Page 3 of 3
Re: 18.0
Posted: Sat Dec 01, 2018 4:27 am
by andyk1
cdarney3 wrote: โThu Nov 29, 2018 9:22 pm
So in the Backup block when logged in as Admin I can backup station data. I had a problem doing 11 years worth but no problem doing a single year. Once backed up the first 10 years wouldn't matter to me If I can manually execute a station data backup and have it backup properly, wouldn't adding a scheduling feature to that be possible?
Ditto for backing up core template and settings files which takes almost no time.
I to have 11 years of data and I have no problems most times backing up the entire data base. That being said... there are times and I have not been able to pin it down, it does not work. Times out and have to do it by year one year at a time. This was maybe 6 or more months ago as I have found there is no reason to back up the entire database since it has been saved. The only thing I do from time to time is back up the current year. It is safe to say your previous years data will not change and therefore not need continuous backing up.
Re: 18.0
Posted: Thu Dec 20, 2018 7:02 pm
by cdarney3
I've taken to backing up all of my template settings and the current year's data every week. All previous years have been backed up once and I don't bother with them now as they are backed up to a pretty secure location. Like you said, previous years won't be changing so I just do the current year. After backing up template files and DBs, I backup the entire DB through my hosting site. I also backup my entire hosted site. I now keep all of these files together on a weekly basis. I really don't want to lost my ALLDATA table again.
Re: 18.0
Posted: Wed Jan 09, 2019 9:59 am
by SimonB
If I can make a way out suggestion...
The desktop solution works well, but not a great fan of the mobile version.
How about an iOS and android app?
Re: 18.0
Posted: Mon Jan 14, 2019 11:29 am
by iatros
Hi simonB
Have a look at this:
viewtopic.php?f=50&t=575
Cheers
Martin
Re: 18.0
Posted: Mon Jan 14, 2019 5:21 pm
SimonB wrote: โWed Jan 09, 2019 9:59 am
programming mobile apps uses completely different languages (Java, Swift etc.) compared to web development (PHP, JavaScript, HTML, CSS etc.), which I do not know.
Re: 18.0
Posted: Mon Jan 14, 2019 7:36 pm
by andyk1
Just to let you know, someone has/is working on an android app that works really well.
https://www.elspinars.es/dev/app.php or look for "Meteotemplate" in the google playstore.
Allot of options. you have to look around for plugins and blocks but fairly simple.
Re: 18.0
Posted: Sun Jan 20, 2019 4:37 pm
by polbrieuc
andyk1 wrote: โMon Jan 14, 2019 7:36 pm
Hi Andy,
Thanks for remind the other forum users of the existence of this project (which is in beta for now).
There is actually a thread on this forum that deal with this topic :
http://meteotemplate.com/forum/viewtopi ... &start=125
Cheers,
Pol-Brieuc
Re: 18.0
Posted: Sun Oct 13, 2019 11:03 pm
by staze
Could I ask that we alter the database schema so the primary key is a normal row number rather than the date, and then convert to InnoDB? MyISAM is deprecated as of MySQL 8, and InnoDB does not like arbitrary primary keys (makes inserts take a significant amount of time).
Re: 18.0
Posted: Tue Jan 14, 2020 7:02 pm
by Meteopomezia
It would be nice if I also implemented the template for the wview software
Re: 18.0
Posted: Sat Jul 04, 2020 7:27 pm
by Dehatter
Re: 18.0
Post by Jachym ยป Sun Jul 15, 2018 5:08 am
Hi Johnny,
- webcam - planned, this however is a plugin, so not related to v18
- lightning counter - API supports already supports lightnings.... so once it is being sent by MB I can create a block/plugin without modifying the template
I too am interested in this, or if anyone has gotten their lightning counter to display in the template, let me know.
Re: 18.0
Posted: Sun Jun 27, 2021 2:15 am
by andyk1
A year later and still can't get ecowitt lightning dist and count yet. If anyone's found a solution let us know.
Using Raspberry Pi ver of MB.
Re: 18.0
Posted: Mon Jun 28, 2021 11:42 pm
I'm using the block by Raffaello Di Martino ( and it works ok,
see this topic ).
You should call api.php passing L, LD and LT ( and I see in your meteotemplateLive.txt these parameters are not present )
