If I use the attached Functions.php instead of the one @jachym put up it gets rid of the Fatal error in the Summary5.8 block but produces a whole lot more warnings, However the Summary Block does load
<?php
# Meteotemplate
# http://www.meteotemplate.com
# Free website template for weather enthusiasts
# Author: Jachym
# Brno, Czech Republic
# First release: 2015
# Main functions
# A script which contains the main functions used by the template.
# v17.2 Nectarine 2019-06-27
if (function_exists('mb_internal_encoding')) {
mb_internal_encoding('UTF-8');
mb_http_output('UTF-8');
//mb_http_input('UTF-8');
mb_language('uni');
mb_regex_encoding('UTF-8');
function count8($a)
if ((PHP_VERSION_ID < 70300) || (is_countable($a)))
return count($a);
else
return 0;
function lang($string,$case="-"){
global $language;
global $lang;
// check if the word exists in the main Meteotemplate translation files and there is translation for it
if (array_key_exists($string, $language[$lang])&&($language[$lang][$string]!="")) {
$str = utf8_encode($language[$lang][$string]);
if($case=="l"){
$str = utf8_encode(mb_strtolower(utf8_decode($str)));
if($case=="u"){
$str = utf8_encode(mb_strtoupper(utf8_decode($str)));
if($case=="c"){
$str = ucfirst($str);
if($case=="w"){
$str = ucwords($str);
if($case=="-"){
$str = ($str);
else{
if($case=="l"){
$str = utf8_encode(strtolower(utf8_decode($str)));
if($case=="u"){
$str = utf8_encode(strtoupper(utf8_decode($str)));
if($case=="c"){
if($case=="w"){
if($case=="-"){
$str = ($str);
else{
if (isset($language['us']) && array_key_exists($string, $language['us'])) { // string exists, but is not yet translated, we return english equivalent
$str = $language['us'][$string];
if($case=="l"){
$str = strtolower($str);
if($case=="u"){
$str = strtoupper($str);
if($case=="c"){
if($case=="w"){
if($case=="-"){
$str = ($str);
else{ // if it is customized translation we just format and return
$str = $string;
if($case=="l"){
if($case=="u"){
if($case=="c"){
if($case=="w"){
if($case=="-"){
$str = ($str);
return utf8_decode($str);
function loadLangs(){
global $baseURL;
global $lang;
$languageRaw = file_get_contents($baseURL."lang/gb.php");
$language['gb'] = json_decode($languageRaw,true);
$languageRaw = file_get_contents($baseURL."lang/".$lang.".php");
$language[$lang] = json_decode($languageRaw,true);
return $language;
function mySQLGET($query){
global $con;
$thisQuery = mysqli_query($con, $query);
if(error_reporting() != 0){
if(!$thisQuery){
echo("Meteotemplate MySQL Error: " . mysqli_error($con));
if($thisQuery){
return mysqli_fetch_array($thisQuery);
function isHTTPS() {
return
(!empty($_SERVER['HTTPS']) && $_SERVER['HTTPS'] !== 'off')
|| $_SERVER['SERVER_PORT'] == 443;
function convertor($n,$unit1,$unit2){
// prepare input
$unit1 = trim(strtolower($unit1));
$unit2 = trim(strtolower($unit2));
$unit1 = str_replace("/","",$unit1);
$unit2 = str_replace("/","",$unit2);
$unit1 = str_replace("kts","kt",$unit1);
$unit2 = str_replace("kts","kt",$unit2);
$unit1 = str_replace("knots","kt",$unit1);
$unit2 = str_replace("knots","kt",$unit2);
$unit1 = str_replace("kph","kmh",$unit1);
$unit2 = str_replace("kph","kmh",$unit2);
$unit1 = str_replace("mb","hpa",$unit1);
$unit2 = str_replace("mb","hpa",$unit2);
$unit1 = str_replace("miles","mi",$unit1);
$unit2 = str_replace("miles","mi",$unit2);
$unit1 = str_replace("feet","ft",$unit1);
$unit2 = str_replace("feet","ft",$unit2);
$unit1 = str_replace("foot","ft",$unit1);
$unit2 = str_replace("foot","ft",$unit2);
// return same units
if($unit1==$unit2){
return $n;
// temperature
else if($unit1=="c" && $unit2=="f"){
return $n*1.8 + 32;
else if($unit1=="f" && $unit2=="c"){
return ($n - 32)/1.8;
// wind speed
else if($unit1=="ms" && $unit2=="kmh"){
return $n * 3.6;
else if($unit1=="ms" && $unit2=="mph"){
return $n * 2.23694;
else if($unit1=="ms" && $unit2=="kt"){
return $n * 1.943844;
else if($unit1=="kmh" && $unit2=="ms"){
return $n / 3.6;
else if($unit1=="kmh" && $unit2=="mph"){
return $n * 0.621371;
else if($unit1=="kmh" && $unit2=="kt"){
return $n * 0.539957;
else if($unit1=="mph" && $unit2=="ms"){
return $n * 0.44704;
else if($unit1=="mph" && $unit2=="kmh"){
return $n * 1.609344;
else if($unit1=="mph" && $unit2=="kt"){
return $n * 0.868976;
else if($unit1=="kt" && $unit2=="ms"){
