Page 2 of 3
Re: Steelseries Gauges don't work ?
Posted: Mon Jan 14, 2019 9:44 pm
by Dehatter
Great minds Andy!!
lol
Posted: Mon Jan 14, 2019 9:45 pm
by Gatewayy
I double checked the plugin and the clock and both show that the initial settings have been created.
Greenshot 2019-01-14 15.43.46.png (12.5 KiB) Viewed 30245 times
Posted: Mon Jan 14, 2019 9:47 pm
by Dehatter
did you actually create the gauges. In the plugin you pick your color and style options.
or did you just click save at the bottom?
Posted: Mon Jan 14, 2019 9:49 pm
by andyk1
Hehehe I just noticed you changed the name of your site Tom and same url. :roll: :lol: :D
Posted: Mon Jan 14, 2019 9:51 pm
by andyk1
Dehatter wrote: Mon Jan 14, 2019 9:47 pm Capture5.JPG
I think he's setting it up now Tom. No change yet.
Posted: Mon Jan 14, 2019 9:52 pm
by Dehatter
you can have a different set in the block.
Posted: Mon Jan 14, 2019 9:54 pm
by Gatewayy
Yes I had changed a few of the settings so I just went back and changed a lot more of them but I am not seeing any changes yet.
Greenshot 2019-01-14 15.52.52.png (586.19 KiB) Viewed 30235 times
Posted: Mon Jan 14, 2019 9:59 pm
by andyk1
Strange. Not sure whats up then. You don't have ssGauges listed twice do you?
Wait. Not sure you can use Gauges and ssGauses at the same time. Try as an experiment to only run one or the other.
Posted: Mon Jan 14, 2019 10:01 pm
by Gatewayy
Good point, I removed the non SS block but I do not see a change.
Posted: Mon Jan 14, 2019 10:04 pm
by andyk1
I see one of the gauges trying to load. Feels like/Dew Point but not showing the gauges. Something else is going on.
Posted: Mon Jan 14, 2019 10:08 pm
by andyk1
The only thing I can think of at this point is delete and reinstall the ssGauges Block and steelSeries plugin and start over
Posted: Mon Jan 14, 2019 10:13 pm
by andyk1
There is another Block Called Gauges. Not sure if that need to be set up. Look in blocks 'Gauges'
by Dehatter
One other thing.
he is not using the /template/ sub-directory. He has the template installed in the root.
Do you think something could be written to look in /template/ ?
I set the plugin up myself.
Posted: Mon Jan 14, 2019 10:18 pm
by andyk1
If you look at my page I have both working I think the way you wanted? In my Desktop Homepage...header block I have"warningsUSRegions;ssGauges;gauges;nwsForecast" Try and see what happens?
Posted: Mon Jan 14, 2019 10:19 pm
by Gatewayy
andyk1 wrote: Mon Jan 14, 2019 10:08 pm The only thing I can think of at this point is delete and reinstall the ssGauges Block and steelSeries plugin and start over
I removed both, re-downloaded the plugin and block and re-installed them, still looks to be the same.
by Dehatter
both run.
Posted: Mon Jan 14, 2019 10:23 pm
by andyk1
Good point. But still it should point to /homepage/blocks/ssGauges and /plugins/steelSeries. I'm stumped. Has to be in a setting somewhere.
Posted: Mon Jan 14, 2019 10:29 pm
by Dehatter
me too. sigh
I checked all the phps, and there no reference instance of /template, but someone would have already checked that anyway.
Posted: Mon Jan 14, 2019 10:30 pm
by Dehatter
also hes using PHP ver 7,3
Can you step down to 7.2 or 7.1?
Posted: Mon Jan 14, 2019 10:32 pm
by andyk1
I have both running on my site and can't find the cause why only one gauge 'Feels Like/Dew point try's to load in his ssGauges series.
Good point. About stepping down a version or two of PHP version.
Posted: Mon Jan 14, 2019 10:33 pm
by Gatewayy
I just checked the scripts myself and yeah nothing looks like a hard coded path. I stepped PHP down to 7.1 to test.
Posted: Mon Jan 14, 2019 10:38 pm
by andyk1
It has to be in the ssGauges block or steelSeries Plugin. It starts to load if you look at his panel the dew point and apparent sym... shows.
Posted: Mon Jan 14, 2019 10:39 pm
by Dehatter
Are you using the standard meteotemplatelive.txt for updates?
Posted: Mon Jan 14, 2019 10:42 pm
by Gatewayy
Tht file does have values in it , I am sending from my station to the template via the api.php.
{"U":1547505626,"B":323,"W":4,"G":4,"H":91,"T":0.1,"HIN":61,"TIN":15.1,"RR":0,"R":0,"P":1027.2,"CO2_1":0,"SW":"WeatherCatV3.03B8","UTime":1547505626,"BTime":1547505626,"WTime":1547505626,"GTime":1547505626,"HTime":1547505626,"TTime":1547505626,"HINTime":1547505626,"TINTime":1547505626,"RRTime":1547505626,"RTime":1547505626,"PTime":1547505626,"CO2_1Time":1547505626,"SWTime":1547505626,"D":-1.2,"DTime":1547505626,"A":-2.8,"ATime":1547505626}
Posted: Mon Jan 14, 2019 10:45 pm
by Dehatter
ok so here a wierd thing.
On his plugin screen the guage summary icons load....and work......wierd!!!!
