Minimum windvalues' time?
Julius
- Software: meteobridge
I see the max values for Wind and Gust are mentioned with the measured time below the km/h values,
but the minimum values are not showing their last measured time. I would prefer it if they would.
This is the | Avg | Max | Min | table block, but I forgot its name.
Re: Minimum windvalues' time?
Ok, I think you refer to the Station Data block. I'll add this too ( I'm already modifying the block )
Julius
Did you get around to adding this? I already have installed Station Data 10.4, but it's not there yet. Perhaps because enough time has not passed yet?
TIA!
Sorry, for the delay... you can try this version:
- added wind/gust min time
- stationData_10.5.zip
- (9.63 KiB) Downloaded 947 times
Julius
Thanks! Only problem now is that it's no longer showing anything; What is the exact syntax for self coloring the speeds in block config?
I think you are referring to the windRose block:
- in 'speed definition' set the 'speed ranges' you want to define ( setting n values sets n+1 ranges )
- in 'define colors for each speed' set the n+1 colors ( one for each previously defined range )
Julius
WindRose no longer works..
Still doesn't change the way it looks for me. Still as the image I posted before. I see no legend, no colors. Any idea what could cause this? it's being tested heredavidefa wrote: ↑Wed Apr 27, 2022 8:00 pm I think you are referring to the windRose block:
It seems correct to me... there is something I don't understand.
Please post the windRose folder zipped so I can give it a try in my test setup.
You have an old version of the dataLoader.php ( homepage/blocks/windRose/dataLoader.php ) file.
Delete it and copy the attached one.
- dataLoader.zip
- (1.29 KiB) Downloaded 1278 times
Julius
Wow, thanks David! Really strange, I unpacked 1.4 in the windRose dir using midnight commander, but apparently not all files got overwritten..
- Jolumarali
- Station model: Vantage Vue
- Software: WlIP
Hello David
Would you have an idea for this difference in total annual rainfall on your stationdata10.5 version?
thank you
thank you
- stationdata.jpg (67.15 KiB) Viewed 44456 times
ver 10.6
- corrected rain data truncated to int values
- stationData_10.6.zip
- (9.35 KiB) Downloaded 1112 times
- Jolumarali
- Software: WlIP
Perfect, thank you Davide