return $n * 0.514444;
else if($unit1=="kt" && $unit2=="kmh"){
return $n * 1.852;
else if($unit1=="kt" && $unit2=="mph"){
return $n * 1.150779;
// pressure
else if($unit1=="hpa" && $unit2=="inhg"){
return $n * 0.02952998;
else if($unit1=="hpa" && $unit2=="mmhg"){
return $n * 0.750063755;
else if($unit1=="inhg" && $unit2=="hpa"){
return $n * 33.863881;
else if($unit1=="inhg" && $unit2=="mmhg"){
return $n * 25.400069;
else if($unit1=="mmhg" && $unit2=="hpa"){
return $n * 1.3332239;
else if($unit1=="mmhg" && $unit2=="inhg"){
return $n * 0.03937;
// precipitation
else if($unit1=="mm" && $unit2=="in"){
return $n * 0.0393701;
else if($unit1=="in" && $unit2=="mm"){
return $n * 25.4;
else if($unit1=="mm" && $unit2=="cm"){
return $n * 0.1;
else if($unit1=="cm" && $unit2=="mm"){
return $n * 10;
// distance
else if($unit1=="km" && $unit2=="mi"){
else if($unit1=="mi" && $unit2=="km"){
return $n * 1.60934;
else if($unit1=="km" && $unit2=="ft"){
return $n * 3280.84;
else if($unit1=="ft" && $unit2=="km"){
return $n * 0.0003048;
else if($unit1=="m" && $unit2=="ft"){
return $n * 3.28084;
else if($unit1=="ft" && $unit2=="m"){
return $n * 0.3048;
function convertT($value){
global $dataTempUnits;
global $displayTempUnits;
$formats = $dataTempUnits.$displayTempUnits;
if($formats=="CC"){
return $value;
if($formats=="CF"){
return round((($value*1.8)+32),3);
if($formats=="FC"){
return round((($value-32)/1.8),3);
if($formats=="FF"){
return $value;
function convertTStddev($value){
if($formats=="CC"){
return $value;
if($formats=="CF"){
return $value*1.8;
if($formats=="FC"){
return $value/1.8;
if($formats=="FF"){
return $value;
function convertW($value){
global $dataWindUnits;
global $displayWindUnits;
$formats = $dataWindUnits.$displayWindUnits;
if($dataWindUnits==$displayWindUnits){
return $value;
if($formats=="mskmh"){
return round(($value*3.6),3);
if($formats=="msmph"){
return round(($value*2.23694),3);
if($formats=="kmhms"){
return round(($value/3.6),3);
if($formats=="kmhmph"){
return round(($value*0.621371),3);
if($formats=="mphms"){
return round(($value*0.44704),3);
if($formats=="mphkmh"){
return round(($value*1.609344),3);
if($formats=="mskt"){
return round(($value*1.943844),3);
if($formats=="kmhkt"){
return round(($value*0.539957),3);
if($formats=="mphkt"){
return round(($value*0.868976),3);
if($formats=="ktms"){
return round(($value*0.514444),3);
if($formats=="ktkmh"){
return round(($value*1.852),3);
if($formats=="ktmph"){
return round(($value*1.150779),3);
function convertP($value){
global $dataPressUnits;
global $displayPressUnits;
$formats = $dataPressUnits.$displayPressUnits;
if($dataPressUnits==$displayPressUnits){
return $value;
if($formats=="hpammhg"){
return round(($value*0.75006375541921),3);
if($formats=="hpainhg"){
return round(($value*0.0295299830714),3);
if($formats=="mmhghpa"){
return round(($value*1.3332239),3);
if($formats=="mmhginhg"){
return round(($value*0.03937),3);
if($formats=="inhghpa"){
return round(($value*33.863881579),3);
if($formats=="inhgmmhg"){
return round(($value*25.400069),3);
function convertR($value){
global $dataRainUnits;
global $displayRainUnits;
$formats = $dataRainUnits.$displayRainUnits;
if($formats=="mmmm"){
return $value;
if($formats=="mmin"){
return round(($value*0.0393701),3);
if($formats=="inmm"){
return round(($value*25.4),3);
if($formats=="inin"){
return $value;
function unitFormatter($unit){
$unit = str_replace('kmh','km/h',$unit);
$unit = str_replace('ms','m/s',$unit);
$unit = str_replace('inhg','inHg',$unit);
$unit = str_replace('hpa','hPa',$unit);
$unit = str_replace('mmhg','mmHg',$unit);
$unit = str_replace('C','°C',$unit);
$unit = str_replace('F','°F',$unit);
return $unit;
function cleanHTML($html){
$html = preg_replace("/\n/", "", $html);
$html = preg_replace('/\s+/', ' ', $html);
return $html;
function createCacheDir(){
if(!is_dir("cache")){
mkdir("cache");
function showLog($errorLog){
foreach($errorLog as $entry){
if($entry[0]=="e"){
echo "<script>console.error('Meteotemplate Error: ".$entry[1]."');</script>";
else if($entry[0]=="w"){
echo "<script>console.warn('Meteotemplate Warning: ".$entry[1]."');</script>";
else{
echo "<script>console.log('Meteotemplate: ".$entry[1]."');</script>";
function getColorHue($colorString,$type){
if($type=="hex"){
$rgb = convertColor($colorString);
