updated warningsEUregions
Weerstationwoerden
Re: updated warningsEUregions
hi to you all
I have this block also on my site but its not update anymore
I see into the cache folder the file params.txt and warningsEURegions.txt
this files are up to date but if i look the txt I see the params.txt is not up to date
and the warningsEURegions.txt is ok
I see the info from the params.txt is on my site and not the info from the warningsEURegions.txt
is there a way for fix this ??
thanks
Gert
thanks
Gert
It seems working now. Not sure this is the case, but when you update the configuration of a block, remember to delete the cache ( if present ), or new content ( with new configuration ) will not be reloaded until the cache is expired ( generally after 1h ). This gives the impression that new settings are not correct.
this one is working fine.
detail: is it possible to make the rss feeds also available in the 'warningsEU' block?
Thank you David for all your work!!!!
Grtz
Alex
Grtz
Alex
Weerstationwoerden
I have see the block works OK now
only the optic full screen is not works but that is no problem for my
T-man
Downloaded the latest issue. I'm able to get warnings for other countries with map but Finland seems non functional. (tested also with mapall.php) Warnings for Finland come through but map is not visible.
-Timo
-Timo
- HILARIO
- Software: WLIP
Hello everyone,
I've noticed for a few days that the map in my "warningsEUregions" block has had some changes.
Now when alerts appear on the map, instead of appearing with the usual colors (yellow, orange, red) they are only seen in black.
Does anyone know if there has been any change?
Could it be that there is a change in the file: cache/params.txt?
I think this file is responsible for the alerts appearing on the map.
Can anyone check this error or incident?
- lemimi
Good evening,
I just checked, this also happens to me:
https://www.lemimi.fr/template/indexFul ... sEUregions
Alvaro Poggiani
- Software: Meteobridge Pro2
Succede estattamente la stessa cosa anche a me, in Italia.
Cordiali saluti
alvaroi
https://www.meteovarazze.it
Cordiali saluti
alvaroi
- Screenshot 2024-11-26 085801.png (55.48 KiB) Viewed 73587 times
Updated the block as the rss feed changed a little bit.
ver 2.4 2024-12-05
- fix rss feed change
- fix finland regions definition
- fix 'sea boundaries'
http://realrunning.netsons.org/template ... ns_2.4.zip
ver 2.4 2024-12-05
- Jolumarali
- Station model: Vantage Vue
- Software: WlIP
Thanks again, Davide, for the successful installation. Your help was invaluable!
- HILARIO
- Software: WLIP
Thank you very much Davide!!
The block returns to normal operations
- lemimi
Same for me. Many thanks to you... Michel
Alvaro Poggiani
Grazie Davide, anch'io confermo che dopo il tuo intervento è tornato tutto a funzionare.
Alvaro
www.meteovarazze.it
Alvaro
www.meteovarazze.it
Decon
Thank you for your work!
Alvaro Poggiani
Non per essere pignoli, ma sembra che il blocco "Warnings EUregions" abbia voglia di scherzare,
(almeno con me)
Comunque va bene anche così
Ciao a tutti
Alvaro
www:meteovarazze.it
(almeno con me)
Ciao a tutti
Alvaro
www:meteovarazze.it
Verify you have the last version installed.
I see your warningsEUregionsConfig.txt start with the following line ( which should belong to ver 2.2 )
Also after updating the software remember to clear the block cache.
Note
For example script warningsEUregions.php should be dated 4 Dec 2024
{"version":2.2,"name":"EU Warnings - regional","namespace":"warningsEUregions","variables":[Note
Alvaro Poggiani
Grazie Davide,
sono le persone come te che aiutano e insegnano alle capre come me.
Ho provveduto subito a porre rimedio al "disservizio" e ho atteso a risponderti che i risultati fossero almeno un po' consolidati.
Inspiegabile comunque quello che mi hai fatto notare, io lo colloco tra i "misteri gaudiosi" che la mia ignoranza, purtroppo, non mi consente di spiegare.
Venerdì u.s. ho installato la tua nuova versione (la 2.4) e nel ringraziarti per il tuo lavoro ti ho comunicato che tutto era tornato a funzionare (vedi mio post)
Ieri, l'Italia, è tornata ,,,"tutta nera" ma ti assicuro che io non avevo re-installato la versione vecchia 2.2.
