Meteotemplate - process of updating
Re: Meteotemplate - process of updating
Post by Jachym » Wed Aug 16, 2023 10:56 am
yes I would still use the new functions.php.
@tobydude - have you tried replacing the scripts/functions.php I posted later in this thread? In the original update_19 zip file this one required a fix.
spd2612
Software: Meteobridge Pro 2
Post by spd2612 » Wed Aug 16, 2023 11:28 am
I did replace the functions.php
Everything works in my plugins and blocks
Except the summary block
It did work before cranberry not really sure why though i believe the errors are associated with php 8.xx
Davis Pro 2
Meteobridge Pro2
GW 2000
WH57 Lightning Detector
tobydude
Software: Weatherdiaplay
Post by tobydude » Wed Aug 16, 2023 2:11 pm
Jachym wrote: Wed Aug 16, 2023 10:56 am
Yes, I did replace the functions.php.
I did the whole replacemant/update twice , but same result.
Biggest problem thou is that my Netatmo station doesn´t communicate with WeatherDisplay.
didoujm
Software: WEATHER DISPLAY
Post by didoujm » Wed Aug 16, 2023 3:24 pm
Hello Jackim
I have a problem starting my test page of version 19.0 Cranberry. The test site: www.mirepoix09-meteo.com/template/indexDesktop.php.
I have to click twice on home at startup to display my page in https. Sincerely didier.
Weather mirepoix
I solved my problem
weatherbee
Post by weatherbee » Wed Aug 16, 2023 3:49 pm
I've updated and included the new functions.php.
I use php 7.4 and it works fine.
It also works in php 8.0 & 8.1.
I just get a blank screen in php 8.2.
spd2612
Post by spd2612 » Wed Aug 16, 2023 4:56 pm
If I use the attached Functions.php instead of the one @jachym put up it gets rid of the Fatal error in the Summary5.8 block but produces a whole lot more warnings, However the Summary Block does load
See my attached Functions.php with the errors below it
<?php
	#	Meteotemplate
	# 	http://www.meteotemplate.com
	# 	Free website template for weather enthusiasts
	# 	Author: Jachym
	#           Brno, Czech Republic
	# 	First release: 2015
	#	Main functions
	# 	A script which contains the main functions used by the template.
	# 	v17.2 Nectarine 2019-06-27
	if (function_exists('mb_internal_encoding')) {
		mb_internal_encoding('UTF-8');
		mb_http_output('UTF-8');
		//mb_http_input('UTF-8');
		mb_language('uni');
		mb_regex_encoding('UTF-8');
	function count8($a)
       if ((PHP_VERSION_ID < 70300) || (is_countable($a)))
           return count($a);
   	   else
   	       return 0;
	function lang($string,$case="-"){
		global $language;
		global $lang;
		// check if the word exists in the main Meteotemplate translation files and there is translation for it
		if (array_key_exists($string, $language[$lang])&&($language[$lang][$string]!="")) {
			$str = utf8_encode($language[$lang][$string]);
				if($case=="l"){
					$str = utf8_encode(mb_strtolower(utf8_decode($str)));
				if($case=="u"){
					$str = utf8_encode(mb_strtoupper(utf8_decode($str)));
				if($case=="c"){
					$str = ucfirst($str);
				if($case=="w"){
					$str = ucwords($str);
				if($case=="-"){
					$str = ($str);
			else{
				if($case=="l"){
					$str = utf8_encode(strtolower(utf8_decode($str)));
				if($case=="u"){
					$str = utf8_encode(strtoupper(utf8_decode($str)));
				if($case=="c"){
				if($case=="w"){
				if($case=="-"){
					$str = ($str);
		else{
			if (isset($language['us']) && array_key_exists($string, $language['us'])) { // string exists, but is not yet translated, we return english equivalent
				$str = $language['us'][$string];
				if($case=="l"){
					$str = strtolower($str);
				if($case=="u"){
					$str = strtoupper($str);
				if($case=="c"){
				if($case=="w"){
				if($case=="-"){
					$str = ($str);
			else{ // if it is customized translation we just format and return
				$str = $string;
				if($case=="l"){
				if($case=="u"){
				if($case=="c"){
				if($case=="w"){
				if($case=="-"){
					$str = ($str);
		return utf8_decode($str);
	function loadLangs(){
		global $baseURL;
		global $lang;
		$languageRaw = file_get_contents($baseURL."lang/gb.php");
		$language['gb'] = json_decode($languageRaw,true);
		$languageRaw = file_get_contents($baseURL."lang/".$lang.".php");
		$language[$lang] = json_decode($languageRaw,true);
		return $language;
	function mySQLGET($query){
		global $con;
		$thisQuery = mysqli_query($con, $query);
		if(error_reporting() != 0){
			if(!$thisQuery){
				echo("Meteotemplate MySQL Error: " . mysqli_error($con));
		if($thisQuery){
			return mysqli_fetch_array($thisQuery);
	function isHTTPS() {
		return
		(!empty($_SERVER['HTTPS']) && $_SERVER['HTTPS'] !== 'off')
		|| $_SERVER['SERVER_PORT'] == 443;
	function convertor($n,$unit1,$unit2){
		// prepare input
		$unit1 = trim(strtolower($unit1));
		$unit2 = trim(strtolower($unit2));
		$unit1 = str_replace("/","",$unit1);
		$unit2 = str_replace("/","",$unit2);
		$unit1 = str_replace("kts","kt",$unit1);
		$unit2 = str_replace("kts","kt",$unit2);
		$unit1 = str_replace("knots","kt",$unit1);
		$unit2 = str_replace("knots","kt",$unit2);
		$unit1 = str_replace("kph","kmh",$unit1);
		$unit2 = str_replace("kph","kmh",$unit2);
		$unit1 = str_replace("mb","hpa",$unit1);
		$unit2 = str_replace("mb","hpa",$unit2);
		$unit1 = str_replace("miles","mi",$unit1);
		$unit2 = str_replace("miles","mi",$unit2);
		$unit1 = str_replace("feet","ft",$unit1);
		$unit2 = str_replace("feet","ft",$unit2);
		$unit1 = str_replace("foot","ft",$unit1);
		$unit2 = str_replace("foot","ft",$unit2);
		// return same units
		if($unit1==$unit2){
			return $n;
		// temperature
		else if($unit1=="c" && $unit2=="f"){