if ($rgb['r'] + $rgb['g'] + $rgb['b'] > 382){
return "light";
else{
return "dark";
else{
$colorBreakDown = str_replace("rgb(","",$colorString);
$colorBreakDown = str_replace(")","",$colorBreakDown);
$colorBreakDown = explode(",",$colorBreakDown);
if ($colorBreakDown[0] + $colorBreakDown[1] + $colorBreakDown[2] > 382){
return "light";
else{
return "dark";
function convertColor($hex, $alpha = false) {
$hex = str_replace('#', '', $hex);
$length = strlen($hex);
$rgb['r'] = hexdec($length == 6 ? substr($hex, 0, 2) : ($length == 3 ? str_repeat(substr($hex, 0, 1), 2) : 0));
$rgb['g'] = hexdec($length == 6 ? substr($hex, 2, 2) : ($length == 3 ? str_repeat(substr($hex, 1, 1), 2) : 0));
$rgb['b'] = hexdec($length == 6 ? substr($hex, 4, 2) : ($length == 3 ? str_repeat(substr($hex, 2, 1), 2) : 0));
if ( $alpha ) {
$rgb['a'] = $alpha;
return $rgb;
function avgWind($directions) { // based on http://en.wikipedia.org/wiki/Yamartino_method
$sinSum = 0;
$cosSum = 0;
foreach ($directions as $value) {
$sinSum += sin(deg2rad($value));
$cosSum += cos(deg2rad($value));
return ((rad2deg(atan2($sinSum, $cosSum)) + 360) % 360);
function windAbb($value){
if($value<=11.25){
return "N";
if($value>11.25 && $value<=33.75){
return "NNE";
if($value>33.75 && $value<=56.25){
return "NE";
if($value>56.25 && $value<=78.75){
return "ENE";
if($value>78.75 && $value<=101.25){
return "E";
if($value>101.25 && $value<=123.75){
return "ESE";
if($value>123.75 && $value<=146.25){
return "SE";
if($value>146.25 && $value<=168.75){
return "SSE";
if($value>168.75 && $value<=191.25){
return "S";
if($value>191.25 && $value<=213.75){
return "SSW";
if($value>213.75 && $value<=236.25){
return "SW";
if($value>236.25 && $value<=258.75){
return "WSW";
if($value>258.75 && $value<=281.25){
return "W";
if($value>281.25 && $value<=303.75){
return "WNW";
if($value>303.75 && $value<=326.25){
return "NW";
if($value>326.25 && $value<=348.75){
return "NNW";
if($value>348.75){
return "N";
function curlMain($url,$timeout){
$ch = curl_init();
curl_setopt($ch, CURLOPT_HEADER, 0);
curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
curl_setopt($ch, CURLOPT_URL, $url);
curl_setopt($ch, CURLOPT_CONNECTTIMEOUT, $timeout);
curl_setopt($ch, CURLOPT_USERAGENT,"Mozilla/5.0 (Windows NT 6.1; rv:19.0) Gecko/20100101 Firefox/19.0");
$data = curl_exec($ch);
curl_close($ch);
return $data;
function loadContent($url,$timeout){
$ch = curl_init();
curl_setopt($ch, CURLOPT_USERAGENT,"Mozilla/5.0 (Windows NT 6.1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/41.0.2228.0 Safari/537.36");
curl_close($ch);
if($data==""){
$data = file_get_contents($url);
return $data;
function solarMax($time,$lat,$lon,$elevation,$elevationUnits){
if($elevationUnits=="ft"){
$z = 0.3048 * $elevation;
else{
$z = $elevation;
$atc = 0.8;
$lw = (M_PI / 180) * -$lon;
$phi = (M_PI / 180) * $lat;
$d = ($time / (60 * 60 * 24) - 0.5 + 2440588) - 2451545;
$M = (M_PI / 180) * (357.5291 + 0.98560028 * $d);
$L = ((M_PI / 180) * (1.9148 * sin($M) + 0.02 * sin(2 * $M) + 0.0003 * sin(3 * $M))) + $M + (M_PI / 180) * 102.9372 + M_PI;
$declin = asin(sin(0) * cos(((M_PI / 180) * 23.4397)) + cos(0) * sin(((M_PI / 180) * 23.4397)) * sin($L));
$rightAsc = atan2(sin($L) * cos(((M_PI / 180) * 23.4397)) - tan(0) * sin(((M_PI / 180) * 23.4397)), cos($L));
$H = ((M_PI / 180) * (280.16 + 360.9856235 * $d) - $lw) - $rightAsc;
$altitude = asin(sin($phi) * sin($declin) + cos($phi) * cos($declin) * cos($H));
$altitude = $altitude * 180 / M_PI;
$JD = $time / (60 * 60 * 24) - 0.5 + 2440588;
$dayTime = ($time - strtotime(date("Y",$time)."-".date("m",$time)."-".date('d',$time)." 00:00"))/(24*60*60*1000);
$t = ($JD + $dayTime -2451545.0)/36525;
$eccentricity = 0.01678634 + 0.000042037*$t + 0.0000001267*$t*$t;
$mean_anomaly = 357.52911+ 35999.05029*$t + 0.0001537*$t*$t;
if($mean_anomaly<0){
$mean_anomaly=$mean_anomaly%360+360;
if($mean_anomaly>360){
$mean_anomaly=$mean_anomaly%360;
$c = (1.914602 - 0.004817*$t + 0.000014*$t*$t)*sin($mean_anomaly*(M_PI / 180));
$c =$c+ (0.019993 - 0.000101*$t)*sin(2*$mean_anomaly*(M_PI / 180));
$c =$c+ 0.000289 *sin(3*$mean_anomaly*(M_PI / 180));
$true_anomary = $mean_anomaly + $c;
$radius = (1.000001018*(1-$eccentricity*$eccentricity))/(1 + $eccentricity*cos($true_anomary*(M_PI / 180)));
