Post install blank white screen
aswigon
Post by aswigon » Tue Nov 28, 2017 11:14 pm
Hi everyone. New to Meteotemplate and having a slight issue with the install process.
I have done a heap of reading / searching but can't find anything that matches my exact issue. I am no PHP guru so don't know the next place to look.
Post-install I am only getting a blank white screen. I enabled the error reporting functionality and got the following.
Warning: include(/home/myhomene/public_html/weather/meteo/scripts/functions.php): failed to open stream: No such file or directory in /home/myhomene/public_html/weather/meteo/header.php on line 48
Warning: include(): Failed opening '/home/myhomene/public_html/weather/meteo/scripts/functions.php' for inclusion (include_path='.:/opt/alt/php56/usr/share/pear:/opt/alt/php56/usr/share/php') in /home/myhomene/public_html/weather/meteo/header.php on line 48
Warning: include(/home/myhomene/public_html/weather/meteo/scripts/headerMetar.php): failed to open stream: No such file or directory in /home/myhomene/public_html/weather/meteo/header.php on line 49
Warning: include(): Failed opening '/home/myhomene/public_html/weather/meteo/scripts/headerMetar.php' for inclusion (include_path='.:/opt/alt/php56/usr/share/pear:/opt/alt/php56/usr/share/php') in /home/myhomene/public_html/weather/meteo/header.php on line 49
Fatal error: Call to undefined function lang() in /home/myhomene/public_html/weather/meteo/header.php on line 68
My page URL and path are configured correctly but for some reason it seems to be using the full host pathing. Have I done something wrong?
MySQL appears to be connecting correctly and I was able to create the base table.
PHP version = 5.6
Re: Post install blank white screen
Post by Jachym » Wed Nov 29, 2017 12:35 am
the full path is intentional and should work, do you use your own server or do you use external webhosting?
aswigon
Post by aswigon » Wed Nov 29, 2017 10:31 am
External hosting.
Post by Jachym » Wed Nov 29, 2017 10:50 am
I would first check the permissions and then if that does not help ask your provider
aswigon
Post by aswigon » Wed Nov 29, 2017 11:12 pm
Is there any recommendations on permissions requirements based on files / directories? I am assuming things like the config file and install folder should have different permissions to the main files?
aswigon
Post by aswigon » Thu Nov 30, 2017 12:47 pm
I scrapped the whole template folder and re-extracted. All working now so not sure what was going on.,
Now on to the customisation process!
Thanks for your help.
Post by Jachym » Thu Nov 30, 2017 1:17 pm
great, servers sometimes behave very oddly :D
