Block Install Empty
Posted: Sat Jan 20, 2018 5:08 pm
by Smithee
Afternoon - just set up my station using the Netamo API (Weather Display for some reason is failing to update - could be a block from my BT router). All is running but i have to install blocks/plugins via FTP, when i go to the blocks/plugins list via the template its blank. Just checking if this is the case with the latest version as my other install lists all the available blocks in the template?
http://www.finchamweather.co.uk/template/
(its a quick install at the moment - i do like the new boot strap mobile btw - is there a way to replicate the colour/design in the desktop view...?)
Re: Block Install Empty
Posted: Sat Jan 20, 2018 8:21 pm
Hi Andy,
yes it does not work for about 5% of users, sometimes block from my provider sometimes on your end, really cant tell and Im afraid not much we can do. I did not make any changes to these scripts in the latest version.
With regards to colors of mobile homepage - not sure what you mean because they use the very same CSS and colors as the rest of the page
