Forecast Comparison Plugin – almost no values
ph2
Post by ph2 » Mon Nov 09, 2020 7:48 pm
I have problems with the ForecastComparison plugin: With CurrentConditions I only see the values of OWM, with CurrentForecast and Station vs. Forecast I only see values from yr and OWM (only 5 days)!
I see "Failed to load weather from worldweather.com Failed to load weather from Aeris Weather Failed to load weather from WU Failed to load weather from darksky.net"
I don't see an error for Yahoo, but no data is loaded for the location (Weyregg).
DarkSky no longer issues new Apis. But in the "forecast" block, DarkSky is also displayed without Api, why not in the plugin?
Aeris is only free for 30 days, after which it is very expensive!
WU: I have an API, but no values (for Weyregg) are displayed.
WWO is only free for 60 days. In the setup I set “NO” to the question “Have you a premium / trial account, the WWO values are still not displayed.
OWM only the 5-day values are displayed, but not the 16-day values.
Are there any tips on how to see Yahoo, WU, WWO and OWM's 16-day values?
Edit: While searching in the blocks, I have now found that there is no more yahoo data: Joachim, maybe you could add that to the information about the plugins and blocks. That should probably be easier and faster than changing these plugins and blocks. Otherwise you try forever and only eventually realize that this (and e.g. DarkSky) no longer deliver data.