			return $n*1.8 + 32;
		else if($unit1=="f" && $unit2=="c"){
			return ($n - 32)/1.8;
		// wind speed
		else if($unit1=="ms" && $unit2=="kmh"){
			return $n * 3.6;
		else if($unit1=="ms" && $unit2=="mph"){
			return $n * 2.23694;
		else if($unit1=="ms" && $unit2=="kt"){
			return $n * 1.943844;
		else if($unit1=="kmh" && $unit2=="ms"){
			return $n / 3.6;
		else if($unit1=="kmh" && $unit2=="mph"){
			return $n * 0.621371;
		else if($unit1=="kmh" && $unit2=="kt"){
			return $n * 0.539957;
		else if($unit1=="mph" && $unit2=="ms"){
			return $n * 0.44704;
		else if($unit1=="mph" && $unit2=="kmh"){
			return $n * 1.609344;
		else if($unit1=="mph" && $unit2=="kt"){
			return $n * 0.868976;
		else if($unit1=="kt" && $unit2=="ms"){
			return $n * 0.514444;
		else if($unit1=="kt" && $unit2=="kmh"){
			return $n * 1.852;
		else if($unit1=="kt" && $unit2=="mph"){
			return $n * 1.150779;
		// pressure
		else if($unit1=="hpa" && $unit2=="inhg"){
			return $n * 0.02952998;
		else if($unit1=="hpa" && $unit2=="mmhg"){
			return $n * 0.750063755;
		else if($unit1=="inhg" && $unit2=="hpa"){
			return $n * 33.863881;
		else if($unit1=="inhg" && $unit2=="mmhg"){
			return $n * 25.400069;
		else if($unit1=="mmhg" && $unit2=="hpa"){
			return $n * 1.3332239;
		else if($unit1=="mmhg" && $unit2=="inhg"){
			return $n * 0.03937;
		// precipitation
		else if($unit1=="mm" && $unit2=="in"){
			return $n * 0.0393701;
		else if($unit1=="in" && $unit2=="mm"){
			return $n * 25.4;
		else if($unit1=="mm" && $unit2=="cm"){
			return $n * 0.1;
		else if($unit1=="cm" && $unit2=="mm"){
			return $n * 10;
		// distance
		else if($unit1=="km" && $unit2=="mi"){
		else if($unit1=="mi" && $unit2=="km"){
			return $n * 1.60934;
		else if($unit1=="km" && $unit2=="ft"){
			return $n * 3280.84;
		else if($unit1=="ft" && $unit2=="km"){
			return $n * 0.0003048;
		else if($unit1=="m" && $unit2=="ft"){
			return $n * 3.28084;
		else if($unit1=="ft" && $unit2=="m"){
			return $n * 0.3048;
	function convertT($value){
		global $dataTempUnits;
		global $displayTempUnits;
		$formats = $dataTempUnits.$displayTempUnits;
		if($formats=="CC"){
			return $value;
		if($formats=="CF"){
			return round((($value*1.8)+32),3);
		if($formats=="FC"){
			return round((($value-32)/1.8),3);
		if($formats=="FF"){
			return $value;
	function convertTStddev($value){
		if($formats=="CC"){
			return $value;
		if($formats=="CF"){
			return $value*1.8;
		if($formats=="FC"){
			return $value/1.8;
		if($formats=="FF"){
			return $value;
	function convertW($value){
		global $dataWindUnits;
		global $displayWindUnits;
		$formats = $dataWindUnits.$displayWindUnits;
		if($dataWindUnits==$displayWindUnits){
			return $value;
		if($formats=="mskmh"){
			return round(($value*3.6),3);
		if($formats=="msmph"){
			return round(($value*2.23694),3);
		if($formats=="kmhms"){
			return round(($value/3.6),3);
		if($formats=="kmhmph"){
			return round(($value*0.621371),3);
		if($formats=="mphms"){
			return round(($value*0.44704),3);
		if($formats=="mphkmh"){
			return round(($value*1.609344),3);
		if($formats=="mskt"){
			return round(($value*1.943844),3);
		if($formats=="kmhkt"){
			return round(($value*0.539957),3);
		if($formats=="mphkt"){
			return round(($value*0.868976),3);
		if($formats=="ktms"){
			return round(($value*0.514444),3);
		if($formats=="ktkmh"){
			return round(($value*1.852),3);
		if($formats=="ktmph"){
			return round(($value*1.150779),3);
	function convertP($value){
		global $dataPressUnits;
		global $displayPressUnits;
		$formats = $dataPressUnits.$displayPressUnits;
		if($dataPressUnits==$displayPressUnits){
			return $value;
		if($formats=="hpammhg"){
			return round(($value*0.75006375541921),3);
		if($formats=="hpainhg"){
			return round(($value*0.0295299830714),3);
		if($formats=="mmhghpa"){
			return round(($value*1.3332239),3);
		if($formats=="mmhginhg"){
			return round(($value*0.03937),3);
		if($formats=="inhghpa"){
			return round(($value*33.863881579),3);
		if($formats=="inhgmmhg"){
			return round(($value*25.400069),3);
	function convertR($value){
		global $dataRainUnits;
		global $displayRainUnits;
		$formats = $dataRainUnits.$displayRainUnits;
		if($formats=="mmmm"){
			return $value;
		if($formats=="mmin"){
			return round(($value*0.0393701),3);
		if($formats=="inmm"){
			return round(($value*25.4),3);
		if($formats=="inin"){
			return $value;
	function unitFormatter($unit){
		$unit = str_replace('kmh','km/h',$unit);
		$unit = str_replace('ms','m/s',$unit);
		$unit = str_replace('inhg','inHg',$unit);
		$unit = str_replace('hpa','hPa',$unit);
		$unit = str_replace('mmhg','mmHg',$unit);
		$unit = str_replace('C','°C',$unit);
		$unit = str_replace('F','°F',$unit);
		return $unit;
	function cleanHTML($html){
		$html = preg_replace("/\n/", "", $html);
		$html = preg_replace('/\s+/', ' ', $html);
		return $html;
	function createCacheDir(){
		if(!is_dir("cache")){
			mkdir("cache");
	function showLog($errorLog){
		foreach($errorLog as $entry){
			if($entry[0]=="e"){
				echo "<script>console.error('Meteotemplate Error: ".$entry[1]."');</script>";
			else if($entry[0]=="w"){
				echo "<script>console.warn('Meteotemplate Warning: ".$entry[1]."');</script>";
			else{
				echo "<script>console.log('Meteotemplate: ".$entry[1]."');</script>";
	function getColorHue($colorString,$type){
		if($type=="hex"){
			$rgb = convertColor($colorString);
			if ($rgb['r'] + $rgb['g'] + $rgb['b'] > 382){
				return "light";
			else{
				return "dark";
		else{
			$colorBreakDown = str_replace("rgb(","",$colorString);
