updated ecowittModules block
ver 1.4b
Minor update: corrected WS80, WS68 and WS65 sensor name
ver 1.4a
I have updated the ecowittModule block ( by raffaello Di Martino ) to include the following:
- updated the ecowitt sensor list
- match battery reports from the updated ecowitt module v2.6 or later
- added a couple of options to name the gateway and select the main wireless sensor
NOTE
To use this block you need to update the ecowitt plugin to v2.6 or later
NOTE1
The rf strength indication is 'fake', currently no rf reception level is reported by the sensors...
ver 1.4a
NOTE
NOTE1
- ecowittModules_1.4b.zip
- (4 KiB) Downloaded 1268 times
- ecowittModules_1.4a.zip
- (4 KiB) Downloaded 1158 times
Re: updated ecowittModule block
ver 1.4c
Minor update:
- corrected wh25, wh31, ws65 low battery indication ( it was 75% )
- added sensor name redefinition
Minor update:
- ecowittModules_1.4c.zip
- (4.08 KiB) Downloaded 1320 times
- Daali
- Station model: Ecowitt GW1002
- Software: Meteobridge, FOSHKplugin
Great work davidefa!
I have an ecowitt WN34S that shows up as TS1BAT. I haven't figured out the array yet to add it =). I can get it to the screen but with horrible batt and rf icons LOL.
TS1BAT = 73.4 Ecowitt.net shows 1.42v you can see I added * 0.055 to get close, but I have no idea what I am doing.
"WN34_1" => array("module_name" => "WN31_1", "battery_percent" => (99-$apiData['TS1BAT'] * 0.055), "set" => $apiData['TS1BAT'], "last_seen" => $apiData['U'], "data_type" => array("Temperature"), "firmware" => $firmware, "rf_status" => (117 - ($apiData['TS1BAT'] * 18)) ),
{"TS1":22.89,"TS1BAT":73.4,"TS1Time":1633998551,"TS1BATTime":1633998551,"StationTime":1633998551,"FWTime":1633998551}https://www.jeffersonweather.com
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
WH41 PM2.5 Air Quality
WH45 PM2.5/10/Co2 Air Quality
WN34S Soil temperature
WH31SM Soil Moisture
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
ver 1.5
- added support for wn34, wn34, wh40 and wn1900
- ecowittModules_1.5.zip
- (4.25 KiB) Downloaded 1309 times
Bashy
- Station model: Davis Vantage Pro2 plus
Hi, can this be used if you dont have a full Ecowitt station, i only have the GW1100 hub, outdoor AQ and Lightning, ideally i would like the AQ and Lightning to work, please? I have both the plugin and this block installed but nothing doing, its in the middle, 4th block down. i fear i may have missed something simple...
https://www.brecklandweather.com/meteo/indexDesktop.php
Yes, it should work.
In the ecowitt plugin set the fourth parameter ( Url of this site api.php script ) to:
As you can see in cache/ecowittLog.txt the relative path you are using fails ( Api result -> )
The only problem I see is that the gw1100 T/H/P sensors will mix with the existing ones.
To avoid this you can set the 'Rename sensors' parameter to:
P1=P;Tin1=Tin;Hin1=Hin
http://www.brecklandweather.com/meteo/api.phpCode: Select all
Api url -> /home/breckland/public_html/meteo/api.php?U=1648486487&P=1018.59&TIN=18.11&HIN=55&PP1=7.0&L=0&LD=5<=1645378640&PP1BAT=5&LBAT=5&Station=GW1100A&FW=V2.1.2
Api result ->
Forward1 ecowitt format
Forward1 url -> http://www.brecklandweather.com/pwsWD2021/ecowitt/
Forward1 nfields -> 17
Forward1 result -> 1To avoid this you can set the 'Rename sensors' parameter to:
ver 1.6
- added support for ws90
- battery voltage expressed in volts ( for those sensors reporting volts )
It is ( should be ) compatible with php 8.2
- ecowittModules_1.6.zip
- (4.51 KiB) Downloaded 1094 times
El_Viejo
Re: updated ecowittModules block
A few days ago I have installed a station is Ecowitt Wittboy GW 2001.
It seems to me that I have successfully configured the "ecowitt" plugin (V 3.5a), because the web page appears "online". However, the block "ecowittModules" (V 1.6) is offline.
In the image is my block configuration.
What am I doing wrong?
Please, forum experts help me to discover and correct my mistakes.
After the failure with the Netatmo plugin, I have been "fighting" with the new template configuration for several days.
Thanks in advance.
Thanks in advance.
- ecowittModules_01.png (63.69 KiB) Viewed 43428 times
- On_Off_01.png (43.29 KiB) Viewed 43428 times
- steph
- Software: Ecowitt gw1100/Raspberry
Personally, I've always stayed on 1.0 and never had a problem.
- Capture d'écran 2024-07-12 181226.png (113.79 KiB) Viewed 43407 times
El_Viejo
I am coming to the conclusion that my error is in the plugin configuration.
spd2612
- Software: Meteobridge Pro 2
Why does my signal meter stay red and at 0
All the other indicators are displaying i am using a Gw2000 with a WS90
spd2612
I removed it to many php 8.2 errors slowed my site and the percent meter stayed red at 0
- Station model: Ecowitt WS90
I don't know. I lost a bunch of symbols on mine when I just upgraded to PHP 8.2 from 8.1. My host won't let me go back to 8.1 now. My site counter broke also with 2-3 other blocks.
