Interactive Graphs/Tables issue
Posted: Sun Mar 25, 2018 2:00 am
Hello... another "I must be missing something simple" question. I just installed and configured a fresh copy of MT onto my Linux VPS. I am feeding the template using WEEWX. The database/update setup went fine.
In general, the template seems to working but I can't seem to get interactive graphs or tables to work. I've tried using a couple of different browsers, so I'm sure I have something missing in the PHP or Apache configuration. Does something need to be configured for Highcharts to work?
One other strange problem I'm having is the Statistics section is not working for Precipitation only. It seems to be working for other data points. Also, I've confirmed there is definitely precipitation data in the database and I can see data under Current Conditions (Avg, Max and Total), so not sure why the Statistics section is not pulling the data.
If anyone has any ideas on what would be causing these issues, let me know.
Here is the site... note, I haven't setup any blocks or anything like that yet, just the default menu items. I wanted to make sure all the data is working before I customize it further.
http://vps.horkboy.com
Thanks!
Thanks!
