webcam plugin behaving strange
proger
Station model: davis vantage vue
Post by proger » Sat Aug 18, 2018 5:04 am
I suddenly got a problem with webcam plugin
My camera is sending photo every 10 minutes to the website.
but the plugin is only changing the photo every hour on the wecam plugin
Have a look at the thumbnails here http://www.auestadhome.com/template/plu ... /index.php
As you can see the photos are the same for every hour and a new photo next hour. And so on.
I cannot figure out what is going on since the camera and plugin has worked fine until the last month
Anyone else got this problem or can help me out here. Been working with it for days now
Re: webcam plugin behaving strange
Post by Johnny » Sat Aug 18, 2018 8:22 am
Hi Proger, that link is not working, "The requested URL /template/plugins/webcam/index.php was not found on this server"
proger
Post by proger » Sat Aug 18, 2018 8:55 am
Yes Sorry.
I am trying to delete the plugin and start over again.
also deleting all photos and database so will see if this is working
proger
Post by proger » Sat Aug 18, 2018 10:31 am
Well tried to set it up all over. But same behavier of the plugin.
Link in post over is working again.
If any one got suggestions it is more than welcome
EveshamWeather
Software: Weewx
Post by EveshamWeather » Sun Aug 19, 2018 1:27 pm
Is the image that gets uploaded actually changing? I have had it in the past where my upload was failing so Meteotemplate just added the same image to database every time it updated.
Vince
proger
Post by proger » Sun Aug 19, 2018 3:10 pm
Yes that is updating and being renamed.
you can see that here.
What is strange is that is is updating once pr hour
http://www.auestadhome.com/template/indexDesktop.php
Post by Dehatter » Mon Aug 20, 2018 2:48 am
Just being sure we do not overlook the obvious, but your image source in the plug-in set up is:
http://auestadhome.com/template/Webcamphoto/webcam2.jpg
Correct?
If so this has not updated since 21:56 August 19.
tom
proger
Post by proger » Mon Aug 20, 2018 7:29 am
Yes I have put correct URL in there.
If you study the 18 august you should see that the plugin only updates photos
every hour.
But the Camera is set to ftp every 500 second and the webcam block is updating every 500 second.
and this work fine.
I have also set the webcam plugin update interval to 500sec and save interval to the database to 10 min
What I wonder is the plugin reading from the downloaded photo from camera (the snap photo) or is it reading from
the renamed photo (webcam2.jpg) ?
on the website filemanager both these photos is changing as they are ment to
Roger
Post by Dehatter » Mon Aug 20, 2018 8:19 am
proger wrote: Mon Aug 20, 2018 7:29 am But the Camera is set to ftp every 500 second and the webcam block is updating every 500 second.
and this work fine.
Your image http://auestadhome.com/template/Webcamphoto/webcam2.jpg is not updating so your block is not updating every 500 secs.
image at 10:59 your time is shown to be taken at 9:49 your time.
proger
Post by proger » Mon Aug 20, 2018 9:53 am
I have checked that and it is updating fine.
A bad photo there
But the time on web photo and computer is the same hour
Post by andyk1 » Mon Aug 20, 2018 10:47 am
Have you look at the cron jobs to see if by chance the time was changed to 1 Hour. I am assuming you are using meteobridge? Look at those settings and your FTP setting in the camera. Shooting in the dark here but I have had this happen with a camera going bad.
proger
Post by proger » Mon Aug 20, 2018 12:19 pm
1. camera uploading to website every 10 min : checked
2. cronjob of renaming file every 10 min : checked
3. webcam block working properly replacing photo : checked
4. cronjob running webcamupdate.php every 10 min: checked (but not replacing photo until new hour)
I have totally run out ideas what to do so more or less give up the whole webcam plugin and timelaps..
I have this script renaming files.
is there anyone who can change this so I keep the original photo and not delete it.
