all these new icons ( but I'm not able to do this )
Another solution could be using a short text ( clearer meaning but different look from standard sensors )
mchd17
you are correct, not very appealing
Years ago, and i mean years ago, i had photoshop. I will get back to you on this.
i think the short text would offset the block info
Have to rethink this
- added extra temperature/humidity and soil moisture
- icons are unchanged ( extra temperatures use same icon as temperature... )
- stationData_10.1c.zip
- (9.3 KiB) Downloaded 1167 times
nice!
added my indoor temp and indoor humidity to my station data.
thank you
even could add the parameter UV into it. In the moisture tab of the settings, it works to.
only the image of soil moisture is shown.
If you could add UV into it, that would be a nice to have.
Thanks again.
thank you
Thanks again.
mchd17
Thanks davidefa, great work!!
One issue found, new data shows up in C even though block says F
- corrected temperature conversion error
- supports any sensor in alldataExtra table ( UV, TIN, HIN, T#, H#, TS#, LT#, SM#, LW#, PP#, CO2_#... )
- redefined parameters ( re-run setup ):
- a single parameter define sensor names and units of measure
format: SM#=name=unit,... ( set unit to 'T' for temperature sensors, as it is used for conversion to the selected display unit )
example:
UV=UV=,T1=compost=T,SM1=tomatoes=%,PP1=PM2.5=ug/m3
example:
- stationData_10.2b.zip
- (9.35 KiB) Downloaded 1283 times
mchd17
Works very good!
Is it possible to get line break in between data?
- added break line
I looked at the block at least a hundred times without noticing the line break...
- stationData_10.3.zip
- (9.41 KiB) Downloaded 1126 times
mchd17
Maybe another issue....
"All time" from the drop down only shows today's date. Shouldn't that be all time records? There is a "today's date" option in the drop down.
Line Breaks look alot better.
- corrected 'alltime' data display
- stationData_10.4.zip
- (9.41 KiB) Downloaded 1665 times
mchd17
That was fast! I think that's a final!
Great work, coffee time!
- meteoesine
- Station model: Davis Pro2+
- Software: Meteobridge nano
stationData block
what I have to change to have only 1 decimal instead of 3 (Rain Rate mm/h)
thanks in advance
stationData block
thanks in advance
ver 10.7
- fix rain max number of decimal digits
- stationData_10.7.zip
- (9.72 KiB) Downloaded 1179 times
mchd17
Rain totals for month and year are not correct totals. Not certain about the other time options, 24hr, week, last 7 days, etc. That's before 10.7
- meteoesine
I noticed that selecting the various options of the period (last 365 days, overall summary, current day) displays only the data of the current year, while it should also show the previous years. The rain values seem correct
thanks in advance
thanks in advance
- meteoesine
you know what?
in the station data settings (last rel 10.7) if I leave the extra sensor field empty it displays the data of the previous years correctly, if I add UV it displays only the data of the current year
- ScreenShot01052.jpg (64.61 KiB) Viewed 72072 times
- meteoesine
Ciao Davide,
in riferimento al mio precedente post che se aggiungo un extra sensore mi fa vedere solo i dati inerenti al 2022, visto che a tutti funziona correttamente, hai qualche idea su cosa possa essere la causa del mio problema? svuotare la cache non risolve il problema (ora ho rimesso la vecchia versione - quella senza extra sensori).
Un'altra cosa: l'evapotraspirazione.
come si fa a generare e archiviare i dati sul database? per avere ET e fulmini nel /pages/station/climate.php?var= (ET /L) la modifica è già disponibile o è ancora in progress?
Ho appena ordinato il sensore wh51, dove trovo il blocco aggiornato ecowitt soil moisture?
grazie
grazie
- MeteoElMasnou
Neither with 10.4 nor 10.7 The historical data does not appear correctly. Has there been any update? Or is it my problem.
Good work.
Good work.