$distance= $radius * 149598000;
$el = $altitude;
$R = $radius;
$nrel = 1367.0;
$sinal = sin(deg2rad($el));
if($sinal >= 0){
$rm = pow((288.0 - 0.0065 * $z) / 288.0, 5.256) / ($sinal + 0.15 * pow($el + 3.885, -1.253));
$toa = $nrel * $sinal / ($R * $R);
$sr = $toa * pow($atc, $rm);
else{
$sr = 0;
return $sr;
/* ############ COLOR FILL ######################## */
function fill($value,$stops,$colors) {
global $fromR, $fromG, $fromB;
global $toR, $toG, $toB;
for ($i = 0; $i < count($stops); $i++) {
if ($value > $stops[$i] && $value <= $stops[$i + 1]) {
$pos = ($value - $stops[$i]) * (1 / ($stops[$i + 1] - $stops[$i]));
$minimum_color = $colors[$i];
$maximum_color = $colors[$i + 1];
$minimum_color = str_replace("#", "", $minimum_color);
if (strlen($minimum_color) == 3) {
$fromR = hexdec(substr($minimum_color, 0, 1) . substr($minimum_color, 0, 1));
$fromG = hexdec(substr($minimum_color, 1, 1) . substr($minimum_color, 1, 1));
$fromB = hexdec(substr($minimum_color, 2, 1) . substr($minimum_color, 2, 1));
else {
$fromR = hexdec(substr($minimum_color, 0, 2));
$fromG = hexdec(substr($minimum_color, 2, 2));
$fromB = hexdec(substr($minimum_color, 4, 2));
$maximum_color = str_replace("#", "", $maximum_color);
if (strlen($maximum_color) == 3) {
$toR = hexdec(substr($maximum_color, 0, 1) . substr($maximum_color, 0, 1));
$toG = hexdec(substr($maximum_color, 1, 1) . substr($maximum_color, 1, 1));
$toB = hexdec(substr($maximum_color, 2, 1) . substr($maximum_color, 2, 1));
else {
$toR = hexdec(substr($maximum_color, 0, 2));
$toG = hexdec(substr($maximum_color, 2, 2));
$toB = hexdec(substr($maximum_color, 4, 2));
$colorR = round($toR + ($fromR - $toR) * (1 - $pos));
$colorG = round($toG + ($fromG - $toG) * (1 - $pos));
$colorB = round($toB + ($fromB - $toB) * (1 - $pos));
$color = "rgb(" . $colorR . "," . $colorG . "," . $colorB . ")";
return $color;
function print_r_tree($data){
// capture the output of print_r
$out = print_r($data, true);
// replace something like '[element] => <newline> (' with <a href="javascript:toggleDisplay('...');">...</a><div id="..." style="display: none;">
$out = preg_replace('/([ \t]*)(\[[^\]]+\][ \t]*\=\>[ \t]*[a-z0-9 \t_]+)\n[ \t]*\(/iUe',"'\\1<a href=\"javascript:toggleDisplay(\''.(\$id = substr(md5(rand().'\\0'), 0, 7)).'\');\">\\2</a><div id=\"'.\$id.'\" style=\"display: none;\">'", $out);
// replace ')' on its own on a new line (surrounded by whitespace is ok) with '</div>
$out = preg_replace('/^\s*\)\s*$/m', '</div>', $out);
// print the javascript function toggleDisplay() and then the transformed output
echo '<script language="Javascript">function toggleDisplay(id) { document.getElementById(id).style.display = (document.getElementById(id).style.display == "block") ? "none" : "block"; }</script>'."\n$out";
/* ############ MOON FUNCTIONS #################### */
// Moon rise/set
class MoonRiSet {
const RADEG = 57.29577951308232;
const DEGRAD = 0.01745329251994;
const ARC = 206264.8;
const SIN_EPS = 0.39768; // sin+cos obliquity ecliptic (23d26m)
const COS_EPS = 0.91752;
const PREC = 18; // precision
private $_sinEarthLatitude, $_cosEarthLatitude;
private $_data = array();
public function __construct($earthLatitude = false, $earthLongitude = false, $earthTimezone = false) {
if ($earthLatitude === false)
$this->earthLatitude = ini_get('date.default_latitude');
else
$this->earthLatitude = $earthLatitude;
if ($earthLongitude === false)
$this->earthLongitude = ini_get('date.default_longitude');
else
$this->earthLongitude = $earthLongitude;
if ($earthTimezone === false)
$this->earthTimezone = ini_get('date.timezone');
else
$this->earthTimezone = $earthTimezone;
// set current day
$this->setDate(date("Y", time()), date("n", time()), date("j", time()));
// set day
public function setDate($year, $month, $day) {
if ($year < 1583 or $year > 2500) return(false);
$old_timezone = date_default_timezone_get();
date_default_timezone_set($this->earthTimezone);
// calculation day's table, begin+end time
$t = $tb = mktime(0, 0, 0, $month, $day, $year);
$te = mktime(24, 0, 0, $month, $day, $year);
$this->tdiff = ($te - $tb) / self::PREC;
$this->_sinEarthLatitude = $this->dsin($this->earthLatitude);
$this->_cosEarthLatitude = $this->dcos($this->earthLatitude);
$i = 0;
while ($i <= self::PREC) {