<?php
$fileList = glob('*.jpg');
var_dump($fileList);
foreach (glob("directory/snap/*.jpg") as $filename) {
echo "Renaming " . $filename . " now.</br>";
if(file_exists($filename)) {
rename($filename, "webcam2" . ".jpg");
echo $filename . " is now webcam2" . ".jpg</br>";
Post by andyk1 » Mon Aug 20, 2018 1:23 pm
Did you check your CAMERA's FTP setting? The time section where you choose seconds or minutes. You have a directory path of..../snap so I am assuming you are using a foscam? if so double check the time interval and FTP
For Foscam
Settings/Network/FTP Setting that all is correct then look in
Settings/Video/Snapshot Settings for the correct time interval between pictures. I set mine for 285 seconds because of network delays and upload times and fairly close to the cron job intervals of 300 seconds.
To me it seems like a timing issue. Somewhere your new picture upload is not happening every 500 seconds as you say. The reason for all the pictures the same and not changing is because the cron job is using the same ../cam/webcamimage.jpg or where ever your image file is in your host server. It's only being updated/uploaded once an hour for whatever the reason and that needs to be tracked down.
Webcam block settings
Webcam plugin settings
cron job settings
FTP upload settings
If you are using a meteobridge, Those setting also
Did you change/modify any CAM php files?
It is working but only once every hour but reusing the same picture every ten minutes
Edited Grammatical error's on 8-21-2018 @ 21:55
proger
Post by proger » Mon Aug 20, 2018 1:38 pm
Thanks Andyk1
I will take a very deep study when I get home from work tonight
There has to be something somewhere and just have to find the small issue :)
Post by andyk1 » Mon Aug 20, 2018 1:41 pm
BTW, you have an awesome camera/time lapse setup. Don't give up on it... we'll figure it out. Lots of experienced users bumping heads on this.
proger
Post by proger » Mon Aug 20, 2018 3:18 pm
I'll give it a couple of days and see what I can figure out.
I'll come back with feedback if I find out what course this.
Post by Dehatter » Tue Aug 21, 2018 6:36 pm
I have used the script that is linked below successfully in the past.
You will have to adjust the pathing to fit you directory structure.
This was written around a Foscam camera for a friend, but it can be adjusted for any camera that FTPs with a datestamp.
I can assist as necessary.
https://drive.google.com/open?id=1211ao ... zC-8C7hmBl
This script renames the latest image in a snapshot folder to webcamimage in a webcam folder, and then deletes all the images from the snapshot folder. It should be placed in your /template/load/crons/ folder. A cronjob is required to run it, but if you are already running an MT cronjob, the existing job will automatically run this one too.
if not, I suggest https://cron-job.org/ as this is free, works well, and sends emails if a failure occures.
The command format looks like this:
http://www.yourdomain.com/template/load/cron.php?password=xxxx
where xxxx=your UPDATE password for the template as defined on the setup page.
This is what my setup page looks like and runs every 2 minutes. Please note that you do NOT need HTTP authentication, so you can leave that box unchecked. I entered information in there at one time when I first started and was trouble shooting.
Post by andyk1 » Tue Aug 21, 2018 7:02 pm
Reading Dehatter's (Tom) reply who has helped me also with a similar problem way back. I remember having a tough time figuring out why my cam snaps where not updating. For one I was using the highest available version of PHP at the time and it actually needed to be lowered to PHP ver 5.6 I believe. If you happened to recently change your version it would be something to look at.
Thanks Tom for reminding me.
That being said I don't think that would be your problem as it is updating but once an hour. I still tend to think it has to do with either FTP upload intervals or cronjob not working right. It is reusing the last updated picture every ten minutes because that is the only available picture and somehow sends a new one once an hour.
It also may help if we knew what your set up looks like... i.e. weather array type, Ambient, ObserverIP, Meteobridge, Davis, Acurite etc.
