A bit of a story.
My meteobridge device had been working flawlessly for almost 20 days straight.
I went on vacation and within 5 hours of leaving home, it quit. My first notice was from cron-job.org, then from several of the other weather networks with which I have memberships. I had a friend attempt to reset both the MB unit and my Ambient ObserverIP unit, but she either was fearful of doing what I asked, or just did not do it.
In any case, I lost a number of days due to this issue. I understand there is a remote login for MB, but I had not set that up. That would not help the ObserverIP unit in any case. So........
I had a brainstorm. I ordered and installed 2 wireless "smart" plugs from Amazon for $25 total.
http://a.co/dlXOKK5
Now if this issue crops up again, I can "unplug" both devices and "plug" them back in over the internet, from anywhere in the world.
I still can't figure out how my MB device became aware that I had left my house!!
As to your specific issue, I do not have this problem. Generally speaking, my MB works flawlessly, though have had to reset the ObserverIP unit. It is my understanding the for some reason, these 2 devices do not play well together. This has only happened to me twice in the month that I have been running them. From others, I understand that connecting them to the router with a network cable makes this issue go away, and I might suggest you try that. In my circumstance they both are pretty far from the router and I will just continue to work on the wireless connectivity issue directly.
The latest version (Meteobridge-api 3.6-12117) seems to be working very very well, and I may just stick with it by booting from a flash drive (one must select try "USB Frist" and have a powered USB hub with a flash drive in it for the system to not update itself - Additional advantage is that the MB will boot without the need to connect to the internet (if your internet goes out during a storm), log the data, and then report when connected).
