Hi all
does anyone know where the preset value for the station elevation comes from?
Station Pressure and Station Temperature are correctly imported from the alldata table, but the value for the elevation is always 240 (ft or m).
Thanks for any explanation, Martin
PS I'm working on a metric version of the plugin (hpa to mmHg, instead of inHg).
pressure conversion
- John B
Re: pressure conversion
Hello, Martin,
As best I can gather your elevation is set in the Meteotemplate main menu in the Station Location section. Unfortunately my station is exactly 240 metres asl so I cannot comment further.
ph2
I had the same problem. I haven't found a solution how to change that through setup. I changed the value $ stationElevation = 240 to my value directly in the plugin file index.php, since then the value has been displayed correctly in the plugin
- iatros
- Language Admin
@John B, @ph2
Thank you both for your reply. I asked Jachym if he can help us and will keep you informed.
Cheers, Martin
Cheers, Martin
