Advanced Setup Questions
Posted: Thu Feb 01, 2018 12:37 am
by Dehatter
2 questions_
1) Can you refer to a standard block from a menu? As in can I open meteorsBlock from the astronomy tab?
2) Are there any directions for the stickerInteractiveAnim.php plugin? I have guessed at a few parameters, but not been successful.
Sorry to bother-
Re: Advanced Setup Questions
Posted: Thu Feb 01, 2018 2:43 am
by jay_hoehn
Tom,
I can't answer your second question, but with the first you can not use a block as a plugin. Blocks need elements of the home page to operate.
Jay
Posted: Thu Feb 01, 2018 5:00 am
Correct, block is a block and will only run from within the homepage, it cannot be run from a menu and I do not consider adding this because it would only bring confusion.
StickerAnim - this was an experimental script which Ive written for myself to make my sticker a bit different. It is not meant for use so there are no instructions how to use it. You would need to modify the code a lot from inside the PHP
Posted: Thu Feb 01, 2018 5:09 am
by Dehatter
Thank you for the answers!
Posted: Fri Feb 02, 2018 12:33 am
by Dehatter
Only 5 hours later....I got the Anmi to work they way I wanted.
lol.....
Posted: Fri Feb 02, 2018 5:22 am
It is easier when you dont use the picture. Please dont post any tutorials, that script was not meant to be public, I accidentally included it in the download file.
Posted: Fri Feb 02, 2018 10:08 pm
by Dehatter
I won't. It was more complicated than I thought it would be, but I am stubborn and bullheaded, with a touch of OCD.
Posted: Fri Feb 02, 2018 10:37 pm
by Fraggboy
Uh oh. . . Don't look at my sig..