			$colorBreakDown = str_replace(")","",$colorBreakDown);
			$colorBreakDown = explode(",",$colorBreakDown);
			if ($colorBreakDown[0] + $colorBreakDown[1] + $colorBreakDown[2] > 382){
				return "light";
			else{
				return "dark";
	function convertColor($hex, $alpha = false) {
		$hex      = str_replace('#', '', $hex);
		$length   = strlen($hex);
		$rgb['r'] = hexdec($length == 6 ? substr($hex, 0, 2) : ($length == 3 ? str_repeat(substr($hex, 0, 1), 2) : 0));
		$rgb['g'] = hexdec($length == 6 ? substr($hex, 2, 2) : ($length == 3 ? str_repeat(substr($hex, 1, 1), 2) : 0));
		$rgb['b'] = hexdec($length == 6 ? substr($hex, 4, 2) : ($length == 3 ? str_repeat(substr($hex, 2, 1), 2) : 0));
		if ( $alpha ) {
			$rgb['a'] = $alpha;
		return $rgb;
	function avgWind($directions) { // based on http://en.wikipedia.org/wiki/Yamartino_method
	  $sinSum = 0;
	  $cosSum = 0;
	  foreach ($directions as $value) {
		$sinSum += sin(deg2rad($value));
		$cosSum += cos(deg2rad($value));
	  return ((rad2deg(atan2($sinSum, $cosSum)) + 360) % 360);
	function windAbb($value){
		if($value<=11.25){
			return "N";
		if($value>11.25 && $value<=33.75){
			return "NNE";
		if($value>33.75 && $value<=56.25){
			return "NE";
		if($value>56.25 && $value<=78.75){
			return "ENE";
		if($value>78.75 && $value<=101.25){
			return "E";
		if($value>101.25 && $value<=123.75){
			return "ESE";
		if($value>123.75 && $value<=146.25){
			return "SE";
		if($value>146.25 && $value<=168.75){
			return "SSE";
		if($value>168.75 && $value<=191.25){
			return "S";
		if($value>191.25 && $value<=213.75){
			return "SSW";
		if($value>213.75 && $value<=236.25){
			return "SW";
		if($value>236.25 && $value<=258.75){
			return "WSW";
		if($value>258.75 && $value<=281.25){
			return "W";
		if($value>281.25 && $value<=303.75){
			return "WNW";
		if($value>303.75 && $value<=326.25){
			return "NW";
		if($value>326.25 && $value<=348.75){
			return "NNW";
		if($value>348.75){
			return "N";
	function curlMain($url,$timeout){
		$ch = curl_init();
		curl_setopt($ch, CURLOPT_HEADER, 0);
		curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
		curl_setopt($ch, CURLOPT_URL, $url);
		curl_setopt($ch, CURLOPT_CONNECTTIMEOUT, $timeout);
		curl_setopt($ch, CURLOPT_USERAGENT,"Mozilla/5.0 (Windows NT 6.1; rv:19.0) Gecko/20100101 Firefox/19.0");
		$data = curl_exec($ch);
		curl_close($ch);
		return $data;
	function loadContent($url,$timeout){
		$ch = curl_init();
		curl_setopt($ch, CURLOPT_USERAGENT,"Mozilla/5.0 (Windows NT 6.1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/41.0.2228.0 Safari/537.36");
		curl_close($ch);
		if($data==""){
			$data = file_get_contents($url);
		return $data;
	function solarMax($time,$lat,$lon,$elevation,$elevationUnits){
		if($elevationUnits=="ft"){
			$z = 0.3048 * $elevation;
		else{
			$z = $elevation;
		$atc = 0.8;
		$lw  = (M_PI / 180) * -$lon;
		$phi = (M_PI / 180) * $lat;
		$d   = ($time / (60 * 60 * 24) - 0.5 + 2440588) - 2451545;
		$M = (M_PI / 180) * (357.5291 + 0.98560028 * $d);
		$L = ((M_PI / 180) * (1.9148 * sin($M) + 0.02 * sin(2 * $M) + 0.0003 * sin(3 * $M))) + $M + (M_PI / 180) * 102.9372 + M_PI;
		$declin = asin(sin(0) * cos(((M_PI / 180) * 23.4397)) + cos(0) * sin(((M_PI / 180) * 23.4397)) * sin($L));
		$rightAsc = atan2(sin($L) * cos(((M_PI / 180) * 23.4397)) - tan(0) * sin(((M_PI / 180) * 23.4397)), cos($L));
		$H   = ((M_PI / 180) * (280.16 + 360.9856235 * $d) - $lw) - $rightAsc;
		$altitude = asin(sin($phi) * sin($declin) + cos($phi) * cos($declin) * cos($H));
		$altitude = $altitude * 180 / M_PI;
		$JD = $time / (60 * 60 * 24) - 0.5 + 2440588;
		$dayTime = ($time - strtotime(date("Y",$time)."-".date("m",$time)."-".date('d',$time)." 00:00"))/(24*60*60*1000);
		$t = ($JD + $dayTime -2451545.0)/36525;
		$eccentricity = 0.01678634 + 0.000042037*$t + 0.0000001267*$t*$t;
		$mean_anomaly =  357.52911+ 35999.05029*$t + 0.0001537*$t*$t;
		if($mean_anomaly<0){
			$mean_anomaly=$mean_anomaly%360+360;
		if($mean_anomaly>360){
			$mean_anomaly=$mean_anomaly%360;
		$c = (1.914602 - 0.004817*$t + 0.000014*$t*$t)*sin($mean_anomaly*(M_PI / 180));
		$c =$c+ (0.019993 - 0.000101*$t)*sin(2*$mean_anomaly*(M_PI / 180));
		$c =$c+ 0.000289 *sin(3*$mean_anomaly*(M_PI / 180));
		$true_anomary = $mean_anomaly + $c;
		$radius = (1.000001018*(1-$eccentricity*$eccentricity))/(1 + $eccentricity*cos($true_anomary*(M_PI / 180)));
		$distance= $radius * 149598000;
		$el = $altitude;
		$R = $radius;
		$nrel = 1367.0;
		$sinal = sin(deg2rad($el));
		if($sinal >= 0){
			$rm = pow((288.0 - 0.0065 * $z) / 288.0, 5.256) / ($sinal + 0.15 * pow($el + 3.885, -1.253));
			$toa = $nrel * $sinal / ($R * $R);
			$sr = $toa * pow($atc, $rm);
		else{
			$sr = 0;
		return $sr;
	/* ############ COLOR FILL ######################## */
	function fill($value,$stops,$colors) {
		global $fromR, $fromG, $fromB;
		global $toR, $toG, $toB;
		for ($i = 0; $i < count($stops); $i++) {
			if ($value > $stops[$i] && $value <= $stops[$i + 1]) {
				$pos = ($value - $stops[$i]) * (1 / ($stops[$i + 1] - $stops[$i]));
				$minimum_color = $colors[$i];
				$maximum_color = $colors[$i + 1];
				$minimum_color = str_replace("#", "", $minimum_color);
				if (strlen($minimum_color) == 3) {
					$fromR = hexdec(substr($minimum_color, 0, 1) . substr($minimum_color, 0, 1));
					$fromG = hexdec(substr($minimum_color, 1, 1) . substr($minimum_color, 1, 1));
					$fromB = hexdec(substr($minimum_color, 2, 1) . substr($minimum_color, 2, 1));
				else {
					$fromR = hexdec(substr($minimum_color, 0, 2));
					$fromG = hexdec(substr($minimum_color, 2, 2));
