Page 2 of 2
Re: need help for ecowitt wh57 lightning device
Posted: Wed Aug 17, 2022 6:37 am
Your gw1100 has been reset and so last distance and last time are unavailable ( but initialized with 0 that as a timestamp is 01/01/1970 ).
Did not consider this case but it could be shown 'unavailable' or '--'
Posted: Sat Aug 20, 2022 11:33 pm
by andyk1
Hello David!!!
I have been away from MT for a good while and catching up before php 7.4 expires.
As Dehatter says "You are definitely THE MAN - THE LEGEND!!"
Posted: Sat Aug 27, 2022 6:54 am
by meteoesine
Ciao,
Would it be possible to move the total lightning year under Strikes last 60min and above last strike?
but only total lightning, however
the other comments $tunder_txt (Storm is approaching at, Storm is going away, ...) leave them under where they are
thanks in advance
Posted: Tue Aug 30, 2022 12:52 am
by andyk1
Hi!
I seem to have a problem in ver 2.3 where the 5 min section is not updating and the approaching storm at the bottom is not working. It was with a previous version which I don't remember the number of but assuming ver 1.0
I am still only using PHP 7.4 because am afraid to make the leap to 8.0 or 8.1. Could that be my problem and which should I try. PHP ver num (8.0 or 8.1) I mean.
Edit: I tried updating to both php 8.0 and 8.1 but my site comes up with a blank page and having to revert back to php 7.4 I think (I forgot the version number)
I mentioned this in other posts encase you run across them.
Posted: Tue Dec 26, 2023 2:18 pm
by Julius
Andy, may I ask how you got the WH57 lightning data correctly into meteotemplate?
I see these in my meteobridge:
- Screenshot 2023-12-26 at 15-14-49 Meteobridge PRO.png (71.17 KiB) Viewed 37939 times
near the bottom are the lightning ones. I added
&L=[lgt0!0total-dmax.0:]&LD=[lgt0!0dist-lastval.0:]<=[lgt0!0total-nonzerotime=epoch:]
to the api call to MT, but for some reason this does not yield anything more than just that L value.
Posted: Wed Jan 10, 2024 8:47 am
by leonrossouw
I need some help with lightningew block please.
My data shows in meteotemplate database…see attachments…but the block always shows only 1 strike…latest.
I have seet cache time to 0
Thank you,
Leon Rossouw.
Posted: Wed Jan 10, 2024 8:52 am
by leonrossouw
Screenshot of block
Posted: Wed Jan 10, 2024 9:00 am
by leonrossouw
Screenshot
Posted: Wed Jan 10, 2024 9:02 am
by leonrossouw
Screenshot database
Posted: Wed Jan 10, 2024 9:04 am
by leonrossouw
Screenshot database
- IMG_0381.jpeg (731.19 KiB) Viewed 37891 times
Posted: Wed Jan 10, 2024 9:22 am
by meteoesine
try to set your block like this
Posted: Wed Jan 10, 2024 9:29 am
by leonrossouw
Thank you…did that but still showing only current strike
Posted: Wed Jan 10, 2024 10:56 am
by leonrossouw
I eventually got it sorted thank you,
Problem was with my database..
Leon
