Wind gust speed in alldata is not the same as on the Davis Conole
iatros
Post by iatros » Thu Dec 14, 2017 4:22 pm
We quite a nice storm last night. My console shows 93 kmh at 4:25 am; whereas the alldata value at that moment is only 64.5 (I corrected this later manually).
How are 5-minutes-values of such highly variable measurements as wind gust speed calculated in alldata? Could those 93 kmh have been just a short peak which "escaped" ?
Martin
Language Admin für Deutsch
Re: Wind gust speed in alldata is not the same as on the Davis Conole
Post by Jachym » Thu Dec 14, 2017 5:43 pm
This is something we discussed here many times, my main question is - which software do you use?
If you use software which supports the API directly, this should not be happening, if you do not, then this is a consequence of the cron job interval
iatros
Post by iatros » Thu Dec 14, 2017 9:38 pm
Sorry, I did not realize there was such a discussion.
No software, just Meteobridge...
Post by Jachym » Thu Dec 14, 2017 11:27 pm
ok, that is strange, MB should be sending maximum value, not current value. Do you see the maximum in your MB control panel?
iatros
Post by iatros » Fri Dec 15, 2017 1:52 pm
yes, I do :
Screenshot-2017-12-15 Meteobridge.png (85.38 KiB) Viewed 5520 times