$this->_data[$i]["timestamp"] = $t;
$jd = $this->getJulianDate($t);
$LST = $this->getLST($jd); // Local Sidereal Time
$this->_data[$i]["LST"] = $LST;
list($RA, $de) = $this->miniMoon(($jd - 2451545.0) / 36525.0);
$this->_data[$i]["RA"] = $RA;
$HA = $LST - $RA; // hour angle
if ($HA > 12) $HA -= 24;
$this->_data[$i]["HA"] = $HA;
$this->_data[$i]["sAlt"] = $this->_sinEarthLatitude * $this->dsin($de) + $this->_cosEarthLatitude * $this->dcos($de) * $this->dcos(15*$this->_data[$i]["HA"]); // sinus Altitude
$t += $this->tdiff;
$i++;
// Moon transit
list($this->transit["timestamp"], $this->transit["hhmm"], $this->transit["hh:mm"]) = $this->getTransit("HA");
// Moon's rise and set
list(
$this->rise["timestamp"], $this->rise["hhmm"], $this->rise["hh:mm"],
$this->set["timestamp"], $this->set["hhmm"], $this->set["hh:mm"],
$this->rise2["timestamp"], $this->rise2["hhmm"], $this->rise2["hh:mm"],
$this->set2["timestamp"], $this->set2["hhmm"], $this->set2["hh:mm"]
) = $this->getRiSet("sAlt", $this->dsin(0.125));
date_default_timezone_set($old_timezone);
return(true);
// PRIVATE //////////////////////////////////////////////////////////////////////////////////////////////////////////////////
private function getTransit($o) {
$fT = false;
for ($i = 1; $i < self::PREC && !$fT; $i += 2) {
if (($this->_data[$i-1][$o] < 0 && $this->_data[$i][$o] >= 0) || ($this->_data[$i][$o] <= 0 && $this->_data[$i+1][$o] > 0)) {
list($nz, $z1, $z2, $xe, $ye) = $this->quad($this->_data[$i-1][$o], $this->_data[$i][$o], $this->_data[$i+1][$o]);
$fT = true;
$oTran = $this->_data[$i]["timestamp"] + $this->tdiff*$z1;
if ($fT)
list($transit["timestamp"], $transit["hhmm"], $transit["hh:mm"]) = $this->formatTime($oTran);
else {
$transit["timestamp"] = false;
$transit["hhmm"] = " ";
$transit["hh:mm"] = " ";
return array($transit["timestamp"], $transit["hhmm"], $transit["hh:mm"]);
private function getRiSet($o, $alt) {
$fRise = $fSet = false;
$fAbove = false;
$oRise2 = $oSet2 = false;
if ($this->_data[0][$o] > $alt)
$fAbove = true;
for ($i = 1; $i < self::PREC; $i += 2) {
list($nz, $z1, $z2, $xe, $ye) = $this->quad($this->_data[$i-1][$o]-$alt, $this->_data[$i][$o]-$alt, $this->_data[$i+1][$o]-$alt);
if ($nz == 1) {
if ($this->_data[$i-1][$o] < $alt) {
if ($fRise === true)
$oRise2 = $this->_data[$i]["timestamp"] + $this->tdiff*$z1;
else {
$oRise = $this->_data[$i]["timestamp"] + $this->tdiff*$z1;
$fRise = true;
else {
if ($fSet === true)
$oSet2 = $this->_data[$i]["timestamp"] + $this->tdiff*$z1;
else {
$oSet = $this->_data[$i]["timestamp"] + $this->tdiff*$z1;
$fSet = true;
elseif ($nz == 2) {
if ($ye < 0.0) {
$oRise = $this->_data[$i]["timestamp"] + $this->tdiff*$z2;
else {
$oSet = $this->_data[$i]["timestamp"] + $this->tdiff*$z2;
$fRise = $fSet = true;
// output
if ($fRise === true || $fSet === true ) {
if ($fRise === true) {
list($rise["timestamp"], $rise["hhmm"], $rise["hh:mm"]) = $this->formatTime($oRise);
list($rise2["timestamp"], $rise2["hhmm"], $rise2["hh:mm"]) = $this->formatTime($oRise2);
else {
$rise["timestamp"] = false;
$rise["hhmm"] = " ";
$rise["hh:mm"] = " ";
if ($fSet === true) {
list($set["timestamp"], $set["hhmm"], $set["hh:mm"]) = $this->formatTime($oSet);
list($set2["timestamp"], $set2["hhmm"], $set2["hh:mm"]) = $this->formatTime($oSet2);
else {
$set["timestamp"] = true;
$set["hhmm"] = " ";
$set["hh:mm"] = " ";
else {
if ($fAbove === true) { // continuously above horizon
$rise["timestamp"] = $set["timestamp"] = true;
$rise["hhmm"] = $set["hhmm"] = "****";
$rise["hh:mm"] = $set["hh:mm"] = "**:**";
else { // continuously below horizon
$rise["timestamp"] = $set["timestamp"] = false;
$rise["hhmm"] = $set["hhmm"] = "----";
$rise["hh:mm"] = $set["hh:mm"] = "--:--";
// return
if ($oRise2 !== false)
return array(
$rise["timestamp"], $rise["hhmm"], $rise["hh:mm"],
$set["timestamp"], $set["hhmm"], $set["hh:mm"],
$rise2["timestamp"], $rise2["hhmm"], $rise2["hh:mm"],
false, false, false);
elseif ($oSet2 !== false)
return array(
false, false, false,
$set2["timestamp"], $set2["hhmm"], $set2["hh:mm"]);
else
return array(
// Low precision formulae for planetary position, Flandern & Pulkkinen
// returns ra and dec of Moon to 5 arc min (ra) and 1 arc min (dec)
// for a few centuries either side of J2000.0
// Predicts rise and set times to within minutes for about 500 years