					$fromB = hexdec(substr($minimum_color, 4, 2));
				$maximum_color = str_replace("#", "", $maximum_color);
				if (strlen($maximum_color) == 3) {
					$toR = hexdec(substr($maximum_color, 0, 1) . substr($maximum_color, 0, 1));
					$toG = hexdec(substr($maximum_color, 1, 1) . substr($maximum_color, 1, 1));
					$toB = hexdec(substr($maximum_color, 2, 1) . substr($maximum_color, 2, 1));
				else {
					$toR = hexdec(substr($maximum_color, 0, 2));
					$toG = hexdec(substr($maximum_color, 2, 2));
					$toB = hexdec(substr($maximum_color, 4, 2));
				$colorR = round($toR + ($fromR - $toR) * (1 - $pos));
				$colorG = round($toG + ($fromG - $toG) * (1 - $pos));
				$colorB = round($toB + ($fromB - $toB) * (1 - $pos));
				$color = "rgb(" . $colorR . "," . $colorG . "," . $colorB . ")";
		return $color;
	function print_r_tree($data){
		// capture the output of print_r
		$out = print_r($data, true);
		// replace something like '[element] => <newline> (' with <a href="javascript:toggleDisplay('...');">...</a><div id="..." style="display: none;">
		$out = preg_replace('/([ \t]*)(\[[^\]]+\][ \t]*\=\>[ \t]*[a-z0-9 \t_]+)\n[ \t]*\(/iUe',"'\\1<a href=\"javascript:toggleDisplay(\''.(\$id = substr(md5(rand().'\\0'), 0, 7)).'\');\">\\2</a><div id=\"'.\$id.'\" style=\"display: none;\">'", $out);
		// replace ')' on its own on a new line (surrounded by whitespace is ok) with '</div>
		$out = preg_replace('/^\s*\)\s*$/m', '</div>', $out);
		// print the javascript function toggleDisplay() and then the transformed output
		echo '<script language="Javascript">function toggleDisplay(id) { document.getElementById(id).style.display = (document.getElementById(id).style.display == "block") ? "none" : "block"; }</script>'."\n$out";
	/* ############ MOON FUNCTIONS #################### */
	// Moon rise/set
	class MoonRiSet {
		const RADEG = 57.29577951308232;
		const DEGRAD = 0.01745329251994;
		const ARC = 206264.8;
		const SIN_EPS = 0.39768; // sin+cos obliquity ecliptic (23d26m)
		const COS_EPS = 0.91752;
		const PREC = 18;    // precision
		private $_sinEarthLatitude, $_cosEarthLatitude;
		private $_data = array();
		public function __construct($earthLatitude = false, $earthLongitude = false, $earthTimezone = false) {
			if ($earthLatitude === false)
				$this->earthLatitude = ini_get('date.default_latitude');
			else
				$this->earthLatitude = $earthLatitude;
			if ($earthLongitude === false)
				$this->earthLongitude = ini_get('date.default_longitude');
			else
				$this->earthLongitude = $earthLongitude;
			if ($earthTimezone === false)
				$this->earthTimezone = ini_get('date.timezone');
			else
				$this->earthTimezone = $earthTimezone;
			// set current day
			$this->setDate(date("Y", time()), date("n", time()), date("j", time()));
		// set day
		public function setDate($year, $month, $day) {
			if ($year < 1583 or $year > 2500) return(false);
			$old_timezone = date_default_timezone_get();
			date_default_timezone_set($this->earthTimezone);
			// calculation day's table, begin+end time
			$t = $tb = mktime(0, 0, 0, $month, $day, $year);
			$te = mktime(24, 0, 0, $month, $day, $year);
			$this->tdiff = ($te - $tb) / self::PREC;
			$this->_sinEarthLatitude = $this->dsin($this->earthLatitude);
			$this->_cosEarthLatitude = $this->dcos($this->earthLatitude);
			$i = 0;
			while ($i <= self::PREC) {
				$this->_data[$i]["timestamp"] = $t;
				$jd = $this->getJulianDate($t);
				$LST = $this->getLST($jd); // Local Sidereal Time
				$this->_data[$i]["LST"] = $LST;
				list($RA, $de) = $this->miniMoon(($jd - 2451545.0) / 36525.0);
				$this->_data[$i]["RA"] = $RA;
				$HA = $LST - $RA;    // hour angle
				if ($HA > 12) $HA -= 24;
				$this->_data[$i]["HA"] = $HA;
				$this->_data[$i]["sAlt"] = $this->_sinEarthLatitude * $this->dsin($de) + $this->_cosEarthLatitude * $this->dcos($de) * $this->dcos(15*$this->_data[$i]["HA"]); // sinus Altitude
				$t += $this->tdiff;
				$i++;
			// Moon transit
			list($this->transit["timestamp"], $this->transit["hhmm"], $this->transit["hh:mm"]) = $this->getTransit("HA");
			// Moon's rise and set
			list(
				$this->rise["timestamp"], $this->rise["hhmm"], $this->rise["hh:mm"],
				$this->set["timestamp"], $this->set["hhmm"], $this->set["hh:mm"],
				$this->rise2["timestamp"], $this->rise2["hhmm"], $this->rise2["hh:mm"],
				$this->set2["timestamp"], $this->set2["hhmm"], $this->set2["hh:mm"]
			) = $this->getRiSet("sAlt", $this->dsin(0.125));
			date_default_timezone_set($old_timezone);
			return(true);
		// PRIVATE //////////////////////////////////////////////////////////////////////////////////////////////////////////////////
		private function getTransit($o) {
			$fT = false;
			for ($i = 1; $i < self::PREC && !$fT; $i += 2) {
				if (($this->_data[$i-1][$o] < 0 && $this->_data[$i][$o] >= 0) || ($this->_data[$i][$o] <= 0 && $this->_data[$i+1][$o] > 0)) {
					list($nz, $z1, $z2, $xe, $ye) = $this->quad($this->_data[$i-1][$o], $this->_data[$i][$o], $this->_data[$i+1][$o]);
					$fT = true;
					$oTran = $this->_data[$i]["timestamp"] + $this->tdiff*$z1;
			if ($fT)
				list($transit["timestamp"], $transit["hhmm"], $transit["hh:mm"]) = $this->formatTime($oTran);
			else {
				$transit["timestamp"] = false;
				$transit["hhmm"] = "    ";
				$transit["hh:mm"] = "     ";
			return array($transit["timestamp"], $transit["hhmm"], $transit["hh:mm"]);
		private function getRiSet($o, $alt) {
			$fRise = $fSet = false;
			$fAbove = false;
			$oRise2 = $oSet2 = false;
			if ($this->_data[0][$o] > $alt)
				$fAbove = true;
			for ($i = 1; $i < self::PREC; $i += 2) {
