Stickers stops displaying text after PHP 7.1.7
Posted: Tue Jan 16, 2018 3:58 pm
by azchrisf
On my server, IIS 8.5, if I use anything after PHP 7.1.7 (even 7.1.13), the text on the sticker is missing.
Any ideas?
Re: Stickers stops displaying text after PHP 7.1.7
Posted: Tue Jan 16, 2018 4:14 pm
Post the link to your sticker that is not working
Posted: Wed Jan 17, 2018 3:55 pm
by azchrisf
It's not just one sticker - its all of them. On the setup.php page all of them are blank.
There is nothing in the PHP errors log.
Heres one:
http://www.copperwoodwx.com/meteo/plugi ... olor=white
Posted: Wed Jan 17, 2018 7:01 pm
Do you have access to your error log? Im afraid we need that your server hides the errors
Posted: Wed Jan 17, 2018 7:11 pm
by azchrisf
Yes I have root.
What do you want me to do?
Posted: Wed Jan 17, 2018 7:21 pm
if the text is not displaying there should be some error, something must have gone wrong, so it should be in the error log
Posted: Wed Jan 17, 2018 7:23 pm
by azchrisf
Nope nothing is present. The error log is working properly, I've verified it's recording with a purposeful error script.
It's set to record E_ALL.
Posted: Wed Jan 17, 2018 7:27 pm
So 7.1.8 does not work?
That really makes no sense, nothing was deprecated in v7.1.8
http://php.net/ChangeLog-7.php#7.1.8
Posted: Wed Jan 17, 2018 7:32 pm
by azchrisf
Ill try 7.1.8 later and let you know. But for right now 7.1.13 and 7.2.1 do not work.
Im going to backtrack it to 7.1.7 for now.
Posted: Thu Jan 18, 2018 7:46 am
by azchrisf
OK I've run through each version individually, it stops working after 7.1.11. Everything up to that it works, so 7.1.12 and later it's broken.
Posted: Sat Jan 20, 2018 2:14 pm
by azchrisf
Jacym you see above?
Posted: Sat Jan 20, 2018 4:43 pm
I see, but I didnt have time to look at this, the problem is that my provider does not offer any higher version than I already have, which is 7.1.5 so I have no way to try to do something until Im able to upgrade too, for me it works and I cant fix something that is already working if you see what I mean.
Posted: Mon Jan 22, 2018 2:24 pm
by azchrisf
If you want to PM me, I'll be glad to give you full access to my server for testing.
Posted: Mon Jan 22, 2018 3:38 pm
This just makes absolutely no sense, have a look....
changelog for the version where it stops working:
http://php.net/ChangeLog-7.php#7.1.12
Only bug fixes...
Posted: Tue Jan 23, 2018 10:05 am
by mpca86
On PHP 7.1.6. everything works without any problems...
Posted: Thu Jan 25, 2018 1:45 pm
by azchrisf
Jachym,
Don't know what to tell you - I did read the changelog. It breaks at 7.1.12 and later and all 7.2 versions on IIS and I've verified it. Anything before 7.1.12 it works fine. It can't be my machine because I can go back or forth different versions before that one and it works fine, if it was me it would be all the time.
As a .NET developer I've seen many times where bugfixes change something in the code that either was not documented before or internally breaks the way the function works based on the way your using it (strangely enough). Keep in mind Bugfixes have broken Windows features before too as well as others apps LOL.
This is a problem as a developer when you don't have the latest version to test on...that's why I'm offering root access to do testing. Once ISPs start upgrading your going to hear more complaints, so best to get ahead of the problem. I know alot of them dont upgrade PHP very often unless it's a security release.
mpca -
Um, read the thread - I said it stops working AFTER 7.1.7, which we know is now 7.1.11 - I was using 7.1.7, so of course it works under 7.1.6!
Posted: Thu Jan 25, 2018 2:54 pm
My provider is quite quick at upgrading, so I will upgrade as soon as it is available and then hopefully be able to find the issue.