private function miniMoon($T) {
$l0 = $this->frac(0.606433 + 1336.855225 * $T);
$l = 2*M_PI * $this->frac(0.374897 + 1325.552410 * $T);
$ls = 2*M_PI * $this->frac(0.993133 + 99.997361 * $T);
$d = 2*M_PI * $this->frac(0.827361 + 1236.853086 * $T);
$f = 2*M_PI * $this->frac(0.259086 + 1342.227825 * $T);
// perturbation
$dl = 22640 * sin($l);
$dl += -4586 * sin($l - 2*$d);
$dl += +2370 * sin(2*$d);
$dl += +769 * sin(2*$l);
$dl += -668 * sin($ls);
$dl += -412 * sin(2*$f);
$dl += -212 * sin(2*$l - 2*$d);
$dl += -206 * sin($l + $ls - 2*$d);
$dl += +192 * sin($l + 2*$d);
$dl += -165 * sin($ls - 2*$d);
$dl += -125 * sin($d);
$dl += -110 * sin($l + $ls);
$dl += +148 * sin($l - $ls);
$dl += -55 * sin(2*$f - 2*$d);
$s = $f + ($dl + 412 * sin(2*$f) + 541*sin($ls)) / self::ARC;
$h = $f - 2*$d;
$n = -526 * sin($h);
$n += +44 * sin($l + $h);
$n += -31 * sin(-$l + $h);
$n += -23 * sin($ls + $h);
$n += +11 * sin(-$ls + $h);
$n += -25 * sin(-2*$l + $f);
$n += +21 * sin(-$l + $f);
$l_moon = 2 * M_PI * $this->frac($l0 + $dl / 1296000);
$b_moon = (18520.0 * sin($s) + $n) / self::ARC;
// convert to equatorial coords using a fixed ecliptic
$cb = cos($b_moon);
$x = $cb * cos($l_moon);
$v = $cb * sin($l_moon);
$w = sin($b_moon);
$y = self::COS_EPS * $v - self::SIN_EPS * $w;
$z = self::SIN_EPS * $v + self::COS_EPS * $w;
$rho = sqrt(1.0 - $z*$z);
$de = (180/M_PI) * atan($z / $rho);
$RA = (24/M_PI) * atan($y / ($x + $rho));
if ($RA < 0) $RA += 24;
return(array($RA, $de));
// finds the parabola through the three points (-1,ym), (0,yz), (1, yp) and returns
// the coordinates of the values of x where the parabola crosses zero (roots of the quadratic)
// and the number of roots (0, 1 or 2) within the interval [-1, 1]
private function quad($ym, $yz, $yp) {
$z1 = $z2 = 0;
$nz = 0;
$a = 0.5 * ($ym + $yp) - $yz;
$b = 0.5 * ($yp - $ym);
$c = $yz;
$xe = -$b / (2 * $a);
$ye = ($a * $xe + $b) * $xe + $c;
$dis = $b * $b - 4.0 * $a * $c;
if ($dis > 0) {
$dx = 0.5 * sqrt($dis) / abs($a);
$z1 = $xe - $dx;
$z2 = $xe + $dx;
if (abs($z1) <= 1.0) $nz += 1;
if (abs($z2) <= 1.0) $nz += 1;
if ($z1 < -1.0) $z1 = $z2;
return(array($nz, $z1, $z2, $xe, $ye));
private function getJulianDate($t) {
//return $t/86400 + 2440587.5; // only for 64bit && year > 1582
$jd = gregoriantojd(gmdate("n", $t) ,gmdate("j", $t) , gmdate("Y", $t)) - 0.5;
$jd += gmdate("H", $t)/24 + gmdate("i", $t)/1440 + gmdate("s", $t)/86400;
return($jd);
// returns the local sidereal time (degree)
private function getLST($jd) {
$mjd = $jd - 2451545.0;
$lst = $this->range(280.46061837 + 360.98564736629 * $mjd);
return ($lst + $this->earthLongitude)/15;
// round time, return array(timestamp, "hhmm", "hh:mm")
private function formatTime($t) {
$t0 = 60*(int)($t/60+0.5);
if (date("j", $t) == date("j", $t0))
$t = $t0;
return array($t, date("Hi", $t), date("H:i", $t));
private function frac($x) {
return($x - floor($x));
private function range($x) {
return($x - 360.0 * (Floor($x / 360.0)));
private function dsin($x) {
return(sin($x * self::DEGRAD));
private function dcos($x) {
return(cos($x * self::DEGRAD));
function special(){
global $pageURL;
global $path;
global $stationLat;
global $stationCountry;
$timestampNow = time();
$icon = "fa fa-home";
if(date('m',$timestampNow)==1 && date('d',$timestampNow)==1){
$icon = "fa fa-glass";
if(date('m',$timestampNow)==12 && date('d',$timestampNow)==31){
$icon = "fa fa-hourglass-end";
if(date('m',$timestampNow)==12 && date('d',$timestampNow)==24){
$icon = "fa fa-gift";
if(date('m',$timestampNow)==12 && date('d',$timestampNow)==25){
if(date('m',$timestampNow)==12 && date('d',$timestampNow)>=20 && date('d',$timestampNow)<24){
$icon = "fa fa-tree";
if(date('m',$timestampNow)==3 && date('d',$timestampNow)==21){
if($stationLat>0){
$icon = "mticon-spring";
else{
$icon = "mticon-autumn";
if(date('m',$timestampNow)==6 && date('d',$timestampNow)==21){
if($stationLat>0){
$icon = "mticon-summer";
else{
$icon = "mticon-winter";
if(date('m',$timestampNow)==9 && date('d',$timestampNow)==23){
if($stationLat>0){
else{
if(date('m',$timestampNow)==12 && date('d',$timestampNow)==21){
if($stationLat>0){
else{
if($stationCountry=="us"){
if(date('Y',$timestampNow)==2017){
if(date('m',$timestampNow)==11 && date('d',$timestampNow)==23){
$icon = "fa fa-cutlery";