				list($nz, $z1, $z2, $xe, $ye) = $this->quad($this->_data[$i-1][$o]-$alt, $this->_data[$i][$o]-$alt, $this->_data[$i+1][$o]-$alt);
				if ($nz == 1) {
					if ($this->_data[$i-1][$o] < $alt) {
						if ($fRise === true)
							$oRise2 = $this->_data[$i]["timestamp"] + $this->tdiff*$z1;
						else {
							$oRise = $this->_data[$i]["timestamp"] + $this->tdiff*$z1;
							$fRise = true;
					else {
						if ($fSet === true)
							$oSet2 = $this->_data[$i]["timestamp"] + $this->tdiff*$z1;
						else {
							$oSet = $this->_data[$i]["timestamp"] + $this->tdiff*$z1;
							$fSet = true;
				elseif ($nz == 2) {
					if ($ye < 0.0) {
						$oRise = $this->_data[$i]["timestamp"] + $this->tdiff*$z2;
					else {
						$oSet = $this->_data[$i]["timestamp"] + $this->tdiff*$z2;
					$fRise = $fSet = true;
			// output
			if ($fRise === true || $fSet === true ) {
				if ($fRise === true) {
					list($rise["timestamp"], $rise["hhmm"], $rise["hh:mm"]) = $this->formatTime($oRise);
					list($rise2["timestamp"], $rise2["hhmm"], $rise2["hh:mm"]) = $this->formatTime($oRise2);
				else {
					$rise["timestamp"] = false;
					$rise["hhmm"] = "    ";
					$rise["hh:mm"] = "     ";
				if ($fSet === true) {
					list($set["timestamp"], $set["hhmm"], $set["hh:mm"]) = $this->formatTime($oSet);
					list($set2["timestamp"], $set2["hhmm"], $set2["hh:mm"]) = $this->formatTime($oSet2);
				else {
					$set["timestamp"] = true;
					$set["hhmm"] = "    ";
					$set["hh:mm"] = "     ";
			else {
				if ($fAbove === true) { // continuously above horizon
					$rise["timestamp"] = $set["timestamp"] = true;
					$rise["hhmm"] = $set["hhmm"] = "****";
					$rise["hh:mm"] = $set["hh:mm"] = "**:**";
				else { // continuously below horizon
					$rise["timestamp"] = $set["timestamp"] = false;
					$rise["hhmm"] = $set["hhmm"] = "----";
					$rise["hh:mm"] = $set["hh:mm"] = "--:--";
			// return
			if ($oRise2 !== false)
				return array(
					$rise["timestamp"], $rise["hhmm"], $rise["hh:mm"],
					$set["timestamp"], $set["hhmm"], $set["hh:mm"],
					$rise2["timestamp"], $rise2["hhmm"], $rise2["hh:mm"],
					false, false, false);
			elseif ($oSet2 !== false)
				return array(
					false, false, false,
					$set2["timestamp"], $set2["hhmm"], $set2["hh:mm"]);
			else
				return array(
		// Low precision formulae for planetary position, Flandern & Pulkkinen
		// returns ra and dec of Moon to 5 arc min (ra) and 1 arc min (dec)
		// for a few centuries either side of J2000.0
		// Predicts rise and set times to within minutes for about 500 years
		private function miniMoon($T) {
			$l0 = $this->frac(0.606433 + 1336.855225 * $T);
			$l = 2*M_PI * $this->frac(0.374897 + 1325.552410 * $T);
			$ls = 2*M_PI * $this->frac(0.993133 + 99.997361 * $T);
			$d = 2*M_PI * $this->frac(0.827361 + 1236.853086 * $T);
			$f = 2*M_PI * $this->frac(0.259086 + 1342.227825 * $T);
			// perturbation
			$dl =  22640 * sin($l);
			$dl += -4586 * sin($l - 2*$d);
			$dl += +2370 * sin(2*$d);
			$dl +=  +769 * sin(2*$l);
			$dl +=  -668 * sin($ls);
			$dl +=  -412 * sin(2*$f);
			$dl +=  -212 * sin(2*$l - 2*$d);
			$dl +=  -206 * sin($l + $ls - 2*$d);
			$dl +=  +192 * sin($l + 2*$d);
			$dl +=  -165 * sin($ls - 2*$d);
			$dl +=  -125 * sin($d);
			$dl +=  -110 * sin($l + $ls);
			$dl +=  +148 * sin($l - $ls);
			$dl +=   -55 * sin(2*$f - 2*$d);
			$s = $f + ($dl + 412 * sin(2*$f) + 541*sin($ls)) / self::ARC;
			$h = $f - 2*$d;
			$n =   -526 * sin($h);
			$n +=   +44 * sin($l + $h);
			$n +=   -31 * sin(-$l + $h);
			$n +=   -23 * sin($ls + $h);
			$n +=   +11 * sin(-$ls + $h);
			$n +=   -25 * sin(-2*$l + $f);
			$n +=   +21 * sin(-$l + $f);
			$l_moon = 2 * M_PI * $this->frac($l0 + $dl / 1296000);
			$b_moon = (18520.0 * sin($s) + $n) / self::ARC;
			// convert to equatorial coords using a fixed ecliptic
			$cb = cos($b_moon);
			$x = $cb * cos($l_moon);
			$v = $cb * sin($l_moon);
			$w = sin($b_moon);
			$y = self::COS_EPS * $v - self::SIN_EPS * $w;
			$z = self::SIN_EPS * $v + self::COS_EPS * $w;
			$rho = sqrt(1.0 - $z*$z);
			$de = (180/M_PI) * atan($z / $rho);
			$RA = (24/M_PI) * atan($y / ($x + $rho));
			if ($RA < 0) $RA += 24;
			return(array($RA, $de));
		// finds the parabola through the three points (-1,ym), (0,yz), (1, yp) and returns
		// the coordinates of the values of x where the parabola crosses zero (roots of the quadratic)
		// and the number of roots (0, 1 or 2) within the interval [-1, 1]
		private function quad($ym, $yz, $yp) {
			$z1 = $z2 = 0;
			$nz = 0;
			$a = 0.5 * ($ym + $yp) - $yz;
			$b = 0.5 * ($yp - $ym);
			$c = $yz;
			$xe = -$b / (2 * $a);
			$ye = ($a * $xe + $b) * $xe + $c;
			$dis = $b * $b - 4.0 * $a * $c;
			if ($dis > 0) {
				$dx = 0.5 * sqrt($dis) / abs($a);
				$z1 = $xe - $dx;
				$z2 = $xe + $dx;
				if (abs($z1) <= 1.0) $nz += 1;
				if (abs($z2) <= 1.0) $nz += 1;
				if ($z1 < -1.0) $z1 = $z2;
			return(array($nz, $z1, $z2, $xe, $ye));
		private function getJulianDate($t) {
			//return $t/86400 + 2440587.5; // only for 64bit && year > 1582
			$jd = gregoriantojd(gmdate("n", $t) ,gmdate("j", $t) , gmdate("Y", $t)) - 0.5;
			$jd += gmdate("H", $t)/24 + gmdate("i", $t)/1440 + gmdate("s", $t)/86400;
			return($jd);
		// returns the local sidereal time (degree)
		private function getLST($jd) {
			$mjd = $jd - 2451545.0;
			$lst = $this->range(280.46061837 + 360.98564736629 * $mjd);
			return ($lst + $this->earthLongitude)/15;
		// round time, return array(timestamp, "hhmm", "hh:mm")
		private function formatTime($t) {
			$t0 = 60*(int)($t/60+0.5);