Post by Dehatter » Tue Aug 21, 2018 8:51 pm
andyk1 wrote: Tue Aug 21, 2018 7:02 pm For one I was using the highest available version of PHP at the time and it actually needed to be lowered to PHP ver 5.6 I believe.
The link is to a new version of the script Andy. I think you can use this with current PHP.
FYI
Thanks to BlueBear (memberlist.php?mode=viewprofile&u=55) for pointing that out to me a few weeks ago.
Post by andyk1 » Wed Aug 22, 2018 3:00 am
Dehatter wrote: Tue Aug 21, 2018 8:51 pm The link is to a new version of the script Andy. I think you can use this with current PHP.
FYI
Tom!!!
If I'm reading this correctly this is a replacement for my ../cam/webcam/camrename.php file you helped me with awhile back? After this edit I can raise my php level back up to the 7.???
proger
Post by proger » Wed Aug 22, 2018 8:31 am
Thanks alot for the php 5.6 tip.
My php ver was actullay set to 7.1
When I come home from work I will have a go setting up my webam timelaps again to see if that does the trick.
Since yesterday I have only run webcam block updating every 10 minutes and that work perfect.
thanks alot for the script Dehatter. Will test that out aswell.
proger
Post by proger » Thu Aug 23, 2018 8:35 pm
Hello Again
No luck with plugin
My setup is:
Acurite 5 in 1 station
aculink internet bridge
D-link dir 505 running Meteobridge
Foscam fi9900ep v3
What I have done:
Delete all files and database from server concerning webcam
(webam block, webcam plugin and Webcam time-lapse block)
change php database to ver 5.4
Starting over:
Set permission for the "webbilder" folder to 777 included subfolder and files in here.
webcamera ftp and image setup:
setting up ftp from camera to web server (success)
download interval set to 540 sec (checked 10 photos coming down to server.)
CRON JOB for rename photo.
Set up meteobrigde for cron job to rename file to webcam2.jpg. Using dehatters script. ( renaming photo every ten minutes with the new one)
all of the above is monitored via the file manager on my providers homepage for at least one hour for confirmation that it works.
Installed the webcam block :
img URL: http://auestadhome.com/template/webbilder/webcam2.jpg
Refresh interval in seconds: 600
Webcam Plugin
Download from Meteotemplate
copy to Plugin directory
control panel meteotemplate
image url: http://auestadhome.com/template/webbilder/webcam2.jpg
update interval: 600
save interval to database: 9
And this is where it goes wrong. Only one update an hour.
It all works fine until I start the Crone job for updateWebcam.php
I have no clue what to do.
I give up.
anyone want to have a go at this is welcome to give it a try.
I can change all password you need to temporary password if any of you would be so kind to give it a go.
Roger
Post by Dehatter » Thu Aug 23, 2018 10:40 pm
did you change the timezone in the image rename script to your timezone?
did you put BOTH the file updateWebcam.php (originally located in the plugin folder) and my image rename file (default name camrenameFC.php) in the /template/load/crons/ folder?
Additionally, a single cronjob command using this format
http://www.auestadhome.com/template/load/cron.php?password=yourupdatepassword
runs ALL the php scripts located in that cron folder. You do not need 2 cronjobs.
Also. not sure if you gave up or what, but your block is not updating either.
proger
Post by proger » Fri Aug 24, 2018 2:02 am
Yes I did.
No I did not. But I have done that now
Course the camera stop sending snaps at 10 pm.
But I have set it go 24 hours a day now.
Roger
proger
Post by proger » Fri Aug 24, 2018 3:34 am
I can't get the script to work when I move the camrenamefc to the cron folder.
I just can't figure out what folders to put in the lines in script
All my files goes into a folder named "webbilder" HTTP://auestadhome.com/webbilder/FI9900 ... F8B2B/snap
I want to save the renamed photo in /webbilder/webam2.jpg
camrenamefc is in /webbilder/
Can you help me with what to put in there
Roger