if(date('Y',$timestampNow)==2018){
if(date('m',$timestampNow)==11 && date('d',$timestampNow)==22){
if(date('Y',$timestampNow)==2019){
if(date('m',$timestampNow)==11 && date('d',$timestampNow)==28){
if($stationCountry=="ca"){
if(date('m',$timestampNow)==10 && date('d',$timestampNow)==9){
if(date('m',$timestampNow)==10 && date('d',$timestampNow)==8){
if(date('m',$timestampNow)==10 && date('d',$timestampNow)==14){
if(date('m',$timestampNow)==10 && date('d',$timestampNow)==31){
$icon = "fa fa-meh-o";
if(date('m',$timestampNow)==4 && date('d',$timestampNow)==16){
if(date('m',$timestampNow)==4 && date('d',$timestampNow)==1){
if(date('m',$timestampNow)==4 && date('d',$timestampNow)==21){
return $icon;
$fooCont = file_get_contents($baseURL."/footer.php");
if (strpos(strtolower($fooCont), 'meteotemplate.com') == false) {
echo "<!-- Error -->Error, contact the developer.";
die();
// Moonphase
define('MP_NEW_MOON_NAME','New moon');
define('MP_NEW_MOON_ID',0);
define('MP_WAXING_CRESCENT_NAME','Waxing crescent');
define('MP_WAXING_CRESCENT_ID',1);
define('MP_FIRST_QUARTER_NAME','First quarter');
define('MP_FIRST_QUARTER_ID',2);
define('MP_WAXING_GIBBOUS_NAME','Waxing gibbous');
define('MP_WAXING_GIBBOUS_ID',3);
define('MP_FULL_MOON_NAME','Full');
define('MP_FULL_MOON_ID',4);
define('MP_WANING_GIBBOUS_NAME','Waning gibbous');
define('MP_WANING_GIBBOUS_ID',5);
define('MP_THIRD_QUARTER_MOON_NAME','Third quarter');
define('MP_THIRD_QUARTER_MOON_ID',6);
define('MP_WANING_CRESCENT_NAME','Waning crescent');
define('MP_WANING_CRESCENT_ID',7);
define('MP_DAY_IN_SECONDS', 60 * 60 * 24);
class moonPhase {
var $allMoonPhases = array();
var $dateAsTimeStamp;
var $moonPhaseIDforDate;
var $moonPhaseNameForDate;
var $periodInDays = 29.53058867; // == complete moon cycle
var $periodInSeconds = -1; // gets set when you ask for it
var $someFullMoonDate;
// $timestamp (int) date of which to calculate a moon phase and relative phases for
function __construct($timeStamp = -1) {
$this->allMoonPhases = array(
MP_NEW_MOON_NAME,
MP_WAXING_CRESCENT_NAME,
MP_FIRST_QUARTER_NAME,
MP_WAXING_GIBBOUS_NAME,
MP_FULL_MOON_NAME,
MP_WANING_GIBBOUS_NAME,
MP_THIRD_QUARTER_MOON_NAME,
MP_WANING_CRESCENT_NAME);
$this->someFullMoonDate = strtotime("March 5 2015 18:05 UTC");
if($timeStamp == '' or $timeStamp == -1) $timeStamp = time();
$this->setDate($timeStamp);
function calcMoonPhase() {
$position = $this->getPositionInCycle();
if($position >= 0.474 && $position <= 0.53)
$phaseInfoForCurrentDate = array(MP_NEW_MOON_ID, MP_NEW_MOON_NAME);
else if ($position >= 0.53 && $position <= 0.724)
$phaseInfoForCurrentDate = array(MP_WAXING_CRESCENT_ID, MP_WAXING_CRESCENT_NAME);
else if ($position >= 0.724 && $position <= 0.776)
$phaseInfoForCurrentDate = array(MP_FIRST_QUARTER_ID, MP_FIRST_QUARTER_NAME);
else if ($position >= 0.776 && $position <= 0.974)
$phaseInfoForCurrentDate = array(MP_WAXING_GIBBOUS_ID, MP_WAXING_GIBBOUS_NAME);
else if ($position >= 0.974 || $position <= 0.026)
$phaseInfoForCurrentDate = array(MP_FULL_MOON_ID, MP_FULL_MOON_NAME);
else if ($position >= 0.026 && $position <= 0.234)
$phaseInfoForCurrentDate = array(MP_WANING_GIBBOUS_ID, MP_WANING_GIBBOUS_NAME);
else if ($position >= 0.234 && $position <= 0.295)
$phaseInfoForCurrentDate = array(MP_THIRD_QUARTER_MOON_ID, MP_THIRD_QUARTER_MOON_NAME);
else if ($position >= 0.295 && $position <= 0.4739)
$phaseInfoForCurrentDate = array(MP_WANING_CRESCENT_ID, MP_WANING_CRESCENT_NAME);
list($this->moonPhaseIDforDate,$this->moonPhaseNameForDate) = $phaseInfoForCurrentDate;
function getAllMoonPhases() {
return $this->allMoonPhases;
function getBaseFullMoonDate() {
return $this->someFullMoonDate;
function getDateAsTimeStamp() {
return $this->dateAsTimeStamp;
function getDaysUntilNextFullMoon() {
return round((1 - $position) * $this->getPeriodInDays(), 7);
function getDaysUntilNextLastQuarterMoon() {
$days = 0;
if ($position < 0.25)
$days = (0.25 - $position) * $this->getPeriodInDays();
else if ($position >= 0.25)
$days = (1.25 - $position) * $this->getPeriodInDays();
return round($days, 7);
function getDaysUntilNextFirstQuarterMoon() {
$days = 0;
if ($position < 0.75)
$days = (0.75 - $position) * $this->getPeriodInDays();
else if ($position >= 0.75)
$days = (1.75 - $position) * $this->getPeriodInDays();