			if (date("j", $t) == date("j", $t0))
				$t = $t0;
			return array($t, date("Hi", $t), date("H:i", $t));
		private function frac($x) {
			return($x - floor($x));
		private function range($x) {
			return($x - 360.0 * (Floor($x / 360.0)));
		private function dsin($x) {
			return(sin($x * self::DEGRAD));
		private function dcos($x) {
			return(cos($x * self::DEGRAD));
	function special(){
		global $pageURL;
		global $path;
		global $stationLat;
		global $stationCountry;
		$timestampNow = time();
		$icon = "fa fa-home";
		if(date('m',$timestampNow)==1 && date('d',$timestampNow)==1){
			$icon = "fa fa-glass";
		if(date('m',$timestampNow)==12 && date('d',$timestampNow)==31){
			$icon = "fa fa-hourglass-end";
		if(date('m',$timestampNow)==12 && date('d',$timestampNow)==24){
			$icon = "fa fa-gift";
		if(date('m',$timestampNow)==12 && date('d',$timestampNow)==25){
		if(date('m',$timestampNow)==12 && date('d',$timestampNow)>=20 && date('d',$timestampNow)<24){
			$icon = "fa fa-tree";
		if(date('m',$timestampNow)==3 && date('d',$timestampNow)==21){
			if($stationLat>0){
				$icon = "mticon-spring";
			else{
				$icon = "mticon-autumn";
		if(date('m',$timestampNow)==6 && date('d',$timestampNow)==21){
			if($stationLat>0){
				$icon = "mticon-summer";
			else{
				$icon = "mticon-winter";
		if(date('m',$timestampNow)==9 && date('d',$timestampNow)==23){
			if($stationLat>0){
			else{
		if(date('m',$timestampNow)==12 && date('d',$timestampNow)==21){
			if($stationLat>0){
			else{
		if($stationCountry=="us"){
			if(date('Y',$timestampNow)==2017){
				if(date('m',$timestampNow)==11 && date('d',$timestampNow)==23){
					$icon = "fa fa-cutlery";
			if(date('Y',$timestampNow)==2018){
				if(date('m',$timestampNow)==11 && date('d',$timestampNow)==22){
			if(date('Y',$timestampNow)==2019){
				if(date('m',$timestampNow)==11 && date('d',$timestampNow)==28){
		if($stationCountry=="ca"){
				if(date('m',$timestampNow)==10 && date('d',$timestampNow)==9){
				if(date('m',$timestampNow)==10 && date('d',$timestampNow)==8){
				if(date('m',$timestampNow)==10 && date('d',$timestampNow)==14){
		if(date('m',$timestampNow)==10 && date('d',$timestampNow)==31){
			$icon = "fa fa-meh-o";
			if(date('m',$timestampNow)==4 && date('d',$timestampNow)==16){
			if(date('m',$timestampNow)==4 && date('d',$timestampNow)==1){
			if(date('m',$timestampNow)==4 && date('d',$timestampNow)==21){
		return $icon;
	$fooCont = file_get_contents($baseURL."/footer.php");
	if (strpos(strtolower($fooCont), 'meteotemplate.com') == false) {
		echo "<!-- Error -->Error, contact the developer.";
		die();
	// Moonphase
	define('MP_NEW_MOON_NAME','New moon');
	define('MP_NEW_MOON_ID',0);
	define('MP_WAXING_CRESCENT_NAME','Waxing crescent');
	define('MP_WAXING_CRESCENT_ID',1);
	define('MP_FIRST_QUARTER_NAME','First quarter');
	define('MP_FIRST_QUARTER_ID',2);
	define('MP_WAXING_GIBBOUS_NAME','Waxing gibbous');
	define('MP_WAXING_GIBBOUS_ID',3);
	define('MP_FULL_MOON_NAME','Full');
	define('MP_FULL_MOON_ID',4);
	define('MP_WANING_GIBBOUS_NAME','Waning gibbous');
	define('MP_WANING_GIBBOUS_ID',5);
	define('MP_THIRD_QUARTER_MOON_NAME','Third quarter');
	define('MP_THIRD_QUARTER_MOON_ID',6);
	define('MP_WANING_CRESCENT_NAME','Waning crescent');
	define('MP_WANING_CRESCENT_ID',7);
	define('MP_DAY_IN_SECONDS', 60 * 60 * 24);
	class moonPhase {
		var $allMoonPhases = array();
		var $dateAsTimeStamp;
		var $moonPhaseIDforDate;
		var $moonPhaseNameForDate;
		var $periodInDays = 29.53058867; // == complete moon cycle
		var $periodInSeconds = -1; // gets set when you ask for it
		var $someFullMoonDate;
		// $timestamp (int) date of which to calculate a moon phase and relative phases for
		function __construct($timeStamp = -1) {
			$this->allMoonPhases = array(
				MP_NEW_MOON_NAME,
				MP_WAXING_CRESCENT_NAME,
				MP_FIRST_QUARTER_NAME,
				MP_WAXING_GIBBOUS_NAME,
				MP_FULL_MOON_NAME,
				MP_WANING_GIBBOUS_NAME,
				MP_THIRD_QUARTER_MOON_NAME,
				MP_WANING_CRESCENT_NAME);
			$this->someFullMoonDate = strtotime("March 5 2015 18:05 UTC");
			if($timeStamp == '' or $timeStamp == -1) $timeStamp = time();
			$this->setDate($timeStamp);
		function calcMoonPhase() {
			$position = $this->getPositionInCycle();
			if($position >= 0.474 && $position <= 0.53)
				$phaseInfoForCurrentDate = array(MP_NEW_MOON_ID, MP_NEW_MOON_NAME);
			else if ($position >= 0.53 && $position <= 0.724)
				$phaseInfoForCurrentDate = array(MP_WAXING_CRESCENT_ID, MP_WAXING_CRESCENT_NAME);
			else if ($position >= 0.724 && $position <= 0.776)
				$phaseInfoForCurrentDate = array(MP_FIRST_QUARTER_ID, MP_FIRST_QUARTER_NAME);
			else if ($position >= 0.776 && $position <= 0.974)
				$phaseInfoForCurrentDate = array(MP_WAXING_GIBBOUS_ID, MP_WAXING_GIBBOUS_NAME);
			else if ($position >= 0.974 || $position <= 0.026)
				$phaseInfoForCurrentDate = array(MP_FULL_MOON_ID, MP_FULL_MOON_NAME);
			else if ($position >= 0.026 && $position <= 0.234)
				$phaseInfoForCurrentDate = array(MP_WANING_GIBBOUS_ID, MP_WANING_GIBBOUS_NAME);
			else if ($position >= 0.234 && $position <= 0.295)
				$phaseInfoForCurrentDate = array(MP_THIRD_QUARTER_MOON_ID, MP_THIRD_QUARTER_MOON_NAME);
			else if ($position >= 0.295 && $position <= 0.4739)
				$phaseInfoForCurrentDate = array(MP_WANING_CRESCENT_ID, MP_WANING_CRESCENT_NAME);
			list($this->moonPhaseIDforDate,$this->moonPhaseNameForDate) = $phaseInfoForCurrentDate;
		function getAllMoonPhases() {
			return $this->allMoonPhases;
		function getBaseFullMoonDate() {
			return $this->someFullMoonDate;
		function getDateAsTimeStamp() {
			return $this->dateAsTimeStamp;