Dopo la tua preziosa annotazione di oggi hon ricominciato dall'inizio:
fatta pulizia dell'installazione precedente, reinstallata la versione nuova di EUregions (2.4), ripulita la cache e le impostazioni di navigazione cancellando quelle precedenti come suggerito da Chrome e, come puoi vedere dallo screen, tutto è come dev'essere.
Probabilmente c'è stato qualche step che mi è sfuggito di mano inavvertitamente
(credo in matematica i misteri non esistano, nemmeno quelli gaudiosi)
e, come dicevo all'inizio, è grazie alle persone capaci e disponibili come te se anche chi non sa riesce ad imparare qualcosa.
Alvaro
www.meteovarazze.it
Alvaro
www.meteovarazze.it
This block version is only for Norway, Sweden and Slovenia (which use 'polygons' in the meteoalarm.org warnings definition ).
All other countries should not use this version ( but this may change )!
ver 2.5 2024-12-26
- changed feed from rss to json
- use leaflet to show polygons on map
- added tooltip with warning description
- approximate coordinates:
Norway 64.91, 16.91, zoom 4.4
Sweden 64.08, 16.44, zoom 4.5
Slovenia 46.16, 14.92, zoom 7.8
http://realrunning.netsons.org/template ... lygons.zip
ver 2.5 2024-12-26
- WEUR_look.png (210.06 KiB) Viewed 70860 times
Meteo Heijningen
- Station model: Ecowitt Wittboy GM2001
I would like to advise the Dutch users to add a small change to the warningsEUregionsBlock.php as in version 2.4 for the Netherlands I found out, at least in my case, you will get no warnings.
In line 49 you need to change the "NL" to "nl" so lower case, (, 'nl'=>'netherlands',) then it works and you will get warnings.
Eddy
Eddy
Thanks, I updated the code.Meteo Heijningen wrote: ↑Fri Dec 27, 2024 3:03 pm I would like to advise the Dutch users to add a small change to the warningsEUregionsBlock.php as in version 2.4 for the Netherlands I found out, at least in my case, you will get no warnings.
Eddy
- tobydude
- Station model: Netatmo
- Software: Weatherdiaplay
This is greate!davidefa wrote: ↑Thu Dec 26, 2024 9:38 pm This block version is only for Norway, Sweden and Slovenia (which use 'polygons' in the meteoalarm.org warnings definition ).
ver 2.5 2024-12-26
Was not aware that there was a new version out as I´m not very good in opening christmas presents.
Thanks.
AnGeLiuS
- Software: Ecowitt
Le bloc ne semble plus fonctionner.
Dans le fichier warningsEURegions.txt, j'ai :
Merci d'avance pour ceux qui pourrait aider
<?xml version="1.0" encoding="UTF-8"?>
<rss version="2.0" xmlns:atom="http://www.w3.org/2005/Atom">
<channel>
<title>MeteoAlarm France</title>
<link>https://meteoalarm.org?region=FR</link>
<description>This RSS feed has been deprecated. Please use the Atom feed instead: https://feeds.meteoalarm.org/feeds/meteoalarm-legacy-atom-france</description>
<language>en</language>
<lastBuildDate>Fri, 27 Mar 2026 12:32:34 GMT</lastBuildDate>
<pubDate>Fri, 27 Mar 2026 12:32:34 GMT</pubDate>
<atom:link href="https://feeds.meteoalarm.org/feeds/meteoalarm-legacy-atom-france" rel="alternate" type="application/atom+xml"/>
</channel>
</rss>
- Jolumarali
- Software: WlIP
bonjour
Legacy RSS Feeds Have Been Sunset on 2026.01.14.
As announced earlier, the legacy RSS feeds (meteoalarm-legacy-rss-*) have been deprecated and are no longer updated. Please migrate to the Atom feed format, which provides the same data and is actively maintained.
Les flux RSS hérités ont été supprimés le 14.01.2026.
Comme annoncé précédemment, les flux RSS hérités (meteoalarm-legacy-rss-*) ont été obsolètes et ne sont plus mis à jour. Veuillez migrer vers le format de flux Atom, qui fournit les mêmes données et est activement maintenu.
Davide au secours
bonjour
Davide au secours
