GrowingDegreeDays plugin - in some cases no values
ph2
Post by ph2 » Mon Nov 09, 2020 7:58 pm
If the month for the start of the season in the GrowingDegreeDays plugin is before the first month in which data is available in the year, then an error occurs: no values: Also a small error: the values are incorrect calculated if the base temperature is entered with a comma. This may only be entered with a dot!
iatros
Re: GrowingDegreeDays plugin - in some cases no values
Post by iatros » Mon Nov 23, 2020 8:59 am
Wenn in der gewählten Zeitspanne Daten fehlen, kann es durchaus sein, dass in der hinterlegten Formel eine Division durch Null geschieht. Dann gbt es kein Resultat. Grüsse
Language Admin für Deutsch
