plugin rain balance
Posted: Thu Feb 01, 2018 3:07 pm
by pascalg21
Capture d’écran 2018-02-01 à 15.59.30.png (59.77 KiB) Viewed 25142 times
Bonjour,
Comment est calculé le pourcentage (%)?? :?:
merci
Re: plugin rain balance
Posted: Fri Feb 02, 2018 2:16 am
by Ken Good
I would point out that the main set up file has a default setting of mm for the average rain settings. Soooo every time I go to the main file to make a change to something else, when I hit save, the rain setting gets changed back to mm from inches. This makes the readings on rain balance go out of wack ever time.
At least I know when I have made a change without realizing it. Ha!
Ken
Posted: Sat Feb 03, 2018 3:36 pm
by acatalano
http://I've noticed the same thing. Many changes seem to be lost. I've entered the station average data several times already, as well as other values.
Posted: Sun Jul 22, 2018 9:19 am
Hi Ken,
which setting/parameter exactly is not being saved, can you send me a screenshot? I checked the rain normals and units and it should be saved just like any other parameter.
Posted: Sun Jul 22, 2018 1:04 pm
by weatherbee
In the normal section of main setup it always reverts to mm, so if you change anything you have to remember to go to normal rain and pick in before you save.
Posted: Sat Sep 01, 2018 10:22 am
by Ken Good
Just to highlight this again, the choice defaults back to "mm" every time you make any other change. So if you want to make changes and you use "inches" in the history setting for temperature normals, you have to remember to change "mm" back to "in" because if you make any other change and press save, it defaults back to "mm."
Ken