		function getDaysUntilNextFullMoon() {
			return round((1 - $position) * $this->getPeriodInDays(), 7);
		function getDaysUntilNextLastQuarterMoon() {
			$days = 0;
			if ($position < 0.25)
				$days = (0.25 - $position) * $this->getPeriodInDays();
			else if ($position >= 0.25)
				$days = (1.25 - $position) * $this->getPeriodInDays();
			return round($days, 7);
		function getDaysUntilNextFirstQuarterMoon() {
			$days = 0;
			if ($position < 0.75)
				$days = (0.75 - $position) * $this->getPeriodInDays();
			else if ($position >= 0.75)
				$days = (1.75 - $position) * $this->getPeriodInDays();
			return round($days,7);
		function getDaysUntilNextNewMoon() {
			$days = 0;
			if ($position < 0.5)
				$days = (0.5 - $position) * $this->getPeriodInDays();
			else if ($position >= 0.5)
				$days = (1.5 - $position) * $this->getPeriodInDays();
		function getPercentOfIllumination() {
			$percentage = (1.0 + cos(2.0 * M_PI * $this->getPositionInCycle())) / 2.0;
			$percentage *= 100;
			$percentage = round($percentage,1) . '%';
			return $percentage;
		function getPeriodInDays() {
			return $this->periodInDays;
		function getPeriodInSeconds() {
			if($this->periodInSeconds > -1) return $this->periodInSeconds; // in case it was cached
			$this->periodInSeconds = $this->getPeriodInDays() * MP_DAY_IN_SECONDS;
		function getPhaseID() {
			return $this->moonPhaseIDforDate;
		function getPhaseName($ID = -1) {
			if($ID <= -1)
				return $this->moonPhaseNameForDate; // get name for this current date
			return $this->allMoonPhases[$ID]; // or.. get name for a specific ID
		function getPositionInCycle() {
			$diff = $this->getDateAsTimeStamp() - $this->getBaseFullMoonDate();
			$periodInSeconds = $this->getPeriodInSeconds();
			$position = ($diff % $periodInSeconds) / $periodInSeconds;
			if ($position < 0)
				$position = 1 + $position;
			return $position;
		function getUpcomingWeekArray($newStartingDateAsTimeStamp = -1) {
			$newStartingDateAsTimeStamp = ($newStartingDateAsTimeStamp > -1)
				? $newStartingDateAsTimeStamp
				: $this->getDateAsTimeStamp();
			$moonPhaseObj = get_class($this);
			$weeklyPhase = new $moonPhaseObj($newStartingDateAsTimeStamp);
			$upcomingWeekArray = array();
			for(	$day = 0, $thisTimeStamp = $weeklyPhase->getDateAsTimeStamp();
						$day < 7; $day++, $thisTimeStamp += MP_DAY_IN_SECONDS) {
				$weeklyPhase->setDate($thisTimeStamp);
				$upcomingWeekArray[$thisTimeStamp] = $weeklyPhase->getPhaseID();
			} // END for($day = 0; $day < 7; $day++) {
			unset($weeklyPhase);
			return $upcomingWeekArray;
		function setDate($timeStamp = -1) {
			$this->dateAsTimeStamp = $timeStamp;
			$this->calcMoonPhase();
----------------------------------------------ERRORS-------------------------------------------------
Deprecated: Function date_sunrise() is deprecated in /var/www/hurricanepub/template/homepage/blocks/summary/summaryBlock.php on line 103
Deprecated: Function date_sunset() is deprecated in /var/www/hurricanepub/template/homepage/blocks/summary/summaryBlock.php on line 104
Deprecated: Function date_sunrise() is deprecated in /var/www/hurricanepub/template/homepage/blocks/summary/summaryBlock.php on line 107
Deprecated: Function date_sunset() is deprecated in /var/www/hurricanepub/template/homepage/blocks/summary/summaryBlock.php on line 108
Deprecated: Function date_sunrise() is deprecated in /var/www/hurricanepub/template/homepage/blocks/summary/summaryBlock.php on line 111
Deprecated: Function date_sunset() is deprecated in /var/www/hurricanepub/template/homepage/blocks/summary/summaryBlock.php on line 112
Deprecated: Implicit conversion from float 2551442.8610880002 to int loses precision in /var/www/hurricanepub/template/scripts/functions.php on line 1218
Deprecated: Implicit conversion from float 1692208338.6023512 to int loses precision in /var/www/hurricanepub/template/scripts/functions.php on line 952
Deprecated: Implicit conversion from float 1692183888.8787467 to int loses precision in /var/www/hurricanepub/template/scripts/functions.php on line 952
Deprecated: Implicit conversion from float 1692232484.8760638 to int loses precision in /var/www/hurricanepub/template/scripts/functions.php on line 952
Deprecated: Implicit conversion from float 1692297236.82949 to int loses precision in /var/www/hurricanepub/template/scripts/functions.php on line 952
Deprecated: Implicit conversion from float 1692273457.5147862 to int loses precision in /var/www/hurricanepub/template/scripts/functions.php on line 952
Deprecated: Implicit conversion from float 1692320678.6056345 to int loses precision in /var/www/hurricanepub/template/scripts/functions.php on line 952
Warning: Undefined array key "next_1_hours" in /var/www/hurricanepub/template/homepage/blocks/summary/summaryBlock.php on line 1689
Warning: Trying to access array offset on value of type null in /var/www/hurricanepub/template/homepage/blocks/summary/summaryBlock.php on line 1689
You can see the errors with the new Functions.php that wont load tHE SUMMARY Block
here https://hurricanepub.com/template/homep ... php?errors
Davis Pro 2
Meteobridge Pro2
GW 2000
spd2612
Post by spd2612 » Wed Aug 16, 2023 11:14 pm
Just a FYI I added a few lines of code to the functions.php just to get rid of the FATAL error to enable the Summary block to load, It does throw allot of Deprecated: Implicit conversion from float and Warnings in the Summary Block, however it is functioning in hopes that the Summary Block will eventually get fixed. The Template seems to be functioning fine In Cranberry.