return round($days,7);
function getDaysUntilNextNewMoon() {
$days = 0;
if ($position < 0.5)
$days = (0.5 - $position) * $this->getPeriodInDays();
else if ($position >= 0.5)
$days = (1.5 - $position) * $this->getPeriodInDays();
function getPercentOfIllumination() {
$percentage = (1.0 + cos(2.0 * M_PI * $this->getPositionInCycle())) / 2.0;
$percentage *= 100;
$percentage = round($percentage,1) . '%';
return $percentage;
function getPeriodInDays() {
return $this->periodInDays;
function getPeriodInSeconds() {
if($this->periodInSeconds > -1) return $this->periodInSeconds; // in case it was cached
$this->periodInSeconds = $this->getPeriodInDays() * MP_DAY_IN_SECONDS;
function getPhaseID() {
return $this->moonPhaseIDforDate;
function getPhaseName($ID = -1) {
if($ID <= -1)
return $this->moonPhaseNameForDate; // get name for this current date
return $this->allMoonPhases[$ID]; // or.. get name for a specific ID
function getPositionInCycle() {
$diff = $this->getDateAsTimeStamp() - $this->getBaseFullMoonDate();
$periodInSeconds = $this->getPeriodInSeconds();
$position = ($diff % $periodInSeconds) / $periodInSeconds;
if ($position < 0)
$position = 1 + $position;
return $position;
function getUpcomingWeekArray($newStartingDateAsTimeStamp = -1) {
$newStartingDateAsTimeStamp = ($newStartingDateAsTimeStamp > -1)
? $newStartingDateAsTimeStamp
: $this->getDateAsTimeStamp();
$moonPhaseObj = get_class($this);
$weeklyPhase = new $moonPhaseObj($newStartingDateAsTimeStamp);
$upcomingWeekArray = array();
for( $day = 0, $thisTimeStamp = $weeklyPhase->getDateAsTimeStamp();
$day < 7; $day++, $thisTimeStamp += MP_DAY_IN_SECONDS) {
$weeklyPhase->setDate($thisTimeStamp);
$upcomingWeekArray[$thisTimeStamp] = $weeklyPhase->getPhaseID();
} // END for($day = 0; $day < 7; $day++) {
unset($weeklyPhase);
return $upcomingWeekArray;
function setDate($timeStamp = -1) {
$this->dateAsTimeStamp = $timeStamp;
$this->calcMoonPhase();
----------------------------------------------ERRORS-------------------------------------------------
Deprecated: Function date_sunrise() is deprecated in /var/www/hurricanepub/template/homepage/blocks/summary/summaryBlock.php on line 103
Deprecated: Function date_sunset() is deprecated in /var/www/hurricanepub/template/homepage/blocks/summary/summaryBlock.php on line 104
Deprecated: Function date_sunrise() is deprecated in /var/www/hurricanepub/template/homepage/blocks/summary/summaryBlock.php on line 107
Deprecated: Function date_sunset() is deprecated in /var/www/hurricanepub/template/homepage/blocks/summary/summaryBlock.php on line 108
Deprecated: Function date_sunrise() is deprecated in /var/www/hurricanepub/template/homepage/blocks/summary/summaryBlock.php on line 111
Deprecated: Function date_sunset() is deprecated in /var/www/hurricanepub/template/homepage/blocks/summary/summaryBlock.php on line 112
Deprecated: Implicit conversion from float 2551442.8610880002 to int loses precision in /var/www/hurricanepub/template/scripts/functions.php on line 1218
Deprecated: Implicit conversion from float 1692208338.6023512 to int loses precision in /var/www/hurricanepub/template/scripts/functions.php on line 952
Deprecated: Implicit conversion from float 1692183888.8787467 to int loses precision in /var/www/hurricanepub/template/scripts/functions.php on line 952
Deprecated: Implicit conversion from float 1692232484.8760638 to int loses precision in /var/www/hurricanepub/template/scripts/functions.php on line 952
Deprecated: Implicit conversion from float 1692297236.82949 to int loses precision in /var/www/hurricanepub/template/scripts/functions.php on line 952
Deprecated: Implicit conversion from float 1692273457.5147862 to int loses precision in /var/www/hurricanepub/template/scripts/functions.php on line 952
Deprecated: Implicit conversion from float 1692320678.6056345 to int loses precision in /var/www/hurricanepub/template/scripts/functions.php on line 952
Warning: Undefined array key "next_1_hours" in /var/www/hurricanepub/template/homepage/blocks/summary/summaryBlock.php on line 1689
Warning: Trying to access array offset on value of type null in /var/www/hurricanepub/template/homepage/blocks/summary/summaryBlock.php on line 1689
You can see the errors with the new Functions.php that wont load tHE SUMMARY Block
