plugin rain balance
pascalg21
Station model: Davis pro 2
Software: weatherlink ip
plugin rain balance
Post by pascalg21 » Thu Feb 01, 2018 3:07 pm
Capture d’écran 2018-02-01 à 15.59.30.png (59.77 KiB) Viewed 25151 times
Bonjour,
Comment est calculé le pourcentage (%)?? :?:
merci
Ken Good
Re: plugin rain balance
Post by Ken Good » Fri Feb 02, 2018 2:16 am
I would point out that the main set up file has a default setting of mm for the average rain settings. Soooo every time I go to the main file to make a change to something else, when I hit save, the rain setting gets changed back to mm from inches. This makes the readings on rain balance go out of wack ever time.
At least I know when I have made a change without realizing it. Ha!
Ken
acatalano
Software: CumulusMX
Post by acatalano » Sat Feb 03, 2018 3:36 pm
http://I've noticed the same thing. Many changes seem to be lost. I've entered the station average data several times already, as well as other values.
Best Regards,
Anthony Catalano
Boulder, CO
Websites: www.apcat.org www.boulderwx.com www.boulderweather.org
Blitzortung Lighting Detector Station 1965
Post by Jachym » Sun Jul 22, 2018 9:19 am
Hi Ken,
which setting/parameter exactly is not being saved, can you send me a screenshot? I checked the rain normals and units and it should be saved just like any other parameter.
weatherbee
Post by weatherbee » Sun Jul 22, 2018 1:04 pm
In the normal section of main setup it always reverts to mm, so if you change anything you have to remember to go to normal rain and pick in before you save.
Ken Good
Post by Ken Good » Sat Sep 01, 2018 10:22 am
Just to highlight this again, the choice defaults back to "mm" every time you make any other change. So if you want to make changes and you use "inches" in the history setting for temperature normals, you have to remember to change "mm" back to "in" because if you make any other change and press save, it defaults back to "mm."
Ken