I dont believe this is affecting anything else
At Line 32 I added
// difference
	function count8($a)
           return count($a);
   	   else
   	       return 0;
	 // End Of Difference
Davis Pro 2
Meteobridge Pro2
GW 2000
Post by Jachym » Sun Aug 20, 2023 1:06 pm
didoujm wrote: Wed Aug 16, 2023 3:24 pm Hello Jackim
Weather mirepoix
I solved my problem
your page works fine for me. The fact it is loading http by default needs to be set up on your server, this is not controlled by the template. You need to add redirect commands in your .htaccess file to redirect all http traffic to https.
Post by Jachym » Sun Aug 20, 2023 1:07 pm
tobydude wrote: Wed Aug 16, 2023 2:11 pm
looking at your page, it seems to be working fine. The fact NetAtmo is not working is because NetAtmo has changed its API. This is most likely the reason it is not being updated in WeatherDisplay and the NetAtmo block from Meteotemplate will also need an update. The original API is no longer working.
tobydude
Post by tobydude » Sun Aug 20, 2023 2:11 pm
Jachym wrote: Sun Aug 20, 2023 1:07 pm
Thanks for info. The weatherpage works because I em still using php 7.4.
Post by Jachym » Sun Aug 20, 2023 2:35 pm
The update is now available on the main website, update instructions are available on the blog page.
NOTE:
If you have already tested the update folder I posted here previously, please still make sure you do the update, I changed a few things and there are 3 new update files in the final update file.
You have two options:
- do the update manually, just like you did during the testing
- do the update using the automated script - in this case you need to change the template version manually back to 18.0, otherwise it wont let you do the update. This can be done by opening config.php in your template root via FTP client and right at the top on the line where version is specified, change it to 18.0, save and re-upload.
Post by alexvanuxem » Sun Aug 20, 2023 3:58 pm
FANTASTIC , GOOD JOB!!!!
Post by alexvanuxem » Sun Aug 20, 2023 5:17 pm
sorry doesn't work for me
not the manual way nor the automatic way.
after both ways, in between a reloaded the working backup a few post ago, I only see the banner, saying a 19.0 upgrade is available
GRtz
tobydude
Post by tobydude » Sun Aug 20, 2023 5:53 pm
I see I already use Meteotemplate 19.0 Cranberry
Must I change back to 18.0 Papaya to get this new update?
And how do I do that? :)
I get this message when I try to set the template back to V. 18:
"This update script is intended for updating from version 17.2 to 18.0, you seem to be using a newer version of the template so this update is not necessary."
Post by alexvanuxem » Sun Aug 20, 2023 8:36 pm
I narrowed the issue down to the functions.php inside the official token download: it's not working.
the functions.php a few post ago is.
I got 19.0 cranberry in the end!
although it's loading very slowly but it works
grtz
A
spd2612
Post by spd2612 » Sun Aug 20, 2023 10:11 pm
@ Jachym
Updated from main web site, Updated manually all went well Everything I have tested seems fine
Still get the issue with the summary block 5.8 not loading But that's probably the Block, I have figured out how to get it to load by adding some code to the functions PHP but I know thats a bad patch.
Good Job I will continue to look for issues
Davis Pro 2
Meteobridge Pro2
GW 2000
legi
Station model: Vantage 2 pro
Post by legi » Mon Aug 21, 2023 6:21 am
Hi Jachym
I got files from you last week for testing and it seems all ok. Should I just stay as it is or should I download you cranberry update as stated in the Blog
Peter Buehrer, Wetter in Henngart https://www.buehrer.com/page-3/index.php
tobydude
Post by tobydude » Mon Aug 21, 2023 8:31 am
tobydude wrote: Sun Aug 20, 2023 5:53 pm
Sorry. Dint read it all. :roll:
steph
Station model: Ecowitt
Post by steph » Mon Aug 21, 2023 9:00 am
For my part perfect update with PHP 7.4.33
Many thanks Jachim
Post by alexvanuxem » Mon Aug 21, 2023 5:16 pm
now working thx too Jachym.
Did any one notice missing icons (turning MT icon when refreshing), the 3 stripes on the left of each block?
GRTZ
Post by Jachym » Mon Aug 21, 2023 5:57 pm
Post by alexvanuxem » Tue Aug 22, 2023 9:13 am
Hi Jachym,
I'm using 8.2.
I asked my provider and mysqli, mysqlnd, pdo_mysql and pdo_sqlite are enabled.
I'm using the latest functions.php that you send me by mail.
Since the whole official release some days ago, the icons mentioned above are missing.
You can it check at www.sint-katelijne-waver-meteo.be/template
you still got my admin password to troubleshoot if needed.
(so the issue remains, sorry).
cheers
Alex
Bigbaywx
Station model: Davis Vantate Pro2
Software: weatherlink data logger
Post by Bigbaywx » Tue Aug 22, 2023 7:11 pm
Flawless update with no pain. Just a matter of following the instructions.
Thanks Jachym!!
Wetter_Saal_io
Station model: GW1000/WS80/WH40/WH57
Post by Wetter_Saal_io » Wed Aug 23, 2023 6:32 am
Hello Jachym,
Update installed with no problems.
However, there is one conspicuous feature: in the "Interactive Graph" block, the time is shifted forward by 2 hours when the website is called up. If another graph is called, the timeline is corrected.
Greetings Stefan
GW1000 mit WS80,WH40 und WH57
Meteotime Duo
Raspberry pi 3+ mit Meteobridge
Ecowitt 54290, Awekas 19941, weather365 8337
www.wetter-saal-io.de
Post by Jachym » Wed Aug 23, 2023 1:15 pm
alexvanuxem wrote: Tue Aug 22, 2023 9:13 am Hi Jachym,
I'm using 8.2.
cheers
Alex
I see that for example the menu icons are missing. The file the template is trying to load is this:
https://www.sint-katelijne-waver-meteo. ... nuDark.png
The icons/menuDark.png icon should be present and therefore loaded. Can you check if this file for example is on your server? When I try clicking it it shows Not found.
